Vanagon Life V.O.W. Drivers Side Window
designer
designer is offline
PostPosted: Sat Jan 20, 2018 12:09 pm    Post subject: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Does anybody have one of these? Seems like a super cool idea, for a Westy, where that window is basically useless, anyways.
With the MOLE system inside, does it get in the way of your table if you have the table lifting mod - which is one of the best mods ever.
I'm about to order a pass-through storage locker and might throw one of these in.
-thanks!
-cc-
__________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013.
benandmj
benandmj is offline
PostPosted: Sat Jan 20, 2018 12:15 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
I don’t have the VOW window but I saw one in person last week and like all Vanagonlife products it looked well thought out and well made. For those not familiar:
http://www.vanagonlife.com/theshop/vowdriver
On the other hand, What is the MOLE system? And the table lifting mod?
85 Westfalia Weekender
91 Syncro Westy
dhaavers
dhaavers is offline
PostPosted: Sat Jan 20, 2018 5:38 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
It's MOLLE, actually... https://en.m.wikipedia.org/wiki/MOLLE
- Dave
"The WonderVan"
Steve M.
Steve M. is offline
PostPosted: Sun Jan 21, 2018 6:24 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
It is a good idea. For me though creating wind drag which ultimately effects fuel economy and engine/gearbox wear is not something I want to do right now.
Team WorldTour
Team WorldTour is offline
PostPosted: Sun Jan 21, 2018 6:52 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
I thought this was a good idea, and tried to do it on my own:
As for the inside, I just tacked the MOLLE directly to the cabnets:
I think for the exterior, I'm going to do a frame over the Alu.
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
drj434343
drj434343 is offline
PostPosted: Mon Jan 22, 2018 9:34 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
I have one of these units and have been happy with it. Installation was as easy as a normal glass window. I can't comment on clearance issues with the cabinets because I have custom units in my van.
I've got MOLLE pouches attached both inside the cabinet and outside over the counter, including a MOLLE first aid kit. Overall, the MOLLE addition was a smaller part of why went with this kit, because you can easily add MOLLE in other places as people have stated.
I also added the kit because I've always hated how that window was split by the cabinet system allowing people to see inside the cabinets.
Additionally, I needed a clean way to route a bunch of wires up to the top of the van, and running them behind the MOLLE provided that option.
I may mount some items to the outside, but haven't decided yet.
Note that the RMW side ladder will interfere with this upgrade. I had to modify the right side upper ladder seat because it now wants to rest on the raised sheet of metal.
bokonon42
bokonon42 is offline
PostPosted: Mon Jan 22, 2018 10:33 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Have you got any pics of that? I have the VOW and have been considering the RMW side ladder... thanks.
Terry
88 Vanagon Wolfsburg Carat - https://www.thesamba.com/vw/forum/viewtopic.php?t=671319
warrenmzz
warrenmzz is offline
PostPosted: Tue Feb 13, 2018 2:47 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Can the overland window be installed with westy cabinets in place, or must the cabinets be moved temporarily during install.
Thanks
dobryan
dobryan is offline
PostPosted: Wed Feb 14, 2018 5:47 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Thanks
If it is installed like the stock window then it can be done. It is not easy but I have done it three times.
You'll need to start your overlapped cord at the middle of the rear side seal so the the rear seats first and then work your way around the top and bottom to the front side. Long thin arms help a lot. Or you can push out the backing of the closet and remove it to gain better access. It is just held on by a gazillion staples.
Dave O
The Western Syncro build
shagginwagon83
shagginwagon83 is offline
PostPosted: Wed Feb 14, 2018 6:09 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
If you did install one of these wouldn't you want to push out the back of closet anyway - for extra storage with the MULE system?
Syncro Jael
Syncro Jael is offline
PostPosted: Wed Feb 14, 2018 7:47 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
I already had the RMW ladder. Then I installed the VOW on both sides. So to keep the ladder I made a mount for the bottom. I also drilled holes in the mount for adjusting pins. You can still pull a pin, slide it out, for better footing. You also need to position it correctly so that the hook-up box access doors will still function. There is just enough room.
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
Sasquatsh
Sasquatsh is offline
PostPosted: Thu Oct 25, 2018 8:30 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Hi very interested in doing it myself too, more info on how you did it would be appreciate! Looks good!
Team WorldTour
PostPosted: Fri Oct 26, 2018 8:00 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Quite easy to do, really.
I ordered two sheets of 3mm aluminum composite (a sheet of pvc between two sheets of Alu).
Cut to shape of window.
Install in window seal/ window hole.
Lather, Rinse, Repeat.
Click to view image
shagginwagon83
PostPosted: Fri Sep 02, 2022 1:40 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Feedback wanted Vanagon Life Overland Window. I own some VL products and they're very high quality.
I realize Van Cafe has an aluminum piece of metal as an option - but I really like the MOLLE grid.
1. For those who installed high lift jack in this location, is it practical? That seems like a LOT of weight to put in the window seal.
2. For Westy owners with driver rear, can anyone provide a picture using the MOLLE storage system? I imagine it would be nice to punch out the closet backing so that you can utilize that system.
drj434343
PostPosted: Fri Sep 02, 2022 2:17 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
I have both the drivers rear and rear gate VL overland windows installed.
The driver's side panel has a high lift jack plus two rotopax tanks and I haven't seen any issues with the seal bearing this weight. I drive this van as hard as you probably can a 2WD, and things have stayed on and together.
I cut a hole in the rear panel and installed a Maxxair fan because my early pop top didn't have a skylight and it is now completely covered in solar panels. I also modified both panels by sandwiching the readily available window insulation between the molle panels and the outside panel. This really cut down on the sense that the panels got "cold" at night; aluminum is a better conductor of heat than glass!
I have a variety of molle pouches on the molle now, but couldn't find pictures of this. I generally store needed camping accessories on these panels (flashlights, bear spray, sunscreen, first aid, etc). On the rear gate panel I have bedding related items like extra blankets, inflatable pillows, ear plugs, etc.
The price is high, but these are quality pieces for sure. I gained a lot of extra storage not normally available, and I also found I liked the increased privacy in the back.
shagginwagon83
PostPosted: Sat Sep 03, 2022 8:35 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
Okay I am sold. I might be sold on the rear window now also. My Westy too doesn't have a skylight and the roof is covered by solar panels.
Beautiful van! Thank you for your feedback!
vanis13
vanis13 is offline
PostPosted: Sat Sep 03, 2022 9:00 am    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
drj434343 wrote:
5 - connection boxes on side panel (under side ladder)- Please share what all you got hooked up to those.
drj434343
PostPosted: Sun Sep 04, 2022 1:58 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
1. Water tank fill quick disconnect
2. Shore power/battery charge
3. Pressurized water quick disconnect from tank (hose with sprayer or I connect to a hanging propane powered tankless water heater for showers).
4. Propane quick disconnect (using grill from stock tank or water heater above)
5. Compressed air disconnect (ARB pump underneath, for airing tire back up, bike tires, rafts, etc)
@shagginwagon83, that Maxxair fan is top 5 improvements I've added, and it was pretty straight forward cutting the hole and mounting it. One advantage of the vertical orientation is that the top serves as an awning, which means I can continue to run the fan even in heavy rain without triggering the rain sensor which closes the top. The fan is essential given my lack of AC, plus wet winters in the NW.
tjet
tjet is offline
PostPosted: Sun Sep 04, 2022 11:45 pm    Post subject: Re: Vanagon Life V.O.W. Drivers Side Window Reply with quote
I've been thinking about getting the VL rear window blank, and install a smaller window on it that opens.
This one has a screen, too. It's about the size of the Doka rear window
https://www.thesamba.com/vw/forum/album_page.php?pic_id=2043579
