bnam Samba Member
Joined: July 02, 2006 Posts: 3462 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Sep 06, 2018 10:05 am Post subject: Door window scraper question |
The colored part is missing on my ghia on both doors. What exactly is it called. And is it avail new?
I'm having difficulty identifying it on the parts manual.
Thanks!
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2937 Location: Auckland, New Zealand
Posted: Thu Sep 06, 2018 10:30 am Post subject: Re: Door window scraper question |
I think it's the metal of the door - inner door skin. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
NoDents Samba Member
Posted: Thu Sep 06, 2018 11:13 am Post subject: Re: Door window scraper question |
On my 71 it's a strip spot welded to the door. I doubt you will find a replacement part number for it since it appears to be a part of the door.
_________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
bnam Samba Member
Posted: Thu Sep 06, 2018 5:45 pm Post subject: Re: Door window scraper question |
Too bad!!
Does anyone have any measurements of that part -- total height and height that protrudes above? I can try to recreate.
Or, I'll have to look for someone cutting up a car. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Posted: Thu Sep 06, 2018 6:20 pm Post subject: Re: Door window scraper question |
For my 1971 Convertible:
31 & 1/16 inches long,
1 inch tall BUT it has a 1/8" fold over seam towards the outside of the door,
Rises 7/16" above the door
Make sense? _________________ No Dents
bnam Samba Member
Posted: Thu Sep 06, 2018 6:38 pm Post subject: Re: Door window scraper question |
Thanks! That does help! That bead formed by the fold-over is probably important to holding down the rubber strip properly. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8237 Location: San Dimas
xzener Samba Member
Posted: Fri Sep 07, 2018 12:24 pm Post subject: Re: Door window scraper question |
What is "A" in the diagram?? C is the glass correct?? I think mine needs an adjustment. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2759 Location: Santa Cruz, CA
Posted: Fri Sep 07, 2018 2:34 pm Post subject: Re: Door window scraper question |
xzener wrote: |
What is "A" in the diagram?? C is the glass correct?? |
Just a guess on my part but in that diagram, "A" looks like it might be a tool used to adjust the position of the guide plugs. Maybe by wedging it between the glass ("C") and the plug, you can spread the sheetmetal a little and gain a bit more clearance if the windows are tight and difficult to roll up & down. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
xzener Samba Member
Posted: Fri Sep 07, 2018 2:50 pm Post subject: Re: Door window scraper question |
My issue is the rubber doesn't press against the glass in a couple areas. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Fri Sep 07, 2018 3:05 pm Post subject: Re: Door window scraper question |
xzener wrote: |
My issue is the rubber doesn't press against the glass in a couple areas. |
Have you tried bending the subject piece of metal towards the window.
In looking at mine (disassembled) it looks pretty wavy. I'll straighten it out before assembly in 6 months or so. _________________ No Dents
Marcdeb Samba Member
