Coolant hose rubbed on cv axle boot
Vanagator
Vanagator is offline
PostPosted: Mon Oct 10, 2016 4:17 pm    Post subject: Coolant hose rubbed on cv axle boot Reply with quote
I can't believe I didn't notice this, but my hose rubbed on the axle and scarred it pretty good......
This is the hose shown in the Bentley....
another shot of the hose....
It's not leaking but doesn't look like I want to ignore it for long. It's a hose that comes from the front heat exchanger (Heater, I guess). I have a heater shut-off valve installed on the other hose that goes to the heat exchanger that I got from Terry Kay. It is 5/8" heater hose.
My question; is there a way to fix this hose without draining the whole system, replacing it and re-filling the system.
Thanks in advance for any comments!
Vanagator
PostPosted: Mon Oct 10, 2016 4:50 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
OH Hey! It just occurred to me that I should be able to just pinch the hose on either sides and install a splice/coupler.??
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Oct 10, 2016 8:12 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Depending on where the shut off valve is installed, maybe only pinch one hose?
If hose is in good shape, why not?
I had the same thing happen with a fairly new heater hose.
I was lazy and shunted in a piece of 1/2" copper
pipe. (double clamped). Would suggest you buy a proper plastic part.
Your FLAPS should have a "Help" type part or similar.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
GWTWTLW
GWTWTLW is offline
PostPosted: Mon Oct 10, 2016 8:52 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Don't ignore it. I've gone through 2 coolant hoses that way. Both left me on the side of the road.
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
Michael4104
Michael4104 is offline
PostPosted: Mon Oct 10, 2016 9:41 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
So how many are looking under their vans now. 😀
To the OP a slice as suggested should do the trick. It's done all the time.
1990 Wolfsburg Carat with new poptop.
1985 Westy now sporting a 1995 Jetta ABA 2.0L. Sold
Vanagator
PostPosted: Tue Oct 11, 2016 8:03 am    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Well the hose is 5 years old now and looks to be still in good shape.
I will go ahead and put in a coupler where it rubbed raw.
Hey everybody make sure you look under you van and make sure your not rubbing!
Thanks....
vegpedlr
vegpedlr is offline
PostPosted: Tue Oct 11, 2016 8:51 am    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Happened to me twice. Each hose. Plastic splice and a few minutes crawling around under the van. The second time a tried the rescue tape to see how it worked. Took a few tries to get enough on there, then it held well. Lasted for an oil change, taking the guys at SAH by surprise. Everyone impressed by the self sealing tape, so good to have some when on the road.
1985 Tintop 4 sp GW 2.3 “Connie”
2006 Mk V GTI 2.0 FSI “Penelope”
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Tue Oct 11, 2016 9:25 am    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Call me paranoid, but I generally use brass fittings for such applications:
Especially considering the heat/cold cycles of these hoses & fittings, and the impact of a failure, I prefer the brass over a cheap plastic part of unknown quality ...
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
0to60in6min
0to60in6min is offline
PostPosted: Tue Oct 11, 2016 10:42 am    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
wouldn't be easier to replace it with a longer hose, run it on top of the larger hose and tie it there?
djkeev
djkeev is offline
PostPosted: Tue Oct 11, 2016 11:25 am    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
I had the exact same rubbing on NEW heater hose that I installed Embarassed
I repaired it with a brass fitting rather than plastic. Pinched off both side, cut and inserted the coupler and clamped. Then I repositioned the hose so that won't happen again!
Dave
Ghia
Vanagon
Beetle
Vanagator
PostPosted: Wed Dec 27, 2017 5:08 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
hey... does anyone have any practical ideas of how to pinch the hose on either side of the coupler, if you don't have proper hose clamps??
I would rather not lose a bunch of fluid.....
dhaavers
dhaavers is offline
PostPosted: Wed Dec 27, 2017 5:14 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
^^^ Couple of vice grips will work...(needle nose is your best bet).
- Dave
"The WonderVan"
Vanagator
PostPosted: Wed Dec 27, 2017 5:20 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Right on, I have one, I could probably scrounge up a second.....
Wildthings
Wildthings is offline
PostPosted: Wed Dec 27, 2017 5:26 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Harbor freight sell cheap but effective hose pinchers. Yes Vicegrips will work, but I like to use something to protect the hose from the teeth on the jaws.
It is really not a big deal to drain the system into a clean bucket and then reuse the coolant.
Steve M.
Steve M. is offline
PostPosted: Wed Dec 27, 2017 5:50 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Vice grips and two pieces of wood squeezing the hose.
A assortment of hose barb splices for each size hose in the system and the hose clamps should be part of your onboard kit.
Vanagator
PostPosted: Wed Dec 27, 2017 8:25 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
yep that's what I was thinking good idea...
no Harbor Freight down here in Mexico! I did see a Mexican set but cheaped out....I'll have that clean bucket ready though. Also, I thought about slipping a used piece of hose over the vice grips for protection...
Jeffrey Lee
PostPosted: Wed Dec 27, 2017 8:53 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
^^ This ^^
If using a ViseGrips, I suggest protecting the rubber hose from the jaws by using a short section of 1/2-inch-diameter wooden dowel, split lengthwise to form two half-round sections.
Here are a few more tools to carry onboard, including a few home made custom ones:
http://campwestfalia.com/emergency-board-vanagon-tool-kit/
Camp Westfalia
Vanagator
PostPosted: Wed Dec 27, 2017 8:59 pm    Post subject: Re: Coolant hose rubbed on cv axle boot Reply with quote
Excellent idea, thanks!
