Battery trays are too expensive soooo.....
Page: 1, 2, 3  Next
art_lessing
art_lessing is offline
PostPosted: Mon Mar 19, 2018 3:47 pm    Post subject: Battery trays are too expensive soooo..... Reply with quote
So I made my own!!!
its a tad small though
...Actually I was just noticing how pricey they are, 100+ bucks and decided to give a scale model an attempt at fabrication
This was really easy at this size, I don't anticipate 22-20 gauge being much harder.
I have one question to any fabricator people out there, how does one fabricate a channel for seals?
c21darrel
c21darrel is offline
PostPosted: Mon Mar 19, 2018 4:34 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
LOL, that was great! It looked small but i wasn't sure til i read your post.
Channels ....basically a flat piece with ends folded over...but they do not touch in center.
https://www.thesamba.com/vw/classifieds/detail.php?id=1273083
GhiaBuild
1967 DC build
djkeev
djkeev is offline
Get a piece of cold rolled steel flat bar.
Shape the bar to fit inside an existing seal "C" channel.
Cut a strip of sheet metal and bend it around your newly created form. Slide the form out.
Dave
Ghia
Vanagon
Beetle
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Mon Mar 19, 2018 4:56 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
I thought "where did he get those YUUUGE scissors?"
Mellow Yellow 74
Mellow Yellow 74 is offline
PostPosted: Mon Mar 19, 2018 8:05 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
Unless you have access to a folding brake, bead roller and shrinker/stretcher it will be much harder. Even with these you will probably take longer in your time than $100 is worth and turn out worse than a bought one unless you know what you are doing.
By all means do it for the feeling of achievement in doing it yourself but if you are only trying to save $100 do yourself a favour and buy a repro one. I have bought and made a lot of panels as part of my resto and my conclusion is that if there is a repro part available, you are better off buying instead of making your own except for very simple patch pieces.
1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
J1
J1 is offline
PostPosted: Mon Mar 19, 2018 8:31 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
Agreed. Here’s one of my first fabrication attempts and it took WAY longer than expected, for a lesser result of course than a purchased item. I believe this was 18g. https://www.thesamba.com/vw/forum/viewtopic.php?p=7677793#7677793
I’ve seen examples here of folks doing some pretty amazing fabrication without “real” tools and if you have the patience and skill, I’m sure we’d all love to see it. But be prepared to be brutish for the wrestling match, while also delicate to finesse stubborn pieces of metal.
I actually have to work on my battery tray too and I will for sure be buying one. Well, unless you provide some inspiration!
1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth.
djkeev
djkeev is offline
PostPosted: Tue Mar 20, 2018 5:45 am    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
There was a video, I cannot find it now, of a "3rd" World resident fabricating almost perfect replacement floor sections for a bus with little more than a pair of tin snips, a blunt chisel and a hammer.
Dave
Ghia
Vanagon
Beetle
kman
kman is offline
PostPosted: Tue Mar 20, 2018 6:11 am    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
I agree with this mostly But for $100 this piece is pretty easy. I've had a lot of practice by now but I could do it with hand tools in under an hour, Cut a blank form out of oak and it will make the bends much easier, especially the curved section. Buy a shrinker/ stretcher and you won't have to notch the curved section at all, though there are other ways to shrink and strecth this is easiest.
71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead
djkeev
djkeev is offline
PostPosted: Tue Mar 20, 2018 3:52 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
People have often criticized me for rebuilding or fixing something that is easily replaced with a simple purchase.
They made the same statement that it isn't worth the time invested ..... yada yada yada.
Fact is........ This is a Hobby.
Yes, hobbies cost money but they are also fun.
If I can have fun spending $20 and spend two days recovering my Vanagon dash that can be replaced with a $100 used one..... so what?
Do those of you who fish, hunt, boat, play golf, etc assign a dollar value to the hours you spend at the hobby?
If so, how much did that Bass you caught for dinner the other day REALLY cost you per pound? An easy thousand or two?
Dave
Ghia
Vanagon
Beetle
Evil_Fiz
Evil_Fiz is offline
PostPosted: Tue Mar 20, 2018 5:01 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
^^^ X2. My hobby hours are paying me dividends in the form of: escape from the day-to-day, satisfaction in personal accomplishment, and granting me new knowledge that only comes from doing instead of buying.
...we're all in this together,
Emil
“…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
art_lessing
PostPosted: Tue Mar 20, 2018 8:34 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
Yep...I am in over my head but what a better way to learn. And save a hundred bucks plus labor for each side. That being said, I figure since this is my first body repair, it's a perfect starting point. I am not skilled to do any butt welds so body panels are out. This section has no complex curves so it feels like I can do it with basic tools. Hammers sheet metal pliers, chisels ect. My plan is to make a paper template of the rotted panel before de-welding it and then add a seam allowance for the flanges. Then since my battery is on the other side, I will cut a hole in my new panel that will hold a six pack. I am going to need it for when I tally up all the missing tin I do have to purchase...
c21darrel
PostPosted: Wed Mar 21, 2018 11:47 am    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
Make extra space for Ice, going to be warm back there. Wink
GhiaBuild
1967 DC build
NOVA Airhead
NOVA Airhead is offline
PostPosted: Thu Mar 22, 2018 7:47 am    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
art_lessing wrote:
...I don't anticipate 22-20 gauge being much harder.
What?! You mean you are not going to use an old license plate or street sign? After seeing so many cars I thought this was the standard material for floor pan and battery tray repairs!
Very Happy Very Happy Very Happy
Ghia Owner Emeritus
kman
kman is offline
PostPosted: Thu Mar 22, 2018 8:08 am    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
or ductwork sheet metal with rivets?
Even 18 gauge mild steel isn't too bad to work with.
art_lessing
PostPosted: Thu Mar 22, 2018 8:36 am    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
I was considering it but once I unfastened the PO metal bandaid I found this
Then upon poking around I found that they tried to cover it with fiberglass
Some of the rear tray is bad too, but I did notice that the metal up by the battery fastener is still solid! As well as the under support beam
It looks like a tweaker started to cut into it and gave up...
kiwighia68
kiwighia68 is offline
PostPosted: Thu Mar 22, 2018 11:18 am    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
djkeev wrote:
... This is a Hobby...
Dave
It's also therapy that keeps the ghosts of aging, boredom and self-doubt at bay. Peace of mind that money can't buy.
By the way, there's also the wow factor. Every time you look at the completed job you go, "Wow, I did that all by myself!"
Priceless.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
anthracitedub
anthracitedub is offline
PostPosted: Thu Mar 22, 2018 6:27 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
Having a creative hobby is one of the main steps in being a healthy individual.
xzener
xzener is offline
PostPosted: Thu Mar 22, 2018 7:59 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
Was this the look on your face when you ripped off the band-aid??
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
art_lessing
PostPosted: Thu Mar 22, 2018 8:42 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
Yep... I found that the apron bracket support ( where do I find those?) is not attached, the other one is missing, the bumper support metal has lost the top lip on places, there is a weird seal/gasket on the tail light section of the battery tray, is the battery tray even attached to the body? the suport for the rear engine shelf is not attached... that's the one under the curved portion of the shelf where it meets the battery tray, I only hAve right sided tin snips and the metal is almost as thin as tin foil even on the good parts.....what the hell am I doing here....?
Mellow Yellow 74
PostPosted: Thu Mar 22, 2018 9:15 pm    Post subject: Re: Battery trays are too expensive soooo..... Reply with quote
I have a friend who renovated his house and installed down lights throughout. His wife proudly told me that he did it himself but he is not the most handy of people so I queried this. What she meant was that he told the electrician where to install the lights all by himself.
1962 Karmann Ghia
Page: 1, 2, 3  Next
