Complete Guide to Performance VW Camshafts
Page: Previous  1, 2, 3  Next
Brian_e Premium Member
Brian_e is offline
PostPosted: Thu Jun 07, 2018 11:37 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
vwracerdave wrote:
I wish CB would redo their entire listings of cams. It is very difficult to understand what they offer and compare all their cams together to make a choice. I don't ever buy CB cams because the way they list them in groups is too difficult to navigate.
I hope Pat Downs reads this. CB website listing of their cams sucks.
I agree. Good cams, but hard to wade through them on their site. This list makes it a little easier, but it is still missing some important numbers, and some of the cams listed dont jive with CB's site.
Brian
jpaull
jpaull is offline
PostPosted: Thu Jun 07, 2018 12:06 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
I started to do a Cam Chart in excel. You can sort by Cam lift, or any other drop down. I put in formulas to calculate all rocker sizes available based upon the cam lift. If anyone wants to finish and add all the cams, PM me and I can send the file.
Brian_e is offline
PostPosted: Thu Jun 07, 2018 1:13 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
That is genius jpaull. Exactly what is needed.
Click on the duration @ .05" and see all the cams available for your desired specs in one spot and compare them easily.
Well done.
Now someone with more time and computer smarts then me finish it for us!!
Applause
norris
norris is offline
PostPosted: Thu Jun 07, 2018 1:21 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
theKbStockpiler wrote:
norris wrote:
While in this cam discussion has anyone an idea of who ground this one? I've look everywhere!
I'm pretty sure it's a Schneider. There was a thread on that number a few weeks back if I'm not mistaken.
Could be, but I emailed it to Schneider and they said it wasn't theirs.
theKbStockpiler
theKbStockpiler is offline
PostPosted: Thu Jun 07, 2018 2:37 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
They have not made a post on STF in a long time but you could try to message them. If they state information in detail ,I doubt they don't know what they are talking about but maybe they misspoke.
http://shoptalkforums.com/memberlist.php?mode=view...fdcbd2e2df
Post on the cam is here:
http://shoptalkforums.com/viewtopic.php?t=93140
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Thu Jun 07, 2018 3:55 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
The FK10 does not match the catalog specs.
FreeBug
FreeBug is offline
PostPosted: Fri Jun 08, 2018 10:44 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
No mention of Engle's V-26, just Berg's version, the GB 309. Is it no longer relevant?
vwracerdave
vwracerdave is offline
PostPosted: Fri Jun 08, 2018 1:19 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
You can still get the V-26 directly from Engle.
costonjs
costonjs is offline
PostPosted: Sun Sep 09, 2018 7:58 pm    Post subject: Reply with quote
AlteWagen wrote:
Mark, if you have any of the crane, comp, crower, erson, clay, isky or any other old school grind numbers I will gladly add them
Thanks
i found this very old crane cam timing card in a box today. the cam is collecting dust on a bookshelf in the living room.
73 sport beetle blue 1745cc
74 sunbug grey 2016cc
roger29palms
roger29palms is offline
PostPosted: Tue Nov 13, 2018 3:56 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
I too have an old Crane Cam card.
I'll do my best to get things correct;
VW-282-NC clearance intake .04, ex. .06
intake @ CAM 360/407 with 1.13 ratio
exhaust @ CAM 360/407 with 1.13 ratio
cam timing @ .014 tappet lift intake opens 40 btdc, closes 62 abdc, 282 dur
exhaust opens 72 bbdc, closes 30 atdc 282 dur
cam timing @ .050 tappet lift intake opens 19 btdc closes 41 abdc 240 dur
exhaust " 51bbdc " 111 btdc 240 dur
No figures for Crane spring requirements or rpm figures given
Part # 760-0014
Dougy Dee
Dougy Dee is offline
PostPosted: Tue Nov 13, 2018 4:46 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
The .050 EC number doesn't work. Too many 1's. Using 10 or 11 the math works. Smile
Part # 760-0014
itsawesty
itsawesty is offline
PostPosted: Sun Oct 13, 2019 6:42 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
What does small, medium and large displacement really mean in cc for air cooled VW engines?
'59 Ghia build thread https://www.thesamba.com/vw/forum/viewtopic.php?t=737729
'73 Westy
'90 Scirocco
2003 911
www.hertfordshirevehiclestorage.com
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Sun Oct 13, 2019 8:42 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
I’m thinking you are inquiring more tward the larger sized Type 2/4 engines of the later Bay Buses from your user name/avatar, but this thread is more along the lines of the Beetle/Type 1 engines. As far as they are concerned; imo small is 1915cc’s or less, medium is 1956-2110, and large is 2180-2386. These are the most common. There are 2442’s, 2498’s, and even 2789’s but the cost of the cranks, piston/cyl sets, case, and heads able to utilize the extra cc’s grow exponentially in price.
Maybe someone else can elaborate on the 2 liter based Bay Bus engines?
itsawesty
PostPosted: Sun Oct 13, 2019 10:58 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
thanks, i was curious to know what the 2276 i have going in my lowlight would be categorised as.
'73 Westy
'90 Scirocco
2003 911
mood
mood is offline
PostPosted: Mon Mar 23, 2020 11:33 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
That looks like a Bob Walters Dial-in-Cam. I have one in my engine and I also couldn't find anything online about it. You can find Dial-in-Cam advertisements in Hot VWs or VW trends magazines from the mid to late eighties. The ad I remember was for inline-4 VW water-cooled engines and won't help you decode your cam.
norris
norris is offline
PostPosted: Tue Mar 24, 2020 5:58 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
Thanks mood....welcome to the samba!
norris
Oops....you’ve been here a while. Like me you just don’t “say” much 😉
norris
norris is offline
PostPosted: Tue Mar 24, 2020 6:03 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
norris
Ohio Tom
Ohio Tom is offline
PostPosted: Tue Mar 24, 2020 11:13 am    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
the Autocraft 9526: The 297deg is at .050" lift. (not advertized).
It is a pro-stock cam.
Powerband from 5,500-10,000rpm.
Todd Getty
Todd Getty is offline
PostPosted: Tue Jul 21, 2020 4:03 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
Hello, I realize this thread is old but wondering if anyone is out there to help identify another random cam and/or crank maker(s)?
I recently cracked open a "mystery engine" finding a lot of nice parts inside but cannot identify the crank or cam makers.
Engine was a 84x94, blow through dual dellorto 40mm carbs. 84mm crank was welded & offset ground based on a late model type one crank w/ VW and Audi stampings. It has "ECS 84" stamped on end counterweight and it's also wedgemated to a stock weight flywheel (STD/STD perfect condition).
The hydrolic cam has "4 6853 / P 7" stamping. I marked the lifters order prior to splitting the case, their faces look smooth and reusable and cam lobes do too. I believe the lifters are Chevy type as the lifter bores in case are way oversized plus 6x center shuffle pins, full flowed, drilled and tapped oil galleys & welded behind #3 = "super case" as we used to call them. It had 1:4 rockers and .300" super thick shims under the Mahle barrels. Heads are mismatched, assuming one melted down and was replaced at some point: clearly different combustion chamber volumes and shapes from one head to the other...
Planning on alignbore, all new bearings, new heads and bolting it back together BUT would really like to know more about the cam or crank.
Thank you guys!
Todd in Portland OR.
TinCanFab
TinCanFab is offline
PostPosted: Tue Jul 21, 2020 5:03 pm    Post subject: Re: Complete Guide to Performance VW Camshafts Reply with quote
When I hear large displacement/hydraulic cam, Bernie Bergmann comes to mind. His magazine ads had a lot of flashy stuff in them, like bright colored engine tins and Porsche fan shrouds,full circle cranks, etc....
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
Page 2 of 3
