daroota Samba Member
Posted: Wed Feb 27, 2013 10:39 pm Post subject: Droopy/baggy sun Visors |
Anyone know a way to restore the sun visors?
My Visors are a little sad looking. They swing, and prop up correctly, but the vinyl is baggy and bloated.
I haven't found anything on the forums or anywhere else. Most people say just replace them, but I'm sure there must be a way.
The only way I could see is cut open a seam, apply contact cement and pulling it shut tight and a little heat to reclose the seam again... but the heat source would have to be something not too hot that could melt it back together like heated Sheet metal pliers or something.
Has anyone tried anything else that worked or looks good? |
subwayaz Samba Member
Posted: Wed Feb 27, 2013 10:59 pm Post subject: |
There cheap enough just replace them; after they get old the loosens up and I don't think even contact cement would make them look nice. And if you add thin foam then there to thick. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17171 Location: Brookeville, MD
Terry Kay Banned
Posted: Thu Feb 28, 2013 7:25 am Post subject: |
Other than having an upolstery shop custom make you a new pair, there is no cure for your issue with the bagged out visors.
But two nice used ones,or cut your's apart, try and pull them tight, and glue tham up.
You'll never be happy with the end result, unless you have some sort of vinyl welder in stock. _________________ T.K.
BoneMachine Samba Member
Joined: January 15, 2012 Posts: 202 Location: MA, Boston Strong
Posted: Thu Feb 28, 2013 8:03 am Post subject: |
I got tired of looking at mine, they're at SewFine right now, getting recovered. They were 'baggy' as you described. The other thing I noticed when taking them down was the plastic 'hardware' is bio-degrading. Replacement hardware would be a good aftermarket product. _________________ '85 Wolfsburg Edition Westfalia Weekender, Zetec #36, w/ Peloquin TBD
'83.5 Westfalia, full camper (we'll never forget you) |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1938 Location: Sidney B.C. Canada
Posted: Thu Feb 28, 2013 8:39 am Post subject: |
A friend of mine sewed up very nice visor repair. I don't know what he used as interior padding but it shows that it can be done without using any vinyl welding/gluing.
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
Last edited by ragnarhairybreeks on Thu Feb 28, 2013 8:01 pm; edited 1 time in total |
Terry Kay Banned
Posted: Thu Feb 28, 2013 10:49 am Post subject: |
That repair / new visors look real nice Alistair.
From a vinyl surge/ binding welder he now has moved up into an Industrial sewing machine.
His Montgomery Ward, Sears, Speigal's, Gambles, Gimbles, or Western Tire home style sewing machine unit won't quite get through the binding, material on the visor & the cardboard backer real good.
Might bend some needles, and cause machine to do some stalling in the process.
I don't think that all would fit between the foot & the feed.
Good idea though. _________________ T.K. |
VWaddict01 Samba Member
Joined: September 17, 2012 Posts: 51 Location: Seattle WA
Posted: Thu Feb 28, 2013 12:07 pm Post subject: |
You could also try the loose steering wheel grip trick. Take a syringe filled with glue and inject it in the loose/baggy parts of the sun visor... _________________ 1990 lifted 2wd (for now..) Vanagon "Savanna"
1979 bagged Rabbit L
1977 B1 Passat Estate
2014 Jetta
(Searching for the next air-cooled project) |
r39o Samba Polizei
Posted: Thu Feb 28, 2013 12:30 pm Post subject: |
I have reinflated saggy visors for other vintage cars.
Using 2 pieces of wood with spacers I make a frame spaced the thickness of the visor.
With the visor in the wooden frame I inject expanding foam. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Thu Feb 28, 2013 4:06 pm Post subject: |
alistair that looks HOT!
I may have to see if I can get that done, maybe put a little foam piece in the middle. |
Posted: Thu Feb 28, 2013 8:04 pm Post subject: |
They are nice, and Terry is right in that it does take some skill to pull off. When Steve gets his van all together it is going to have of the nicest interiors around. The visors are only just the tip of the iceberg.
I can see someone hand stitching leather on the visors. Don't laugh, some vanagon owners put more work into other parts of the van.
cheers
http://shufti.wordpress.com |
Reventlos Samba Member
Joined: May 24, 2009 Posts: 103 Location: Costa Mesa, CA
Posted: Fri Mar 01, 2013 1:33 am Post subject: |
Not to hijack this thread, but has anyone come up with a sano way to keep the visors in place in rough terrain? Tightening the set screw is pretty imprecise---too tight, and you can't use the visor, too loose and in falls down. I've tried Velcro, but it doesn't like to stick the headliner of the Syncro Westy. I'm thinking of some sort of little swivel bracket screwed into the headliner that you could turn to hold the visor in place. Somebody must have had a good idea for this. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Feb 06, 2018 9:48 pm Post subject: Re: Droopy/baggy sun Visors |
This thread talks about recovering the sun visors but on mine the vinyl is fine - it is the inside that has disintegrated and they are like an envelope full of dust. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
jimf909 Samba Member
Posted: Tue Feb 06, 2018 11:07 pm Post subject: |
Terry Kay wrote: |
Good idea though. |
Is there a TK Hall of fame where we can save masterpieces of non-sequitors like this? Would the mods object to a TK/dylan HOF thread? TK’s flat-earth denial of the Mullendore port would be a nice start. Just for fun and learning. Perhaps it could also include the posts that were actually helpful so it would be fair, balanced and land in the no-spin zone.  _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Wed Nov 21, 2018 4:00 am Post subject: Re: Droopy/baggy sun Visors |
I installed these ones from Van Cafe a few months ago to replace the bags of disintegrated foam that mine had become: https://www.vancafe.com/251898550A-p/251898550a.htm
They are Classic Line made by JP Group but the driver one has started to fall down already. _________________ 1962 Karmann Ghia
