flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2135 Location: Perry, GA
TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Mon Jan 01, 2018 6:18 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
I can’t wait to see how you fix this rust.
You should see my car! _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 521 Location: Shoreline, WA
Posted: Sun Jan 07, 2018 8:18 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
Yikes, I fear mine may be in the same shape... I can't wait to see your repairs.
Cheers!
Mike _________________ 1964 Sedan 6 volt |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3389 Location: Dirty Jersey
Posted: Mon Jan 08, 2018 6:58 am Post subject: Re: 1958 De Luxe Beetle from Morocco |
You need to cut all that rot out, make up and shape the new pieces, and weld them in. _________________ 1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks! |
Posted: Mon Jan 08, 2018 8:31 am Post subject: Re: 1958 De Luxe Beetle from Morocco |
Yes sir, I'm just waiting on a stretcher/shrinker so I can start bending some metal. It'll be here Wednesday. I had to work this past weekend and I'll be working next weekend as well, so I'm just in the evaluation stage right now.
I typically work one area at a time to keep from getting to many pots on the fire. So far I've closed up a big gash in the rear firewall. After that I repaired a 6" crack on the hood. Currently the front clip is nearing completion with welding new metal in after cutting out the rot and straightening the bent metal. I will work the windshield area next followed by the rear window. I really despise Bondo but a little glazing putty is unavoidable. And truthfully the only reason I've used any glazing putty at this point was to test the invisibility of the repairs. I'll finish up by revisiting the heater channel repairs I did 3 years ago. Everything else is solid and intact.
Finally, I'll have the car dustless blasted. This is why I'm trying to avoid any putty at this point. It will be removed when the car gets blasted. Hopefully nothing gross pops out of that. Then I'll do my final glazing/fill, prime it and prep for paint.
I don't like looking at the whole project this way, but rather approach it from a milestone point of view. There is no end point in time, I'm just in metal repair mode now. But, I do welcome advice and appreciate all of it. _________________ 1968 Westfalia
https://www.thesamba.com/vw/forum/viewtopic.php?t=792825&highlight=
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483 |
TheDon Samba Member
Posted: Mon Jan 15, 2018 12:34 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
That’s awesome work. How did you get the curve into your patch piece for the. Rear window channel? _________________
lawn ninja wrote: |
TheDon Samba Member
Posted: Mon Jan 15, 2018 7:40 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
I had figured that. But I meant the slight curve the joins the rest of the body work, not the window channel. _________________
lawn ninja wrote: |
TheDon Samba Member
lawn ninja wrote: |
Posted: Tue Jan 16, 2018 11:24 am Post subject: Re: 1958 De Luxe Beetle from Morocco |
Here's a step by step of the patch fabrication
Today we'll be fabricating a patch for this area
First I cut a rough piece out of the front clip I bought a couple of weeks ago. This is from the gas tank struts. It's already been through the stretcher to get the radius of the back window. Clamped in place with vice grips I'll lightly hammer the shape to match the curve downward on the body.
Here it is.
I removed it and cut it to size. It is now clecoed in place to check fit.
It required a little more hammer to lay like it should.
After hammering I drew an outline of the piece.
And voilà. It is ready to be cleaned up. This was all done prior to cutting the body. I'm using the body as a dolly in essence. Tomorrow I'll clean up the piece to remove the paint and straighten the edges smooth. Then I'll mark the body and cut out the bad metal slightly smaller than the patch. _________________ 1968 Westfalia
TheDon Samba Member
Posted: Tue Jan 16, 2018 1:02 pm Post subject: Re: 1958 De Luxe Beetle from Morocco |
awesome. thats what I was needing!
thank you for taking the time and photos _________________
lawn ninja wrote: |
