oibovveroi Samba Member
Posted: Thu Aug 02, 2018 10:32 am Post subject: Current stock muffler options? |
Are the ill fitting dansk the best stock option? That’s about all I’m seeing at the usual online parts supply. |
vwoldbug Samba Member
Posted: Thu Aug 02, 2018 12:52 pm Post subject: Re: Current stock muffler options? |
There is a NOS Leistritz made in W. Germany in the classifieds to check on . |
Posted: Thu Aug 02, 2018 1:36 pm Post subject: Re: Current stock muffler options? |
vwoldbug wrote: |
The 40hp exhaust is compatible to the 1600DP?
Please excuse my ignorance |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Thu Aug 02, 2018 1:48 pm Post subject: Re: Current stock muffler options? |
no, 40 HP are narrower. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked  |
hanksjim1 Samba Member
Joined: October 03, 2014 Posts: 87 Location: PNW, USA
Posted: Thu Aug 02, 2018 3:27 pm Post subject: Re: Current stock muffler options? |
The Leistritz come up regularly on ebay for ~$100. I bought several. |
bluebus86 Banned
Posted: Thu Aug 02, 2018 9:16 pm Post subject: Re: Current stock muffler options? |
oibovveroi wrote: |
Ill fitting is a very bad option, an old used correct fitting one is better. dont settle for ill fitting.
Bug On. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Thu Aug 02, 2018 9:18 pm Post subject: Re: Current stock muffler options? |
60ragtop wrote: |
no, 40 HP are narrower. |
yes, short stroke verses long stroke cranks change over all motor width, hence side to side distence between the heads and their exhaust ports. the 40 horse had a shorter stroke.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Aug 02, 2018 11:49 pm Post subject: Re: Current stock muffler options? |
Is there a difference between one online dealers $75. Dansk and the other $135 dansk muffler?
I have a German one. But it’s from the 70s maybe early 80s and very crusty. No holes, but I don’t know if it still has any inerds left. |
Posted: Fri Aug 03, 2018 12:02 pm Post subject: Re: Current stock muffler options? |
The ad I speak of is in the 1968 and up section . I did a search for muffler in the 1968 parts section . The sticker on the muffler says 1300 cc to 1600 cc . I do know a 40 hp muffler won't fit a 1600 engine . |
Joined: August 31, 2013 Posts: 13302 Location: North Carolina
Posted: Fri Aug 03, 2018 2:01 pm Post subject: Re: Current stock muffler options? |
I just installed a Bosal unit, great fit, sounds a bit throatier than an original German one but still gets a bit of that original "fweem" under acceleration. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Cheburashka Samba Member
Posted: Fri Aug 03, 2018 6:36 pm Post subject: Re: Current stock muffler options? |
Just got a Dansk in the mail. I don't know what people are complaining about. The parts lined up pretty well.
Of course, that took a little persuasion. . .
And quite a bit of heat and brass.
[/img]
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3342 Location: Memphis
Posted: Fri Aug 03, 2018 9:02 pm Post subject: Re: Current stock muffler options? |
Cheburashka wrote: |
I just don't believe anyone should have to do THAT MUCH work to an exhaust to get a good fit.. straight out of the box. I bought a Dansk exhaust for my early bay and it was the same way. It needed too much work and I was never happy with how my engine performed with it on there. My biggest pet peeve is the fresh air pre-heaters. They were so far off that I finally had to yank them out altogether and run the fresh air tubes straight to the heater box. I even tried to use the preheaters from a stock VW muffler, but the pipe shape and geometry is different enough that they wouldn't go on the aftermarket exhaust at all.
There are no good stock options that I personally know of. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11787 Location: Redding, CA
Posted: Sun Aug 05, 2018 3:26 pm Post subject: Re: Current stock muffler options? |
I just checked out the reviews on the Bosal muffler. It seems that TDC may be into something. The manufacturer brags about the perfect fit. They also mention quality, too; but a good fit is a good start.
So ... when the time comes, I’m going to give the Bolton a shot. It certainly can’t be worse than Dansk, and it might deliver the quality and fit the mention.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien
Last edited by Tim Donahoe on Sun Aug 05, 2018 11:19 pm; edited 2 times in total |
AlmostHeavenWV_VW Samba Member
Posted: Sun Aug 05, 2018 3:31 pm Post subject: Re: Current stock muffler options? |
TDCTDI wrote: |
I just installed a Bosal unit, great fit, sounds a bit throatier than an original German one but still gets a bit of that original "fweem" under acceleration. |
RockAuto's got those:
https://www.rockauto.com/en/moreinfo.php?pk=1080376&cc=1368851&jsn=387 _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
sb001 Samba Member
Joined: May 19, 2011 Posts: 10458 Location: NW Arkansas
Posted: Sun Aug 05, 2018 6:22 pm Post subject: Re: Current stock muffler options? |
Just a simple question I'm wondering...
Why are all the aftermarket mufflers' preheat tubes for the heat riser on the opposite side as the original VW?
They are all on the right side, the original VW was on the left:
_________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Sun Aug 05, 2018 7:19 pm Post subject: Re: Current stock muffler options? |
sb001 wrote: |
Maybe the switch was to consolidate the manufacturing lines of the mufflers once the Mexican Beetle got the spin-on filter oil pump? I know that pump/filter combo won't clear the left-hand preheat tube, maybe VW just began making all of the mufflers with it on the right to avoid having two different parts being made? and the aftermarket followed suit as well?
Just a guess _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Posted: Sun Aug 05, 2018 8:50 pm Post subject: Re: Current stock muffler options? |
FWIW, that tube is actually the return. On the pictured exhaust, the manifold actually gets it’s heat from the port directly on the #2 exhaust flange, it then flows through the heat riser then through that tube to return to the exhaust flow at the lower pressure side of the exhaust system. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
sb001 Samba Member
Posted: Sun Aug 05, 2018 9:40 pm Post subject: Re: Current stock muffler options? |
TDCTDI wrote: |
FWIW, that tube is actually the return. On the pictured exhaust, the manifold actually gets it’s heat from the port directly on the #2 exhaust flange, it then flows through the heat riser then through that tube to return to the exhaust flow at the lower pressure side of the exhaust system. |
Aah.
So then would it make any difference that the return tube is on the opposite side on all these aftermarket units? _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Mon Aug 06, 2018 4:08 am Post subject: Re: Current stock muffler options? |
sb001 wrote: |
TDCTDI wrote: |
Aah.
So then would it make any difference that the return tube is on the opposite side on all these aftermarket units? |
No sir, the manifold just needs one side to have a higher pressure on one side so that the exhaust wants to flow through it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
