AlteWagen Troll
Posted: Wed Dec 11, 2013 9:12 am Post subject: Complete Guide to Performance VW Camshafts |
I often refer to this list for customer inquiries so thought this would be useful for others.
If you find any typographic errors or have additional specifications @ .050 please let me know and I will update the sheets ASAP.
edit: fixed CB data _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Wed Dec 11, 2013 10:34 am Post subject: |
| thats pretty good,I had another one but lost it in the big crash.I wonder why non of these charts have any of the crane or comp cams or other v8 grinders listed that did vw stuff in the old days(yes engle is a v8 grinder as is ersonn& some others,) crane did vw& porsche cams long ago. and also possiably made aluminum roller rockers,but they may of went to some special racers& not sold to the public. mr crane told me he didnt remember ever selling them to the public,so there are some sets out there somewhere...possiably.but probably all used up. |
gooser Samba Member
Joined: February 21, 2008 Posts: 766 Location: danville virginia
Posted: Wed Dec 11, 2013 10:45 am Post subject: |
| i also wonder why cb performance's famous cheater cam (2280) is not listed or is that not considered a performance cam? |
AlteWagen Troll
johnwesley Samba Member
Posted: Wed Dec 11, 2013 4:39 pm Post subject: |
| is there any info on the DRD cams? |
Joined: May 17, 2003 Posts: 4875 Location: Harmony, PA
Posted: Wed Dec 11, 2013 4:44 pm Post subject: |
The Crower Cams are slightly different from what they currently have on their site. They have; (lift at 1.1)
61002 int 260 220 0.375 110 ex 268 227 0.381 110
61000 int/ext 268 227 0.354 110
61003 int 276 234 0.398 107 ex 284 244 0.421 107
61004 int 284 244 0.424 107 ex 290 252 0.446 107
61005 int 290 252 0.447 107 ex 298 260 0.460 107
61006 int 298 260 0.462 107 ex 306 272 0.482 107
61007 int 306 272 0.481 107 ex 312 280 0.500 107
61002 Smooth idle. Great all around stock replacement cam. Super torque profile. RPM 1000-5000+
61000 Fair idle. Good bottom end profile with mid-range power. Emphasis on torque. RPM 1800-6000+
61003 Fair idle. Competition profile. Super torque and mid-range profile for 1600cc engines. RPM 2000-7000+
61004 Fair idle. High torque profile with emphasis on the top end for 1800cc engines and under. RPM 2500-7500+
61005 Fair idle. Broad mid-range and top end power for 2180cc engines and under. RPM 2500-7500+
61006 Fair idle. Broad mid-range and top end power for engines with increased compression. RPM 3000-8000+
61007 Rough idle. Strong mid-range and top end power for 2000cc engines or larger with increased compression. RPM 3500-8500+ |
slalombuggy Samba Member
Posted: Wed Dec 11, 2013 4:54 pm Post subject: |
there is a few of CB/Eagle on this page that you don't have. 2290, 2291,2295,2296 and 2297. Thanks for charting all this info. It's great to have it all in one spot and I know it must be a bit of work on all the data entry. Thanks for taking the time.
http://www.cbperformance.com/searchresults.asp?cat=195
brad |
AlteWagen Troll
neil68 Samba Member
Joined: March 17, 2007 Posts: 3453 Location: Calgary, Canada
Posted: Wed Dec 11, 2013 7:43 pm Post subject: more camshafts |
I've been using a JPM Raptor camshaft for a few years (the middle one below). These cams are designed to be run with less spring pressure at high rpm's. Here's their main list, but they also custom grind at various lobe angles, etc. Duration is at 1.27mm (0.050") and lift is at the cam lobe:
JPM01106 251° 10.00mm (0.394") 1.1-1.25:1
JPM01706 258° 9.57mm (0.377") 1.4-1.5:1
JPM00806 263° 9.64mm (0.380") 1.4-1.5:1
JPM01006 274° 10.35mm (0.407") 1.4-1.5:1
JPM06908 274° 10.80 mm (0.425") 1.4-1.6:1
JPM00206 280° 10.50mm (0.413") 1.4-1.5:1
JPM00406 282° 10.70mm (0.421") 1.4-1.5:1
JPM01306 287° 11.43mm (0.450") 1.4-1.5:1
JPM00906 293° 11.25mm (0.443") 1.45-1.6:1 _________________ Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
drumbum68 Samba Member
Posted: Thu Dec 12, 2013 8:21 am Post subject: |
| Cb 2251, 2252, 2253, 2254 are hydraulic cams. |
tncsparky Samba Member
Joined: November 29, 2008 Posts: 703 Location: santa rosa
Posted: Fri Dec 13, 2013 8:59 am Post subject: |
On the Norris Cams the advertised #'s are listed @020.
On the 336 it is 290@020 and 254@050
This page has good info on Norris stuff
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight= _________________ "My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
I think you are just waiting around for a high-five from a unicorn so you can feel better about yourself |
posada Samba Member
Joined: October 21, 2014 Posts: 4 Location: El Salvador
Posted: Tue Jun 05, 2018 7:40 pm Post subject: Re: Complete Guide to Performance VW Camshafts |
| friends can help me identify these cams codes |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
earthquake Samba Member
Joined: January 10, 2008 Posts: 4007 Location: SANDY VALLEY, NEVADA
Posted: Thu Jun 07, 2018 1:26 am Post subject: Re: Complete Guide to Performance VW Camshafts |
Don't forget about Schneider cams
http://schneidercams.com/solidliftercamshafts-18.aspx
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
-Alex77- Samba Member
Joined: December 09, 2008 Posts: 514 Location: Finland
Posted: Thu Jun 07, 2018 5:34 am Post subject: Re: more camshafts |
JPM; best cams in the industry
| neil68 wrote: |
JPM00906 293° 11.25mm (0.443") 1.45-1.6:1 |
_________________ Lasercut parts and CAD design |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11146 Location: Black Forest, CO
norris Samba Member
Posted: Thu Jun 07, 2018 9:24 am Post subject: Re: Complete Guide to Performance VW Camshafts |
While in this cam discussion has anyone an idea of who ground this one? I've look everywhere!
Olli from NJ Samba Member
Posted: Thu Jun 07, 2018 9:37 am Post subject: Re: Complete Guide to Performance VW Camshafts |
On the CB site it states that all of their cams are 107 lobe center. The above chart has a lot of them listed at 108.
Olli |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15605 Location: Deep in the 405
Posted: Thu Jun 07, 2018 9:51 am Post subject: Re: Complete Guide to Performance VW Camshafts |
I wish CB would redo their entire listings of cams. It is very difficult to understand what they offer and compare all their cams together to make a choice. I don't ever buy CB cams because the way they list them in groups is too difficult to navigate.
I hope Pat Downs reads this. CB website listing of their cams sucks. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Jun 07, 2018 11:06 am Post subject: Re: Complete Guide to Performance VW Camshafts |
| norris wrote: |
| While in this cam discussion has anyone an idea of who ground this one? I've look everywhere! |
I'm pretty sure it's a Schneider. There was a thread on that number a few weeks back if I'm not mistaken. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
