Newer, larger kitchen drawer in older van?
sphet
sphet is offline
PostPosted: Tue Apr 10, 2018 10:05 pm    Post subject: Newer, larger kitchen drawer in older van? Reply with quote
I am envious of the larger drawers on the later westfalias. Has anyone attempted to retrofit this into an older van? I'm thinking of trying to build up a drawer myself from scratch since I am tired of not having enough knife storage.
1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee
jimf909
jimf909 is offline
PostPosted: Tue Apr 10, 2018 11:39 pm    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
What model years are these earlier and later vans that you’re referring to? My 85 and 90 both have u-shaped drawers that are not large or awesome.
For knife storage, I sure do like a magnetic knife holder screwed to the hinged lid above the stove/sink. Mine holds theee knives, a bottle opener and another thing or two (sorry, no pics at this time).
- Jim
Butcher wrote:
Guilty as charged.
sphet
sphet is offline
PostPosted: Tue Apr 10, 2018 11:43 pm    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
For knife storage, I sure do like a magnetic knife holder screwed to the hinged lud above the stove/sink. Mine holds theee knives, a bottle opener and another thing or two (sorry, no pics at this time).
I've got an 82 and its a tiny rectangle that holds two sets of cutlery and a knife. It's ridiculous. I suspect it changed in 85.
jimf909
jimf909 is offline
PostPosted: Tue Apr 10, 2018 11:50 pm    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
Ive also seen magnetic knife holders on the inside of the cabinet door below the sink. I think part of the solution is going beyond that drawer because it's constrained by the sink/drain.
FWIW, YMMV.
- Jim
Butcher wrote:
Guilty as charged.
kamzcab86
kamzcab86 is offline
PostPosted: Wed Apr 11, 2018 12:21 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
Edit: Nevermind. Embarassed Just learned that the early drawers are not U-shaped, like the later drawers.
~Kamz Anxious
2016 Golf GTI S
82westyrabbit
82westyrabbit is offline
PostPosted: Wed Apr 11, 2018 4:30 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
My 82 westy has the smaller drawer with out the legs going back. Gowesty has the larger drawers for sale. I think the drawers are the same width and you could modify it to fit. I have not done it myself but I am shore some one will chime in who has. You might have to modify the sink drain. Good luck
MarkWard
MarkWard is offline
PostPosted: Wed Apr 11, 2018 4:50 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
I swapped out the drawer on our 82. The longer drawer just slid in. No modifications required.
danfromsyr
danfromsyr is offline
PostPosted: Wed Apr 11, 2018 6:21 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
modify the stove face with a knife drawer
from this thread https://www.thesamba.com/vw/forum/viewtopic.php?t=507102
juanb wrote:
With the prospect of spending a year in the van, I'm in the mindset of using every available bit of space.
The following is is an idea that I've had for a while, and finally this weekend was able to make it happen. I thought about this while looking at the very helpful disassembly pictures that davideric9 posted to this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=334649
If you look at the area left of the burners, there is some empty space in there:
The back of it is ventilation for the fridge, but we're not going to go so far that it matters.
The first thing I did, because I know my craftmanship can be laughably bad, was to procure an extra stove front plate. I got it from the classifieds, I think it was $25 or so:
Then I marked how far I wanted to go, and attacked it with a jigsaw:
My strategy is usually "measure once, cut three times". Make sure to never hire me for anything that doesn't have an undo button Smile
I went to Home Depot, and after a couple of hours of looking of inspiration, I settled on this thing, it's a roof gutter of some sort. What mattered to me was that it is metal, it has a 90 degree bend alongside, and one of the sides is about 2 inches tall:
By making cuts on the longer side and bending it I built this box, which is about 12"x4":
Not pictured here, but I epoxyed it in place, and left it clamped overnight.
I made a wooden front, which I sanded until it fit snugly in the stove front. Here they are, pictured in my paint booth:
After a couple of coats. I painted the table legs as well.
When the paint was dry, I attached the front to the drawer using a handle that screws from behind, and then lined the drawer with some black rubber material so the stuff inside doesn't rattle too much. I also put some of that low friction tape that I used on the slider door, on the bottom and edges of the drawer.
Voila, a new cutlery drawer:
Now I can use the main drawer under the sink for other stuff. I'm not too worried about heat, this is relatively far from the flame, separated by two layers of metal, plus my drawer itself is metal. So I should be ok.
The paint I used was Rustoleum Satin Granite, it is here if you scroll down a bit:
http://painting123.com/ProductInfo.asp?p2=I7
It's a bit darker than stock, but I don't mind it. My bad craftmanship shows a little bit, but it isn't too bad. And when compared to my stock stove plate, it is a noticeable improvement. The old plate had that greenish grey color that most original westy stoves have by now.
Here it is closed:
Abscate wrote:
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Apr 11, 2018 6:41 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
sphet wrote:
...I suspect it changed in 85.
My 84 has the later drawer - possibly the change coincided with the WBX at 83½.
shagginwagon83
shagginwagon83 is offline
PostPosted: Wed Apr 11, 2018 6:54 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
83½ here, I have short drawer. I would swap - but imagine how much a good, used brown drawer is going to cost.
SCM
SCM is offline
PostPosted: Wed Apr 11, 2018 8:10 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
If I was in the OP's shoes I'd be looking for one of the later model drawers too. But here's another idea for knife storage. Super easy to build if you have a table saw with a dado blade.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
sphet
sphet is offline
PostPosted: Mon Jun 18, 2018 11:10 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
I thought I would wrap up this post with my findings. I was able to buy a later-model drawer that matches the colours of my early van. It slid in just fine but the latch did not work. I measured it a bit and the latch is installed an 1/8 of an inch higher on the new drawer. There is also a noticeable recess in the rubber trim on the old one. I ended up cutting back the trim on the new drawer to match the old, and unscrewed, slightly bent and then re-installed the metal catch to make up the 1/8 of an inch. It's almost perfect but then the old drawer was always a bit finnicky anyways. My one thought is that I expect the slides installed on the inside of the cabinet probably extend back much farther in the late vans -- but since i store my anvils in the luggage rack and not in my cutlery drawer I doubt this will be a problem.
Comparison of the two styles -- look at that extra space for losing things!
The new later-model drawer
The earlier one with the recess cut into it.
spitsnrovers
spitsnrovers is offline
PostPosted: Mon Jun 18, 2018 12:35 pm    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
By modifying the sink drain to a smaller elbow, that "U" can be avoided. Photos of the back of the drawer here, down near the end:
http://www.griffco.ca/interest/vw/vwshower.htm
'88 VW Westfalia
'75 Triumph Spitfire 1500
81 Westy
81 Westy is offline
PostPosted: Sat Apr 16, 2022 11:52 pm    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
I am hoping to build the U shaped drawer to replace my '81 tiny drawer. Any chance you could send me the dimensions on the U shaped drawer to facilitate or ease my project?
Much Appreciated!!!
Ron
vanis13
vanis13 is offline
PostPosted: Sun Apr 17, 2022 11:33 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
Link did not work. I think it's this one
http://www.griffco.ca/VW/vwshower.htm
Keep in mind that they don't use the sink and three sprayer comes up through the drain. A similar solution for the drain could be created.
VeeDubn
VeeDubn is offline
PostPosted: Sun Apr 17, 2022 1:45 pm    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
1980 Westy - we modified our silverware drawer; added drawer slides too.
Pchill2
Pchill2 is offline
PostPosted: Mon Apr 18, 2022 9:14 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
VeeDubn wrote:
Any other pictures of your interior? I'm intrigued...
87 Syncro Westy
Honda K24 swap
VeeDubn
VeeDubn is offline
PostPosted: Mon Apr 18, 2022 8:43 pm    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
Pchill2 - Additional pictures of our interior . . .
Pchill2
Pchill2 is offline
PostPosted: Tue Apr 19, 2022 5:26 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
Love it!
PM'd you (I don't want to railroad this thread with questions)
87 Syncro Westy
Honda K24 swap
spitsnrovers
PostPosted: Tue Apr 19, 2022 7:27 am    Post subject: Re: Newer, larger kitchen drawer in older van? Reply with quote
Thank you Vanis13 for updating my old link. I tried to edit that post, but was a long way too late! Embarassed
'88 VW Westfalia
