Kick down switch on a 70 FI auto FB questions
Kanester
Kanester is offline
PostPosted: Wed Aug 29, 2018 9:14 am    Post subject: Kick down switch on a 70 FI auto FB questions Reply with quote
Can someone post a picture of the wires that connect to the kick down switch on a 70 FI auto FB? Or tell me what color wires are supposed to connect to it? Does one connect to the trans?
Where can I source a new switch? Mine is beyond repair.
I have a thin red wire coming from the main harness thats not connected to anything yet. It's routed with the oil pressure wire. I also have a thin black wire coming from the starter wiring that doesn't have a home either.
I managed to rewire the FI system since almost every one was broken or disconnected form its plug. These few are all I have left to figure out.
Thanks in advance!
Bobnotch
Bobnotch is offline
PostPosted: Wed Aug 29, 2018 11:00 am    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
The thin red wire went to the electric AAR (Aux Air Regulator).
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Kanester
Kanester is offline
PostPosted: Wed Aug 29, 2018 12:43 pm    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Thanks Bob. The wire for the AAR was broken way underneath it. Found it and hooked up now.
I have no remaining wires in the engine bay now so what hooks up to the Kickdown switch? I assume one is a ground? Where does the other come from?
Are there replacement switches?
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Aug 29, 2018 12:46 pm    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
No colors, but here is how the switch is wired:
I think the wires are all black, anyway.
With an automatic, you probably need the red wire connected to the electric AAR. Can you post a pic of your engine bay in that area (near the distributor) and we can better advise you.
Switches are near impossible to find. Some have adapted generic micro-switches from Radio Shack. Hard to find a RS anymore, too!
Kanester
Kanester is offline
PostPosted: Wed Aug 29, 2018 12:50 pm    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Ah that's easy enough!
Where and what is N5? On the trans?
Kanester
Kanester is offline
PostPosted: Wed Aug 29, 2018 2:13 pm    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Is this the kick down solenoid?
I have a black wire coming out of it.
Pic is from samba gallery that I circled.
Kanester
Kanester is offline
PostPosted: Wed Aug 29, 2018 3:20 pm    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Whoo hoo! Black wire coming from starter harness was the reverse lights.
All that's left is the wire coming from the trans pictured above. If that's the solenoid my engine wiring will finally be done!
I cant test it cause the car still isn't running and the switch is toast.
KTPhil is offline
PostPosted: Thu Aug 30, 2018 10:11 am    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
This confuses me... there is a wire from the starter to the FI (probably white), and a wire form the tranny to the switch (probably black)
Kanester
Kanester is offline
PostPosted: Thu Aug 30, 2018 10:31 am    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Believe me the wiring on this car has driven me mad. LOL
There's not one wire in the engine compartment I haven't had to extend, replace the connector end, or reattach to save the FI.
Pictured is the wire I'm talking about. If you look close you can see the thin black wire behind the red one. It exits the harness that goes to the starter. (I'll be fixing the tape on the red wire soon)
It only has power when the car is in R. Tried every other option to get power to it, as in lights, brakes, and all switches. Only R so reverse lights! Very Happy
There are no other switches on the trans other than the one I circled in the earlier picture. Hoping that is the kick down solenoid.
Bobnotch
Bobnotch is offline
PostPosted: Thu Aug 30, 2018 11:01 am    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
That's "N5" that goes to the kick down switch.
Off the coil + or terminal #15, you should have a black wire with a cigar shaped fuse holder (S1), and a black wire coming out of it, that goes to the kick down switch (FCool.
Tram wrote:
Tram wrote:
Bobnotch
Bobnotch is offline
PostPosted: Thu Aug 30, 2018 11:07 am    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Yes, because it gets power from the gear selector (shifter) in the reverse position. Just like the engine won't start unless the selector lever is in the N position.
That wire gets power from the fuse box (hot with key on) to the shifter. Then out of the shifter to the tail light "T", then to the reverse lights.
I hope this helps.
Tram wrote:
Tram wrote:
Kanester
Kanester is offline
PostPosted: Thu Aug 30, 2018 11:35 am    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Thanks Bob.
Now if I can source a kick down switch I'll be set!
I figured the switch was under the shifter when I looked and felt all around the trans and nothing else was coming out of it. Then i finally found a diagram that showed the switch was a reverse/neutral combo so I figured it had to be under the shifter.
Thanks again for all your guys help. Hopefully I'll be driving today. Then on to the wiring mess under the dash. LOL
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Aug 30, 2018 12:27 pm    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
The KD switch mounts to the engine on the left side of the Intake Air Distributor. I have a thick red wire from my left KD switch contact to the positive side of the coil. I have a thin black wire w/black fuse holder to the other contact on my right KD switch. I took a picture, but Photobucket is screwing with me trying to steer me into a new paid account. My son is trying to move my pics some where else, but even he (IT Expert) is having trouble getting it accomplished! Rolling Eyes
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Multi69s
Multi69s is offline
PostPosted: Thu Aug 30, 2018 10:44 pm    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
The green circled area on your trans is it's kickdown unit. Just to make things simple, it is activated by 12V, not ground. The kickdown "SWITCH", is integrated into the throttle mechanism. But to put it basically, the kickdown switch is a micro switch with an arm on it. In its regular state, it is in the normally open (no connection) condition. The electrical connections are easy. Connect a wire from the hot (keyed) side of the coil to the switch. I put an inline fuse there. Then from the switch run a wire to the green circled connection. When the throttle is floored, it closes the micro switch, and sends 12V to the trans. This activates the kickdown feature.
I wish I had some better pics for you, but I have been running a Type 4 engine so long, I don't have a pic of the stock throttle unit. However, I did steal the first pic from the gallery. The rest of the pics are from my various stages of carburation, and I hope you can get a general idea from al of them.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
EasyBresee
EasyBresee is offline
PostPosted: Fri Apr 09, 2021 6:42 am    Post subject: Re: Kick down switch on a 70 FI auto FB questions Reply with quote
Hi there! Old thread I know, but I noticed your brake light switch in the first pic isn't factory and is secured to block somehow. Do you happen to know whats going on there? My brake light switch plug threaded housing snapped off the block Sad
