hydro50 Samba Member
Joined: November 21, 2013 Posts: 76 Location: Eagle Rock, CA
Posted: Sat Sep 22, 2018 10:57 am Post subject: Mounting Front License Plate |
Asking for suggestions on how to mount a license plate on a front ribbed bumper? Don’t really want to drill holes if I don’t have to. Are there any nice brackets out there?
Thanks! _________________ Dang this Type II thing has gotten expensive! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sat Sep 22, 2018 11:18 am Post subject: Re: Mounting Front License Plate |
good problem to have, congratulations _________________ regards
Uli
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2214 Location: UK (South)
Posted: Sat Sep 22, 2018 11:46 am Post subject: Re: Mounting Front License Plate |
Adhesive pads like they use on modern number plates. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Sat Sep 22, 2018 3:07 pm Post subject: Re: Mounting Front License Plate |
Make your own bracket.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14272 Location: Casa de Oro, California
Posted: Sat Sep 22, 2018 6:40 pm Post subject: Re: Mounting Front License Plate |
mdege wrote: |
This is what you are looking for. They clamp to the bumper, no holes required. |
Can you explain how these work? |
mdege Samba Member
Posted: Sun Sep 23, 2018 2:11 am Post subject: Re: Mounting Front License Plate |
Sure, I will try to illustrate how they work. These brackets are made for European plates, but I will show how they will work on US plates on these pressed bumpers. The later bumpers are too fat for these brackets to work with US plates unless you drill new holes in the plates.
This is a picture of the parts of a bracket.
This is how it clamps to the edge of the bumper (sorry my bumper are currently up in the rafters).
You will need some spacers to clear the front of the bumper
All you'll see from the front are two screw heads.
You can mount them to the top or the bottom edge of the bumper. It is advisable to use the bottom edge of the bumper because the clamps will leave some marks in the paint of the bumper. _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
epayne611 Samba Member
Joined: February 09, 2011 Posts: 316 Location: Orange County, CA
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Sun Sep 23, 2018 6:46 pm Post subject: Re: Mounting Front License Plate |
Really heavy duty magnets? _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Mon Sep 24, 2018 3:08 pm Post subject: Re: Mounting Front License Plate |
Thanks for all the ideas!
The adhesive pads seem the most economical but I wonder how they’d hold up in the SoCal heat. I don’t feel very confident in them.
Mdege’s brackets look good but rare if available at all.
The Vintage Speed bracket does not work for pressed bumpers as stated on their webpage.
So, npbusguys fabricating a bracket is what I’ll go for. I don’t like how low to the street his sits and Ill try to get something up on the bumper like mdege’s. _________________ Dang this Type II thing has gotten expensive! |
mdege Samba Member
Posted: Fri Sep 28, 2018 3:22 pm Post subject: Re: Mounting Front License Plate |
mdege wrote: |
I have two sets of these brackets. I think they would be put to good use on your bus. You pay for the postage and I'll send them to you. |
Thanks mdege, I will PM you work out details.
Tony _________________ Dang this Type II thing has gotten expensive! |
junichi Samba Member
Joined: September 12, 2005 Posts: 749 Location: brentwood bay, bc
Posted: Fri Aug 11, 2023 4:50 pm Post subject: Re: Mounting Front License Plate |
In case it helps anyone, my front bumper had holes drilled above centre at the correct width apart. I suspect it’s a reproduction bumper. Rather than fold over the plate or have it stick out, I just bent up a simple set of brackets and put a rubber washer on each side to protect the bumper paint. Now it hangs straight.
_________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf |
2type2 Samba Member
Joined: June 02, 2002 Posts: 979 Location: SW Colorado
Posted: Sat Aug 12, 2023 8:18 am Post subject: Re: Mounting Front License Plate |
I made mine from 1" flat iron bar stock, 1/4" nuts and bolts with nyloc nuts. Just fab up a T or H shape, drill out and attach to splash pan.this _________________ "A life of peace and happiness depends on your own gratefulness" |
kiwipip Samba Member
Joined: July 23, 2018 Posts: 76 Location: New Zealand
Posted: Sun Aug 13, 2023 8:29 pm Post subject: Re: Mounting Front License Plate |
I made a plinth out of aluminium, the four screws in the photo are to attach the plate to the plinth. I have bonded the plinth to the bumper as I couldn't bring myself to drill holes in my newly chromed bumper
