JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Sun Jun 03, 2018 1:12 am Post subject: WW oil vapor barrier any effect on engine case breathing 36hp |
I am running a 1192cc 36hp engine with a WW okrasa kit, and also installed their oil vapor barrier.
As the engine now has it maximum hp at roughly 4500 while an original 36hp is achieving that at roughly 3600. (see dyno sheet: https://www.thesamba.com/vw/forum/album_page.php?pic_id=1682081)
I also installed the WW oil vapor barrier, which goes into the oil filler neck.
I have some doubts regarding this part, according to me it will limit the engine case breathing because the plate is working as a restrictor.
on a standard 36hp which is slowly driven it will work ok but what about an okrasa engine which is frequently driven hard.
Who has any experience with this barrier in relation to tuned 36hp engine case breathing? Or any advise? _________________ 1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - 83Nm@3610rpm |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Sun Jun 03, 2018 5:28 am Post subject: Re: WW oil vapor barrier any effect on engine case breathing 36hp |
I installed that on my engine but I also used vented valve covers like this
No problems with breathing cruising at 80 MPH _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
JeeWee Samba Member
Posted: Tue Jun 05, 2018 8:47 am Post subject: Re: WW oil vapor barrier any effect on engine case breathing 36hp |
Honestly I had to look twice to this picture to see what is vented. but now I do see that there is a pipe running in the middle, starting from top and exiting in the bottom of the valve cover. Have you made that yourself? Or was it an accessory back in the days? It looks pretty easy to weld that on, what is the pipe diameter?
anyone else remarks on the oil vapor barrier? I guess you will also be able to run without and not have leaking, as it was not originally designed with this part. _________________ 1192CC WW okrasa
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1341 Location: south san francisco
Posted: Tue Jun 05, 2018 9:20 am Post subject: Re: WW oil vapor barrier any effect on engine case breathing 36hp |
it works great. it was a original part on 25hp motors. when they added the draft tube to the oil filler they stopped using it. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Tue Jun 05, 2018 9:31 am Post subject: Re: WW oil vapor barrier any effect on engine case breathing 36hp |
I made my own, link to directions in this thread
https://www.thesamba.com/vw/forum/viewtopic.php?p=3183534 _________________ Rick
| tasb wrote: |
| sb001 wrote: |
Big_E_Deluxe Samba Member
Joined: September 23, 2013 Posts: 288 Location: Charlotte, NC
JeeWee Samba Member
Posted: Tue Jun 05, 2018 11:44 pm Post subject: Re: WW oil vapor barrier any effect on engine case breathing 36hp |
cool, I will take your advise, I'll make a set of those valve covers. I have thrown out the WW oil vapor barrier, with a proper alternator gasket I am sure it will not leak, just install it properly.
I have 8mm copper (cunifer) lines which I will use as well for my fuel lines, currently in progress to convert to Zenith NDIX... can't wait to hear it running and dyno'd. _________________ 1192CC WW okrasa
