modok Samba Member
Joined: October 30, 2009 Posts: 27716 Location: Colorado Springs
Posted: Tue Jan 09, 2018 9:42 pm Post subject: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Crank dowel jobs are a real challenge.
How do you make 8 pins line up perfectly at the same time, and fit perfectly straight in their perfectly fit holes with just the right press-fit?
You lie to yourself. That's as close as you will ever come. perfection is impossible
But I tried real hard this time and I took some pictures. Probably not enough pictures, but anyway it worked well enough I don't need to destroy the evidence, rather can share it.
Best christmas gift ever, my brother got me this fancy welding helmet.
Two LARGE parallel bars hang off the back of the table and there is my precision crank clamp-er, which is bored to 2.170" Shims are used to fit different sizes.
I welded up the holes, and faced the back of the crank flat again.
Put the flywheel on, check that it's straight, then attempt to ruin multiple drills and reamers boring into the welds. Wishing for a smooth hole with .001 press and praying they don't go oversize.
This device here lets you see how tapered ovaly and rough your holes are, which is depressing. it was a lot easier not knowing.
Success
[/img] |
esde Samba Member
Joined: October 20, 2007 Posts: 6362 Location: central rust belt
Posted: Tue Jan 09, 2018 10:14 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
VERY NICE.
Thanks for sharing. And nice helmet, the Speedglas are my favorite masks.
What mangled crank was that? _________________ modok wrote:
modok Samba Member
Posted: Tue Jan 09, 2018 10:28 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
It's the one you think it is.
Porsche journal, Okrasa
Whatever alloy these are, weld there will be HARD spots. like a-2 steel or something.
old scat crank, chinese crank, were far easier.
I haven't yet tried fixing the one you traded me. I probably will, since I have it all setup. CRANK MODE |
esde Samba Member
Posted: Tue Jan 09, 2018 10:38 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Glad that you were able to fix it for him. I thought it might be the okrasa, the way they are finished is not like anything made now. And, very interesting to see the crank holding arrangement. I've been pondering the same thing, but have no parallels stout enough, yet sound like another excuse to buy tools..
I'm curious, since you've done a few of these repairs, what have you done / figured out along the way thats made the job easier?
LOWE TECH Samba Member
Joined: June 22, 2016 Posts: 44 Location: SW Washington
Posted: Tue Jan 09, 2018 11:06 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
FGood post! I’m a Speedglass fan but I’’m missing the custom paint. Merry CHRISTmas! All these little details go unnoticed unless you’ve tried ‘em yourself. Try saving a hole by welding it shut or lay out multiple holes with a tight tolerance, diametric or X-Y, be honest. Just more small details that add up to ones work.  |
nsracing Samba Member
Posted: Wed Jan 10, 2018 1:35 am Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
I am just curious what the runout is after the flywheel was mounted?
Mount the package on a rollers and find out.
What did you do to cleanup the welds and establish the original flat for the flywheel to sit on? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2528 Location: Meridian,ID
Posted: Wed Jan 10, 2018 7:49 am Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
I'm getting a fizzy feeling all over my body!!  |
Dauz Samba Member
Posted: Wed Jan 10, 2018 9:20 am Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
glen, what size are those dowels? Have you ever used 8mm? |
anthracitedub Samba Member
Posted: Wed Jan 10, 2018 9:34 am Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Very nice job man. A lot better than I did at age 17 with a hand drill on an assembled engine.😁 |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Wed Jan 10, 2018 9:56 am Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Modok, nice work. ..and that jig you made seems to work for you. ..I thought they made oversized pins to solve the oval-shaped hole problem? ...wouldn't it be easier to just re-drill all the holes for bigger pins?
VeeWeeman  |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4123 Location: San Diego
Posted: Wed Jan 10, 2018 10:07 am Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
What reamers did you use? |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3650 Location: Paradise, Ca
Posted: Wed Jan 10, 2018 3:17 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Nice job! Looks like you have lots of other vw goodies layen around there, cool shop! _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1624 Location: The South Zone
Posted: Wed Jan 10, 2018 3:30 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Holy smoked nuts! If there's ever a cylinder head shortage in the world, now I know who to blame. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Jan 10, 2018 4:11 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
How much material did you end up taking off the end of the crank to make it flat?
I have at least 100 cranks that I need to do this to. Many of them are perfect std/std too.... _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Ebel Samba Member
Posted: Wed Jan 10, 2018 4:35 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
I would think the labor involved would make it too costly to save stock cranks. |
modok Samba Member
Posted: Wed Jan 10, 2018 5:26 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
nsracing wrote: |
To face it I used a simple flycutter, which I made myself, out of a crankshaft.
I indicated off the thrust surface to see the crank was square before facing it.
I then I took it off the mill, set on the flywheel and applied grinding paste to lap the flywheel can crank to eachother, then cleaned if off and bolted it up and checked runout again. When I put it back in the mill with flywheel attached I indicated the flywheel to see that the runout was the same as when it was on vee blocks.
I also checked the runout again after installing the pins. |
modok Samba Member
Posted: Wed Jan 10, 2018 5:28 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
[email protected] wrote: |
I have at least 100 cranks that I need to do this to. Many of them are perfect std/std too.... |
Somewhere between .001 and .002" |
modok Samba Member
Posted: Wed Jan 10, 2018 5:37 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
veeweeman wrote: |
VeeWeeman  |
Several of the original holes were ovaled so badly they were almost connected. The other crank in the last picture is next, I have only welded 5 of them, as 1 hole is ok and the other two can just be oversized. |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4071 Location: Rapid City, South Dakota
Posted: Wed Jan 10, 2018 6:53 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Awesome work!!
Have you perfected the broken off flush pin removal yet?
Modok's FUBAR'ed crank repair service.
Brian |
esde Samba Member
Posted: Wed Jan 10, 2018 7:41 pm Post subject: Re: Fixing cranks; dowel pins loose?? Holes un-drilled and re-drill |
Ebel wrote: |
when you can no longer find a std/std stock crank, it will be worth it. Hell, they're hard to find now. _________________ modok wrote:
