nohabusguy Samba Member
Posted: Sun Mar 09, 2008 7:27 am Post subject: Syncro Decoupler on the blink |
Recently acquired an 89 Syncro with the decoupler (middle knob) and rear locker (right knob) set up. The syncro has the solid shaft now with the VC removed. I have noticed recently that the decoupler switch isn't engaging and disengaging without driving for a long period of time. There isn't a lot of rhyme or reason to when it works properly or not, except that its been very cold and snowy out in Massachusetts where I live. For example, I might push the middle switch back in to turn off the front wheel drive and the green light won't go off for at least a few miles of driving. Same way when I pull the switch, it will take a while to engage. If I drive for 20 plus miles, then it might start to work normally where pulling and pushing the switch causes the light to go on and off pretty quickly. The four wheel drive is definitely working when the light is on, as I am getting normal traction.
I will likely take it to my local VW guy to have it checked out. But he doesn't work on this type of set up too often (as he told me over the phone -- I could hear him thinking "I don't want to get involved with this"). Any thoughts on whether this is a minor/major problem, and what might need to be repaired? Thanks! |
jakebayless Samba Member
Joined: March 05, 2007 Posts: 180 Location: Santa Rosa, CA
Posted: Sun Mar 09, 2008 9:28 am Post subject: |
If I had to guess (which I'm doing ) I'd say that there is most likely a vacuum leak somewhere.
The control knob in the dash is merely a valve turning vacuum on or off to the actuator mounted back on the decoupler. (same actuator as the rear locker - exactly same system)
If you or your mechanic can verify adequate vacuum in the lines to & from the triple lobed vacuum canister under the drivers side frame rail, you are well on your way.
Two other likely scenarios I've seen are either a rusted acutator shaft (if rust is prevalent in your part of the world) or a sticky actuator itself.
I'd be willing to bet James (Dogpilot) can give you more specifics... Probably even has schematics!
I've been fortunate enough to have a troublefree decoupler for only a year or so... (still would LOVE to get my hands on a front locker!)
cheers,
~jake |
silversyncro Samba Member
Joined: May 20, 2006 Posts: 135 Location: silverton colorado
Posted: Sun Mar 09, 2008 9:50 am Post subject: |
My 91 syncro westy had what sounds to be the same issue earlier this winter. The problem turned out to be the vacuum check valve located under the van next to the vacuum resevoir. I just went down to napa and bought a generic valve for like three bucks, and it works like a charm again.
You just need to get the motor running, pull or push the knob so that you are asking it to do something...then crawl under there and start pulling vacuum lines off starting at the decoupler till you find either a blockage or a leak. Syncro.org has a great trouble shooting guide for your difflock if you need more info |
Posted: Mon Mar 10, 2008 6:06 pm Post subject: |
Thanks for the leads. I will check those out. |
Posted: Tue Mar 11, 2008 6:39 am Post subject: |
jakebayless has a few good points too, but the rear difflock, and the the de-coupler are not controlled by the same actuator in exactly the same place, they are in two totally different locations. That doesn't mean that a vacuum leak at, or on the way to your difflock wouldn't effect your de-coupler though.
Just didn't want you going on a wild goose chase.
Good luck |
Posted: Thu Jun 19, 2008 5:07 pm Post subject: |
Finally got around to crawling under the Syncro and troubleshooting this problem ... pulled off the check valve, and shot it with wd-40 and then compressed air (the stuff I use to clean my keyboard). I put the check valve back on and now everything works fine. Decoupler engages and disengages as it should. Thanks! _________________ 1967 Double Cab
1967 21 Window Deluxe Bus
1989 Westy Syncro (Subaru 2.5, dreaming of installing a NAHT)
1990 Doka Syncro (WBX 2.1) |
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Thu Jun 19, 2008 8:56 pm Post subject: |
nohabusguy wrote: |
Finally got around to crawling under the Syncro and troubleshooting this problem ... pulled off the check valve, and shot it with wd-40 and then compressed air (the stuff I use to clean my keyboard). I put the check valve back on and now everything works fine. Decoupler engages and disengages as it should. Thanks! |
Syncro's are too expensive to own and operate blah blah blah Burn the engineers!! _________________ Imagine that, theres not an "h" in either Westfalia or Syncro? |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10661 Location: Western WA
Posted: Fri Jun 20, 2008 9:49 am Post subject: |
buspor63 wrote: |
well Jesus H! .....I never noticed that before.  _________________
....KTMs, GasGas, SPOT mtb |
MTV1960 Samba Member
Joined: March 29, 2011 Posts: 51 Location: Costa Rica
Posted: Thu Dec 21, 2017 11:59 am Post subject: Re: Syncro Decoupler on the blink |
Hi there, hope you can help trouble shooting an issue with my decoupler as it is not engaging. was working fine when parked 5 months ago. van is located in costa rica and was parked during the rainy season. rear locker works fine! a bit slow bit comes on in a min or so when pulled. What ive done so far.: Pulled off the check valve and sprayed it with WD40 and blew it out with compressed air. Has flow one direction. I can hear pressure at the dash switch when depressed. Then i pulled off the tubes at the actuator and sucked on both. one was holding and the other one was not until i pulled the knob then is was holding a seal one direction. could it be the actuator is bad by just sitting for 5 months? was going to remove it to inspect and clean it but thought i would ask a pro if that is possible to clean and reinstall or a waste of time. I dont have a backup part here in Costa Rica and would have to wait for some one bring one from the states. What do you suspect the problem is and if there is suggestion to try something now? pain to take down the rock guard if i dont have a new part or if that is that is te actual problem at all.
Thanks Michael V _________________ 86 Wolfsburg Weekender
87 Syncro Westy |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Thu Dec 21, 2017 12:24 pm Post subject: Re: Syncro Decoupler on the blink |
They do get stubborn from lack of use. Maybe you can try working the actuator back and forth multiple times with a couple pieces of spare hose. Jack up a front tire and turn it slowly while sucking on the tube. You will know as soon as it engages as it won't turn any more. It does not take a lot of mouth pressure to activate them so if it does you know it is probably gummed up and you might have to take some of it apart to grease it up.
Every time my locker or decoupler started to give me trouble it was a crusty hose with cracks right at the nipple on the actuator. I cut off a bit of the end and back to normal. In one case I replaced a small section with some silicone hose. But mine are well greased underneath and I exercise them regularly. |
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Thu Dec 21, 2017 12:43 pm Post subject: Re: Syncro Decoupler on the blink |
For me, it's always been the check valve .. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Thu Dec 21, 2017 12:54 pm Post subject: Re: Syncro Decoupler on the blink |
Ill give it a try. What would be the procedure for that? Suck on the top or the bottom? guess i need a length of hose thats long enough to work the front wheel at the same time. Would the knob need to be open of closed at the same time ? _________________ 86 Wolfsburg Weekender
87 Syncro Westy |
Posted: Thu Dec 21, 2017 12:57 pm Post subject: Re: Syncro Decoupler on the blink |
Regards to the ck valve. i can move air one direction only but it not super open feeling. not sure if thats normal. Requires a bit to pressure to blow air past the valve. could that be restricting that system? I Do have a working rear locker and i think they share the check valve right? _________________ 86 Wolfsburg Weekender
87 Syncro Westy |
Posted: Thu Dec 21, 2017 1:06 pm Post subject: Re: Syncro Decoupler on the blink |
You should be able to suck and blow through just one but take both hoses off the actuator then it doesn't matter the position of the dash button. The "suck to engage" is the inner blue nipple on the spare I just checked.
Gears may be right about the check valve. You could remove it and see if it is working. I don't think you even need the check valve, there is always suction in the cannister so it doesn't ever get pressurized. But you could remove it at least temporarily. |
clift_d Samba Member
Joined: December 02, 2012 Posts: 272 Location: Hackney innit, UK
Posted: Thu Dec 21, 2017 2:23 pm Post subject: Re: Syncro Decoupler on the blink |
Check it's not the decoupler indicator sensor before you go much further. This is similar to the reverse gear indicator sensor in that it is switched by a groove on the actuating shaft moving past the sensor. You should have the access to pull this sensor from the nose of the gearbox without too much difficulty which will then allow you to see whether the actuator shaft is actually moving or not. We had a similar issue a couple of years back when we were in Iceland, in that we thought our decoupler was sticking but it turned out that the indicator sensor was failing. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4568 Location: East Kootenay, British Columbia
Posted: Thu Dec 21, 2017 4:34 pm Post subject: Re: Syncro Decoupler on the blink |
Van-Cafe:
http://www.van-cafe.com/diff-lock-actuator-check-valve
And lots of other goodies:
http://www.van-cafe.com/diff-lock-actuator _________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Posted: Thu Dec 21, 2017 5:40 pm Post subject: Re: Syncro Decoupler on the blink |
Right, so your saying that you were engaged but the sensor was not sending so the light was not on?
Im pretty certain im not engaged at all. I dont here or feel any grinding on the gravel when making a turn. I have zero access to parts here in Costa rica. I know of a syncro club in Nicaragua that could have parts but its too far. Im going to drop the Rock guard and remove the actuator and see if i can clean it. All the tubing looks fine.
This country is harsh on everything made by man. Syncro is headed back north for a refit in April. FYI think twice about bringing down your Vans to this part of the world unless you have at least one spare part of every part on the van, and every tool you can think of. List of parts replaced since 2014:
-2 wheel bearings
-2-rear CV's
-Power steering rack
-front claiper
-multiple bulbs
-Shure flow faucet
-Aux battery
-Subi oil pressure switches
-Subi SS header
-head light adjusters
-fuel filter
-prop shaft yokes
-wiper arms
-Front control arm bushings
-Coolant expansion tank
Pura Vida! Good surf though! _________________ 86 Wolfsburg Weekender
87 Syncro Westy |
Posted: Thu Dec 21, 2017 5:42 pm Post subject: Re: Syncro Decoupler on the blink |
Any one headed to Costa Rica that can bring me a check valve and an actuator?  _________________ 86 Wolfsburg Weekender
87 Syncro Westy |
Posted: Thu Dec 21, 2017 7:24 pm Post subject: Re: Syncro Decoupler on the blink |
MTV1960 wrote: |
Right, so your saying that you were engaged but the sensor was not sending so the light was not on? |
Correct. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
gears Samba Member
Posted: Fri Dec 22, 2017 7:47 am Post subject: Re: Syncro Decoupler on the blink |
If you can suck air through the check valve in one direction only, it's OK (it's supposed to seem semi-restricted).
Leaky hose somewhere would be my next guess. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
