SupBeetle4Zaid Samba Member
Posted: Mon Dec 11, 2017 7:44 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| Buggeee wrote: |
| That is an awesome cat. What a nice surprise. |
oh yes a blessing. it wasn't bothered by any of the power tools or hammering. This kitty is cut out for this kind of work. |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3542 Location: Pennsylvania
Posted: Mon Dec 11, 2017 8:24 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
You got a buddy to help.  |
Posted: Mon Dec 18, 2017 4:16 am Post subject: Re: My first Resto project - 1975 super beetle 1303 |
I cut off some rust, wasnt brave enough to make bigger cuts.. And cutting is the easy part haha.
As Dwayne1m kindly suggested along many other great suggestions on PMs, I have cut through to the foam on the other rear quarter from the inside as it would be more forgiving cosmetically. I have found no foam and less rust, will need patches where fender bolts go as its rusted through on many parts:
But its a chance to convert and paint the rust there anyway. I wonder what could be under that patch there, didnt have the heart to check last night.
Dodgy Samba Member
Joined: January 30, 2006 Posts: 523 Location: Leicester, UK
Posted: Tue Dec 19, 2017 8:42 am Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| Dodgy wrote: |
Great! A fellow '75 1303 rescuer!
These must be getting pretty rare now as fashion has favoured the early Beetles for so long - but Supers (especially the late ones) are so much better to drive than other Beetles you will definitely enjoy it when all your work is done.
Looking forward to seeing your progress! |
I agree, these beetles are good daily drivers which is exactly what i want. I was advised not to save it but I am not giving up on it. My observation is that these are rare and almost extinct in Jordan. I have come across your 75 build log and i gotta say your repairs are AMAZING! and your car started off with many of the same rust problems i have so ill look at the log closely and highly appreciate any advice you could spare. Thanks for stopping by. |
Posted: Sun Jan 28, 2018 1:17 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
after a long break from the project (due to high demand from work) I have worked several days on cleaning the interior from all the insulation and endless types of glue, would paint stripper take care of glue remnants?
I have converted the rust on the inside panel (death foam area), next I will prime it and paint it with Ace rust stop if that works, otherwise Ill have to order POR15, which will take time to arrive:
there is a spot I cant stop thinking about when its time to prep the car for paint. I have no Idea how I would reach it (to strip old paint and repaint)
Another question I have is, how would I paint the inside of a panel I am going to weld, even if its covered in weldable primer, wouldn't the weld line itself be bare metal? and maybe rust and infect the surrounding area?
-Zaid |
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Sun Feb 11, 2018 3:00 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
Paint stripper will remove the glue residue but also the paint...
POR 15 is not as good as used to be...A good industrial use primer it will be good to use...
I suggest you to do not make any further cuts to the body until to find a donor , also a good wash will also reveals more problem areas , as for the rear window louvers , sandblasting or paint remover aerosol works good there...
Good luck and keep the pics coming...
Jim |
Posted: Thu Feb 15, 2018 7:12 am Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| Jim Hunter wrote: |
Jim |
Thanks a million jim, I do plan on removing all the paint anyway. So instead of por15 should I use epoxy primer? I will wash the car and hold off on the cuts until i have patched what i already cut.
Thanks for advice on rear window louvers.
Zaid |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11394 Location: Huntington Beach, CA
Posted: Thu Feb 15, 2018 8:58 am Post subject: Re: My first Resto project - 1975 super beetle 1303 |
Hi Zaid, vinegar will eat rust. Just take a towel, lay it on the rusty steal and drench the towel. Keep it wet, by reapplying vinegar and covering the towel with plastic, so that it does not evaporate quickly. In several hours the rust will start to dissolve and the fresh steel will appear. If there is no good steel, you will be left with holes.
Vinegar is acetic acid. Acetic acid dissolves rust and will not harm the good metal. Acetic acid is almost always the active ingredient in “rust disolvers”. Cheap and easy. There is also Naval Jelly. If you can get Naval Jelly, that is acetic acid in a Jelly form that sticks onto vertical surfaces.
Use a weldable primer. Be sure to prime the back side after welding, or you will have rust once again. I use primer in the spray can and a straw. Drill small holes on the inside as needed to reach the back side.
Good luck! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Thu Feb 15, 2018 1:40 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| Quote: |
Zaid |
Hi Zaid,
Yes a good epoxy primer it would be ideal , just clean as best as you can the surface before.Epoxy primers are 98% weldable as well...
Vinegar as suggested is also good but use white vinegar instead...
Good luck! |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4972 Location: Stuck in Ohio
Posted: Thu Feb 15, 2018 9:15 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
For my louvered area I poured the paint stripper in a spray bottle (like window cleaner), although an aerosol can (as Jimbo suggests) would also work, and then after it bubbled up I blasted it out of there with a water pressure washer to get in there between the cracks. It took a few applications and power washings to finally get all the old paint scraps out of there. Once it was all bare metal I used a couple of cans of aerosol spray paint self etching primer. The spray paint cans let me get up close in between the cracks and up under the louvers until it was sealed up again. There were some sloppy drips outside on the louvers from getting in so close but those sanded right down.
I like to use phosphoric acid to dissolve rust, because it converts the surface of the metal bonding with the molecules somehow.
Good luck! _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
Posted: Fri Feb 16, 2018 4:27 am Post subject: Re: My first Resto project - 1975 super beetle 1303 |
I just noticed the clear shield on the front of the Super. Is that aftermarket or home made? That looks so much better then a bra. I wonder how it's attached. |
Posted: Wed Feb 21, 2018 7:47 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
I will surely try the "stripper in a spray bottle" suggestion as I cant source spray can stripper. I love the idea of drilling a hole on the inside and spraying the welded area, very cleaver thanks!
I went junk Yard hunting and found most of the body metal I needed, almost at welding stage!
I made a short video of the junk yard hunting I though some might find it interesting to see what it would look like in Jordan. thank you guys for all the help and support.
heres the link:
Last edited by SupBeetle4Zaid on Sun Mar 04, 2018 2:35 am; edited 2 times in total |
Posted: Thu Feb 22, 2018 4:28 am Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| Interesting video. Finding a rust free donor like that here is almost impossible. Why didn't you jump on the zebra station wagon???(1:15 of video) |
Posted: Thu Feb 22, 2018 9:16 am Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| Dwayne1m wrote: |
Hahah i noticed zebra wagon every time I went, I wonder what purpose it served.
The car was in a surprisingly good shape, and I cut so much for 80$
Now I am starting to work on the fit to weld ..wish me luck.
Glad you found the video interesting and thank you for keeping an eye on my build log  |
Posted: Thu Feb 22, 2018 12:29 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
Im glad you like the video, and I agree, miracle of the Internet.
I am pretty sure I wont be able to find sprayable stripper here, it was difficult finding the regular one but this is the same brand I have.
I also bought a body hammer and dolly bloc. I also got a spray gun, cheap one for spaying the epoxy primer after i strip the car. I get excited over tools, thought id share.
Posted: Thu Feb 22, 2018 1:21 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| SupBeetle4Zaid wrote: |
I get excited about buying new tools too!! That part of the reason I like this hobby! _________________ Jimbo
| TDCTDI wrote: |
Posted: Thu Feb 22, 2018 3:16 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| VW_Jimbo wrote: |
I get excited about buying new tools too!! That part of the reason I like this hobby! |
tools are a beautiful thing..Im a tool head |
Rome Samba Member
Joined: June 02, 2004 Posts: 10694 Location: Pearl River, NY
Posted: Thu Feb 22, 2018 5:06 pm Post subject: Re: My first Resto project - 1975 super beetle 1303 |
| That was an ENORMOUS junkyard! Glad you found good metal for your '75. |
