Steering Wheel Paint
spacebiscuit
spacebiscuit is offline
PostPosted: Fri Aug 03, 2018 5:08 am    Post subject: Steering Wheel Paint Reply with quote
Is there a particular paint to use when spraying a steering wheel? my fear is that the paint will come off since it will be in contact with the drivers hands, or should a well cured spray paint be fit for purpose.
1972 Type 2 1600cc
1990 MKII Golf 1.6 CL
SGKent Premium Member
SGKent is offline
PostPosted: Fri Aug 03, 2018 7:59 am    Post subject: Re: Steering Wheel Paint Reply with quote
why are you painting the steering wheel?
spacebiscuit
PostPosted: Fri Aug 03, 2018 8:02 am    Post subject: Re: Steering Wheel Paint Reply with quote
Some cracks were repaired with a white resin and sanded back smooth.
Plus I have restored the entire dash and it is shiny new and my ICD is taking over Smile
1972 Type 2 1600cc
vocho_702
vocho_702 is offline
PostPosted: Fri Aug 03, 2018 8:28 am    Post subject: Re: Steering Wheel Paint Reply with quote
I am also curios about this, but I think that whatever is on the wheels is not paint. It seems to be more like a plastic dip or like you said resin. But I also don't see why a good prepped paint job wouldn't stay on there for a long time. No expert here though, just a thinker.
Life is short, enjoy the ride...in a VW
69 Sunroof Beetle-AirheadParts Treffen 18
DD-70 Baywindow Camper-AirheadParts Treffen 21
spacebiscuit
PostPosted: Fri Aug 03, 2018 8:33 am    Post subject: Re: Steering Wheel Paint Reply with quote
Yes agreed - I am not entirely sure that it is painted and the last thing i want to do is ruin an otherwise decent steering wheel hence my question. Curious to know how it is finished....
1972 Type 2 1600cc
SGKent is offline
PostPosted: Fri Aug 03, 2018 8:34 am    Post subject: Re: Steering Wheel Paint Reply with quote
you can try cleaning it with lacquer thinner, spray Bulldog on it then SEM GM Black. Repeat the Bulldog and Sem GM Black vinyl spray. That is how I painted the dash after speaking with the local car paint supplier. It holds up well.
spacebiscuit
PostPosted: Fri Aug 03, 2018 8:36 am    Post subject: Re: Steering Wheel Paint Reply with quote
Just found this:
About Wheels
http://www.thebugshop.org/bsfqstrg.htm
A few things worth mentioning, some obvious some not. A steering wheel is made of a steel core around which a plastic is formed and molded. Like the other stuff in your (old) car, it has to withstand extreme environmental conditions, notably temperature extremes that repeatedly expand and contract the wheel. And as the plastic and steel expand at different rates relative to this invariably cracks the wheel plastic.
Regarding what kind of paint to use on the wheel, keep this in mind: the steering wheel is clearly the single most "handled" part of the car. Many vintage enthusiasts know that Krylon "Ivory" spray paint is a dead ringer for the VW Ivory (L567), but rattle can enamel is not going to hold up to the rigors of a steering wheel's life (at least if the car is driven). VW used lacquer but urethane is a better choice today in my opinion.
And just as trying to tear off a split fingernail with your other hand will all but guarantee that it will tear down into the nail bed and not across the top like you want it to (and hurt!), cracks in steering wheels never go across the smooth, flat face portions of the wheel. They find their way across the bumpy, detailed, ribbed sections of the wheel like a heat sinking missile.
1972 Type 2 1600cc
aeromech
aeromech is offline
PostPosted: Fri Aug 03, 2018 8:49 am    Post subject: Re: Steering Wheel Paint Reply with quote
Knowledge dump:
I've refurbished several steering wheels. I've always started with a wheel that wasn't in terrible shape. The hub area needs to be pretty well intact in my opinion.
I use a pencil grinder to route out the cracks and then fill them with a two part epoxy putty that sets up hard within a couple hours. Then finish sand and prime.
I used a two part primer here
Finally I apply the top coat which in this case was a three part automotive paint
I don't worry too much about the outer ring because I always install a wheelskins leather wrap
To make things simpler, a person might try one of these paint kits from Amazon. Get the gloss or flat black color
https://www.amazon.com/DuraCoat-Shake-Spray-Kit-Color/dp/B01GNZRYAE
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
spacebiscuit
PostPosted: Fri Aug 03, 2018 9:00 am    Post subject: Re: Steering Wheel Paint Reply with quote
Awesome job - just what I was looking for
1972 Type 2 1600cc
spacebiscuit
PostPosted: Fri Aug 03, 2018 9:09 am    Post subject: Re: Steering Wheel Paint Reply with quote
What is a 2 part primer? Does this have additional chemical added?
1972 Type 2 1600cc
aeromech
aeromech is offline
PostPosted: Fri Aug 03, 2018 9:23 am    Post subject: Re: Steering Wheel Paint Reply with quote
Epoxy. Two parts that you mix
https://www.sherwin-automotive.com/fleet-refinishi...e-primers/
If I was going to do this I'd start here and read
http://www.duracoat-firearm-finishes.com/
You should be able to find both a primer and a top coat that will be tough
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
vocho_702
PostPosted: Fri Aug 03, 2018 9:26 am    Post subject: Re: Steering Wheel Paint Reply with quote
Just as I thought, a well prepped and painted, with good materials job should do the trick. Thanks Aeromech, for that perfect example. I am gonna give it a shot as well now that I have this knowledge “dumped” on me! Very Happy I would also like to see how you refiinished the dash, SGKent, as mine is looking pretty worn out. Thanks a ton folks, I appreciate every bit of info.
spacebiscuit
PostPosted: Sat Aug 04, 2018 1:32 am    Post subject: Re: Steering Wheel Paint Reply with quote
I'm glad that I posted the question. I was considering using a regular matt black out of a spray, sure it may have looked nice but I am sure within a few days I'd be left with more paint on my hands than the wheel"
1972 Type 2 1600cc
Amskeptic
Amskeptic is offline
PostPosted: Sun Aug 05, 2018 5:49 pm    Post subject: Re: Steering Wheel Paint Reply with quote
I painted my steering wheel back in 2015, then drove it for 33,000 miles:
It's a no. Still looks OK, but feels horrible in the humid heat. Acids from your hands attack the paint, even engine enamel, which is what I used.
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
Sven F
Sven F is offline
PostPosted: Mon Aug 06, 2018 3:39 am    Post subject: Re: Steering Wheel Paint Reply with quote
Use two component epoxy putty to fill in cracks (not body filler, it will crack)
Wetsand whole wheel in 400 or 600 grit
Use a silicone remover/degreaser because plastic/backelite absorbs all those oils from your hands.
Use plenty of plastic primer (not regular primer you use for sheet metal!!!) This is what bodyshops use on plastic bumpers on modern cars, it's usually transparent with a metallic shine. Without this step, the paint will peal off 100% certain.
Use automotive paint of your choice. Let paint cure for a week.
Do not use aerosol spray cans for any of the steps, only a paint gun. Aerosol paints are unstable, they never cure properly and are sensitive to chemicals, it will turn to a goey, sticky mess.
Following these steps the paint will never come off with regular use or become sticky, but if you wear metal jewelry on your hands while driving, you will eventually scratch the surface.
74 Thing
74 Thing is offline
PostPosted: Mon Aug 06, 2018 6:46 am    Post subject: Re: Steering Wheel Paint Reply with quote
I second the Wheelskins leather steering wheel wrap when you are done!
Don't use spray enamel for the top coat. Use a good 2 part urethane. You can now get them in spray cans with the activator in the bottom portion (the cans run around $25 each and are a one time use). Make sure you wear proper breathing protection if using these 2 part paints.
Jalabert
Jalabert is offline
PostPosted: Thu May 07, 2020 12:39 pm    Post subject: Re: Steering Wheel Paint Reply with quote
I'm having difficulty finding the wheelskins cover online or in NZ. I'm contemplating stitching two small leather covers together at the spokes - does that sound like a dreadful idea? Hard to tell exactly how the joins are dealt with.
I'm looking at this for painting the wheel, seems to be the most likely solution that's locally available.
https://www.duplicolor.com/product/vinyl-and-fabric-coating/
'73 westy, 1700 type 4 with 34icts
tractoman
tractoman is offline
PostPosted: Thu May 07, 2020 12:45 pm    Post subject: Re: Steering Wheel Paint Reply with quote
Order direct from their web site. I just got one but am only 30 miles away from their Berkeley location.
Mike
'75 Westy
ivwshane
ivwshane is offline
PostPosted: Thu May 07, 2020 1:40 pm    Post subject: Re: Steering Wheel Paint Reply with quote
I wonder if a low temp powder coat would work. The steering wheel would need to withstand 300°/15 minutes or 280°/30 minutes.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
SGKent is offline
PostPosted: Thu May 07, 2020 2:46 pm    Post subject: Re: Steering Wheel Paint Reply with quote
it is plastic. Do so at your own risk.
