Valve Springs for setting up Rocker Geometry
msaltz
msaltz is offline
PostPosted: Thu Aug 02, 2018 6:59 pm    Post subject: Valve Springs for setting up Rocker Geometry Reply with quote
When setting up/adjusting rocker geometry using an adjustable push rod is there a weaker valve spring that should be installed? If so does anybody have a source for where to get them? Any insight would be greatly appreciated.
vwracerdave
vwracerdave is offline
PostPosted: Thu Aug 02, 2018 8:44 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
I bought a couple of $2.00 springs at the local hardware store that were about the size of a VW valve spring and I could compress with my fingers. Jeg's and Summit also sell checking springs.
vince1
vince1 is offline
PostPosted: Fri Aug 03, 2018 12:32 am    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
I use stock Type 4 rockers end play springs.
Those are nice because you can also push the valve on the piston top to check clearances when mocking the engine.
my French blog https://vwpanelvan.wordpress.com/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ... Wink
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
msaltz
msaltz is offline
PostPosted: Fri Aug 03, 2018 2:57 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
Thanks for the info. Never thought of checking the hardware store. I'll check there first and see what they have.
The type 4 rocker end play springs do look like the ticket though.
UK Luke 72
UK Luke 72 is offline
PostPosted: Sat Aug 04, 2018 3:46 am    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
I use a spring off a set of spring loaded push rod tubes.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
FreeBug
FreeBug is offline
PostPosted: Sat Aug 04, 2018 10:29 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
In a pinch you can wrap coat hanger wire around a piston pin. Works.
Sharp64
Sharp64 is offline
PostPosted: Sun Dec 29, 2019 11:20 am    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
Tried searching and couldn’t find the answer. But what is the reasoning behind using a softer spring when setting geometry? Is it due to using the adjustable rod?
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
67rustavenger
67rustavenger is offline
PostPosted: Sun Dec 29, 2019 11:26 am    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
The softer spring is used to set the rocker geo. Without having to use the cam and lifters to move the rocker arm.
Basically you can get the geo set with the head off the engine when using the soft springs. I got my soft springs from Ace Hardware.
After the geo is set. You install the head and figure out the correct PR length.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
FreeBug
FreeBug is offline
PostPosted: Sun Dec 29, 2019 11:46 am    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
Good Luck.
Is the wire clip hole offset like that on purpose?
67rustavenger
PostPosted: Sun Dec 29, 2019 11:51 am    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
Good Luck.
The heads are Tim's stage 2. They came that way and the bails give the correct tension on the valve covers.
I can only imagine that the Tim's measured the distance to get the bail over the valve cover. Before the hole was drilled.
Buy Once, Cry Once!
mark tucker
mark tucker is offline
PostPosted: Sun Dec 29, 2019 12:00 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
my old pop up sprinklers have awesome stainless steel springs in them that are perfect. a spring is a spring if it will fit it will work.small dia or large as long as it 1 stays on the retainer,2 dosent coil bind. 3 has enough force& length to hold the valve closed.
bugguy1967
bugguy1967 is offline
PostPosted: Sun Dec 29, 2019 9:05 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
You get better results because your pushrod doesn't flex, the engine stays put when you turn it to a certain position instead of the spring pushing back, you can play with adjustments easily, you don't have to worry about the tension pushing your rocker sideways thus loosing lift, and other things. I was just outside doing geometry for my new engine. With my soft checking spring, I was able to push the retainer down, pull my lash cap and continuously check the swipe.
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Sun Dec 29, 2019 9:13 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
That's a good idea. Cool
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
View user's profile Send private message Send e-mail YouTube Gallery Classifieds Feedback
Onceler
Onceler is offline
PostPosted: Sun Dec 29, 2019 10:19 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
Good Luck.
I’m currently trying to set geometry and admit I’m a bit of a moron, but how are you able to set geometry without installing cam and lifters and adjustable pushrod? I’d appreciate any tricks, cause this sucks
1972 Karmann Ghia
67rustavenger
PostPosted: Sun Dec 29, 2019 10:36 pm    Post subject: Re: Valve Springs for setting up Rocker Geometry Reply with quote
Here's a thread on the topic. Read it all the way through! It'll make sense in the end.
https://www.thesamba.com/vw/forum/viewtopic.php?t=706356&highlight=
If you are trying to use the slipper type of rockers. You likely need to shave the rocker arm blocks (the ones on the rocker arm shaft. Not the head) 0.060".
I did mine on a belt sander and measured frequently as I shaved them to get the geo correct.
Good Luck.
Buy Once, Cry Once!
