Sherm Samba Member
Joined: October 30, 2009 Posts: 21 Location: South Central Oregon
Posted: Sun Feb 11, 2018 7:09 pm Post subject: Rear floor pan insulation or? |
Here are some photos of "something" I think is covering the rear floor pans on my '69 type 1. I have never seen this before and I suspect that previous owner has added something. Or at least I hope that is what it is. Has anyone seen such a covering before? I've not pulled the rear carpet yet and checked the pan however I was told by local VW repair shop that the pans had been replaced. All thoughts are welcome, and thanks. |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Sun Feb 11, 2018 7:42 pm Post subject: Re: Rear floor pan insulation or? |
It looks like a rubberized undercoat that is coming off.
If it were mine, I'd clean it all off to see what the metal looks like then paint it with POR15, marine paint, or whatever you prefer. I have an aversion to rubberized undercoating. Too often people use it to cover up crappy temporary repairs or rust. |
Daddy o's 67 Samba Member
Joined: November 25, 2008 Posts: 118 Location: Lancaster, SC
Posted: Sun Feb 11, 2018 7:56 pm Post subject: Re: Rear floor pan insulation or? |
Looks to me like the floor pan is rotted out. Better pull the seat out and the carpet or vinyl floor mat up to see what is going on. |
vwoldbug Samba Member
Posted: Mon Feb 12, 2018 8:32 am Post subject: Re: Rear floor pan insulation or? |
If the floor pans were replaced it was decades ago . |
CWAVE Samba Member
Posted: Tue Feb 13, 2018 9:08 am Post subject: Re: Rear floor pan insulation or? |
My vote is to strip off the rubberized coating (that appears to be letting go in many places), grind it down to bare metal, and POR-15.
I did that on mine (granted I'm doing a body off restoration of my VW) but the idea is the same. I too am not a fan of those coatings, as it can hide things you'd want to know about. POR-15 is a good solid finish, and you'll be able to spot problems before they become real issues down the road.
This isn't a replaced pan. This is the original 1973 factory pan after being cleaned up and POR-15'd. Yours could look like that too!
CWAVE |
bluebus86 Banned
Posted: Tue Feb 13, 2018 9:36 am Post subject: Re: Rear floor pan insulation or? |
The failed under coating should be removed as it can act as a water trap and thus promote rust. Sometimes dealers or aftermarket vendors, or owners add undercoating such as this.
Bug On, With a Clean Bottom! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
AlmostHeavenWV_VW Samba Member
Posted: Tue Feb 13, 2018 2:36 pm Post subject: Re: Rear floor pan insulation or? |
I'd get the old coating off and address the underlying issues- coatings/paints don't usually fail without an underlying problem.
Once you have repaired/addressed the issues on the pan, you can do a number of things:
1) Grind to bear metal then use PO-15/MasterSeries Silver
2)Get fixed, use a rust converting primer over surface rust, then paint with other paint
(Eastwood Extreme chassis black/ Eastwood 'rust-encapsulator' paint)
3)Get fixed, then use a Rust encapsulating rubberized coating (Eastwood brand one option)
I would not use a plain 'rubberized undercoating' that doesn't have rust-addressing compounds for the previously mentioned hiding or trapping of issues (water/rust/rot) _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7032 Location: Clyde, TX
Posted: Tue Feb 13, 2018 3:52 pm Post subject: Re: Rear floor pan insulation or? |
Daddy o's 67 wrote: |
Agreed. While there is some thin undercoat and some areas of unidentified goop slopped on, that looks like rotted out sheet metal. _________________ 1960 Ragtop w/Semaphores "Inga" |
Joined: August 31, 2013 Posts: 12865 Location: North Carolina
Posted: Tue Feb 13, 2018 4:30 pm Post subject: Re: Rear floor pan insulation or? |
I don't know what everybody else is seeing, but those pans are shot. Judging by the sheet metal screws protruding through the pans, whatever "repair" was done looks like it was screwed over the top of the rusted out original. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
scdevon Samba Member
Joined: October 18, 2017 Posts: 163 Location: Rockies
Posted: Wed Feb 14, 2018 10:48 am Post subject: Re: Rear floor pan insulation or? |
Insulation?
Those pans are rotten from the inside out. _________________ 1970 Beetle 1600 DP |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Wed Feb 14, 2018 11:45 am Post subject: Re: Rear floor pan insulation or? |
the black stuff on the underside of the pan is undercoating some hack smeared over the rotten pan from the bottom of the car. the rubbery stuff coming out of the rot is the sealant some hack smeared over the rotten pan from inside the cabin. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Feb 14, 2018 5:52 pm Post subject: Re: Rear floor pan insulation or? |
In the POs last pic it sorta' looks to me like there's a seam going across the left pan right in front of the light brown colored dirty area. I agree that some major work needs done. Reminds me that my battery is on its way to dropping through the floor in the foreseeable future. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Sherm Samba Member
Posted: Wed Feb 14, 2018 9:51 pm Post subject: Re: Rear floor pan insulation or? |
My appreciation to all that have responded to my post. I will be removing all of the "substance" covering the rear pans and will also look under the carpet. Chances are that the pans are history. Gives credence to the saying "buyer beware." I appreciate all of your responses. |
