henk Samba Member
Posted: Sun Jun 07, 2015 2:45 am Post subject: |
| campingbox wrote: |
| cdennisg wrote: |
A wheelie poppin' high roof split bus. Awesome! |
No kidding, that is cool.
Wasn't there a video of that bus falling on its side somewhere? |
yes,here it is.
that happend during the eurpean big inn at chimay in a burn out contest.
that was when they changed the paint livery off it.
i think it look alot better how it looks now.
https://m.youtube.com/watch?v=KZmuDLiZzsA
henk!!! |
mclarni Samba Member
Joined: August 19, 2008 Posts: 29 Location: Angmering West Sussex
Posted: Thu Aug 11, 2016 1:04 pm Post subject: |
| bad dog racing wrote: |
Worlds Fastest Bus using Reduction Gear Boxes.
5th Fastest Bus in the World.
BOR 64 September 6, 2009
Sacramento Raceway
13.747 at 98.597mph
13.741 at 99.671mph |
Any more info on this bus?
I need a reduction box setup like this for my bus.
Cheers
Nick |
nikke911 Samba Member
Posted: Fri Nov 17, 2017 1:43 pm Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
Jump in for a quick lap around the infamous Nürburgring in my"Leichtbau"panelvan..Couple of yellowflags slowed the lap a little.
mandraks Samba Member
Joined: November 28, 2004 Posts: 7124 Location: Lawrenceville, Ga
Posted: Fri Nov 17, 2017 3:07 pm Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
nice fire suit . Shame about the yellow flag at my favorite (banked) turn  _________________ regards
Uli
Posted: Sat Nov 03, 2018 1:11 am Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
This year even faster...
panel Samba Member
Joined: December 02, 2001 Posts: 1225 Location: Victoria B.C. Canada
Don66bus Samba Member
Posted: Sat Nov 09, 2019 5:19 am Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
Well, that was a trip. How did I miss that video a year ago?
Going around the Ring at speed in a bus. The visuals were familiar. The engine note and the velocity were beyond anything I have experienced in a bus. |
Posted: Sun Nov 17, 2019 9:15 am Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
Couple of laps from this years trip. We go sub 10 minutes BtG now..
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5476 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
panel Samba Member
Posted: Mon Jun 01, 2020 5:23 pm Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
| DONGKG wrote: |
| Is there a need for a spacer installing a 17' Turbo Twist on a Split bus? Thanks in advance. |
I would say only if it needs it like if it were to rub the beam,body or shocks etc. Or you wanted it to be closer to the dogleg. _________________ My '65 Bus~Subaru EJ20 Megasquirted Turbo conversion |
jppiggen Samba Member
Joined: March 14, 2008 Posts: 15 Location: Kaatsheuvel, Netherlands
Posted: Tue Jan 26, 2021 10:27 am Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
hi,
see a lot of modified suspensions here on thesamba.
was just playing around with some parts on my suspension and wanted to see weather this would be a good improvement or not.
test fitted the front suspension of a 944 under my splitscreen from '62 and added shocks from a mk1 golf in the shortest position. Seems to be fitting nicely and no big modifications needed.
the steering rack also fits nicely tilted forward offcourse
the shock tower can be positioned underneath the seat, the sheet metal was toasted anyway. The original frontbeam needs to be fully restored so if I invest the money then might change it to 944 all around. Have all the parts so thats a low starting investment.
If I create a subframe holding the shock tower that would do the trick
send me your thoughts
regards jp |
gumbajv Samba Member
Posted: Wed Jan 27, 2021 7:52 am Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
Haven't up dated my site for a while but did some suspension work and engine mods.
The front suspension was converted to a 935, adjustable control arms, adjustable spindle height, double adjustable nitrogen shocks, coil overs, and camber boxes. Still waiting for a 911 sway bar. I converted to a 911 steering box a few years back. Brakes are Wilwood 4 piston, 911 slot&vented rotors, 912 hubs. Wheels are 8x17 3 pc. BBS/Fuchs.
Sent the 7006 turbo out to be modified for better low/mid range power. The weight includes 140lb driver.
Posted: Fri Jan 29, 2021 12:25 pm Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
Since your using shocks off a fwd car you will probably need to get them re-valved, and may go to a softer coilover.
I would use a racing camber box for the top mounts which would make camber & caster adjustments easier. I would also mount them as high as possible to get good shock travel. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 4583 Location: San Jose, CA
Posted: Fri Jan 29, 2021 3:47 pm Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
| gumbajv wrote: |
The front suspension was converted to a 935, adjustable control arms, adjustable spindle height, double adjustable nitrogen shocks, coil overs, and camber boxes. Still waiting for a 911 sway bar. I converted to a 911 steering box a few years back. |
Have you checked bump-steer using turn plates or bump-steer plates? Curious what you have. |
Posted: Sat Jan 30, 2021 9:27 am Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
(Have you checked bump-steer using turn plates or bump-steer plates?)
Not sure what your referring to. No issues with this setup. |
Posted: Sat Jan 30, 2021 3:49 pm Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
| gumbajv wrote: |
why is it so heavy? a stock 68 crewcab weighs 2590 empty? _________________ regards
Uli
Posted: Sun Jan 31, 2021 7:47 am Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
3027 lbs. without driver. The added weight comes from the modified '79 930 3.3 turbo motor, 915 trans and various other parts.
Posted: Sun Jan 31, 2021 5:18 pm Post subject: Re: Race Bus / Fast Bus / Sleeper Bus **Info & Idea Thread |
that explains the extra weight  _________________ regards
Uli
