Big feet...
SiRJoZ
SiRJoZ is offline
PostPosted: Tue Aug 14, 2018 6:59 pm    Post subject: Big feet... Reply with quote
So moving on to my next task...
1970 bug. The pedals are not exactly designed for my big feet. Is there a solution to creating more space between the pedals so I can avoid hitting the brake and gas at the same time?
Surely someone else here has big feet and has dealt with this...
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Tue Aug 14, 2018 7:04 pm    Post subject: Re: Big feet... Reply with quote
Classified section lists vendor that sell big foot pedal clusters
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Aug 14, 2018 7:15 pm    Post subject: Re: Big feet... Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=1340666
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Cali_Army_Guy
Cali_Army_Guy is offline
PostPosted: Tue Aug 14, 2018 7:30 pm    Post subject: Re: Big feet... Reply with quote
It’s cool, but doesn’t solve the issue the OP is having. This moves the distance between the brake and clutch. Doesn’t mention anything about the distance between the gas and brake. I have the same issue when I wear my work boots (size 13) and drive my ‘66. I’ll catch part of the gas pedal when braking.
2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold
PostPosted: Tue Aug 14, 2018 7:38 pm    Post subject: Re: Big feet... Reply with quote
Try the roller pedal it works
Cali_Army_Guy
PostPosted: Tue Aug 14, 2018 8:43 pm    Post subject: Re: Big feet... Reply with quote
I have one. When I’m wearing boots I’ll still manage to hit both every so often during a drive.
Tim Donahoe
Tim Donahoe is offline
PostPosted: Wed Aug 15, 2018 12:13 am    Post subject: Re: Big feet... Reply with quote
Hm? Don’t wear boots.
Tim
Let's do the Time Warp again!
Richard O'Brien
Ovally
Ovally is offline
PostPosted: Wed Aug 15, 2018 2:06 am    Post subject: Re: Big feet... Reply with quote
If you have the none cast pedals, you can try to bend them a little, maybe with a maximum of 1/4 to 1/2 inch.
No ideal solution, another possibility is to have the pedal cluster modified.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
mrmdls
mrmdls is offline
PostPosted: Wed Aug 15, 2018 2:35 am    Post subject: Re: Big feet... Reply with quote
I don't have wide feet however, I have the same issue when I wear running shoes when I drive my bug. I found that wearing boat shoes, or older style (canvas) sneakers, I don't have the issue of my shoe hitting both pedals.
75 model 110 (Basic Bug) - Project Daily Driver
sjbartnik
sjbartnik is offline
PostPosted: Wed Aug 15, 2018 8:20 am    Post subject: Re: Big feet... Reply with quote
Learn heel & toe technique. Very Happy
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
JCrimson
JCrimson is offline
PostPosted: Wed Aug 15, 2018 8:45 am    Post subject: Re: Big feet... Reply with quote
I have the same issue with certain shoes. I wear a size 12/13 depending on the shoe and have wider feet.
Often i'll wear shoes like Toms when driving the bug. They're canvas/cloth, they're light, and i have more of a feel of the pedal.
Sometimes I'll drive it while wearing flip flops, but those are almost always too big, so i'll drive barefoot. And before anyone says that its illegal, that is a myth.
1974 Super Beetle
hitest
hitest is offline
PostPosted: Wed Aug 15, 2018 9:39 am    Post subject: Re: Big feet... Reply with quote
I don't have oars for feet- but revisit the idea of the cluster that moves the clutch over...
You'll learn how to occupy more space with your brake foot. You'll enjoy that extra wiggle room-as it becomes muscle memory when you lift your foot off the accelerator and use the brake. Likewise you'll learn how to slip your toes partially under the brake to work the gas.
I'm certain in a couple weeks you won't remember having the problem. The wide cluster really does allow relief with your gas pedal. I am not a paid spokesman. Cool
FU#5
mark tucker
mark tucker is offline
PostPosted: Wed Aug 15, 2018 2:54 pm    Post subject: Re: Big feet... Reply with quote
you can do like I did and cut off part of your foot Shocked .... I dont see what a roller peddell will do fer ya..I dont like them any way..you can also bend the brake peddell over a tad...if your carfull..and do it right..(you dont want it folding up when the breaks are applied!!), my car has type 3 peddels in it(well thats what Ive been told they are...I dont know if they have more or less room.
Starbucket
Starbucket is offline
PostPosted: Wed Aug 15, 2018 3:42 pm    Post subject: Re: Big feet... Reply with quote
Hose clamp a 2" square of rubber 1 1/2" thick to the top of the peddle and the brakes will engage before you reach the gas peddle.
ElskanTriumph
ElskanTriumph is offline
PostPosted: Sat Jun 14, 2025 6:14 am    Post subject: Re: Big feet... Reply with quote
Late to the party, but this guy bends them. Is there a reason NOT to do this? I'm thinking about it when I change the gas pedal to a harder one later this summer.
https://youtu.be/pdjTXeyb6rU?feature=shared
