What went wrong? 61 dead on freeway.
Page: 1, 2, 3  Next
Clara Premium Member
Clara is offline
PostPosted: Mon Nov 05, 2018 2:31 am    Post subject: What went wrong? 61 dead on freeway. Reply with quote
Unloaded a bunch of items from my April 61 deluxe yesterday. Nice to have the arm chair in the living room. It has been since mid September since I started or drove it, when I drove it south from Washington. The bus has just been parked by the barn. I wanted to get a tall ladder, and the 9 foot hwe rack on the 15 is the ticket. Didn’t unload the garage stereo (with eight track player) and speaker wires.
On the way to Home Depot there was a bit of stuttering or hesitation on the freeway. I thought it odd since that was not usual. And only about 130 miles since filling the tank. Pulled reserve Anyway. Seemed to stop the hesitation.
On the way back, with ladder on rack, I pushed reserve back in anyway. Didn’t seem to affect anything. A few miles later, right before my exit, the hesitation came back. In fact, the engine shut off. I coasted onto the shoulder into the shade of a eucalyptus tree. I smelled something. Smoke? Electrical? Oil temp was 200 F shortly before it stalled. Was cruising about 60-65. 1600sp with big nut tranny. Upper seventies out.
Greg opened the engine lid. No engine smoke. Engine is not hot, looks normal. I looked at the fuses, nothing odd. Looked under the dash. Didn’t see anything odd, except clutter on the tray. And actually the wiring is not pristine.
Honestly, I hadn’t looked at the wiring since the nineties. Some PO did put some hackage under there. But honestly, it worked, and I’d put many miles on the bus without issues. Just not much recently. Felt around. Are there any loose wires? Possibly the headlight switch red wire wAs warm. The white with black stripes wire was cool. one of the ignition switch terminals was warm. I could see which one, it’s a little tight under there.
Starter turned with key, but the engine did not catch. found a test light in my toolbox, the right most fuse was hot, but with key on no other fuse was hot. Hm. Iirc the second fuse should be hot with key on. Asked Greg to check for hot at coil with ignition on. Noticed that the dash lights sometimes did not come on with key on. And smelled some electrical smell with key on, so shut key off.
What did we do to get home?
Tizian
Tizian is offline
PostPosted: Mon Nov 05, 2018 2:52 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Clara,
seems like your ignition switch died... Sad
But that's just a remote guess from across the pond.
Olli
perello
perello is offline
PostPosted: Mon Nov 05, 2018 5:43 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
is this a riddle? Smile
In my case I found that the contact switch tends to develop an eroded pit at the contact point as can be seen here (this is a ghia switch)
It can be easily repaired with epoxy glue.
however I don't see a clear relation between this and a hesitating engine.
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
type241
type241 is offline
PostPosted: Mon Nov 05, 2018 7:15 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Clara, Are you moving from Washington?
Lind
Lind is offline
PostPosted: Mon Nov 05, 2018 8:01 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Fuel, air and spark are the three things an engine needs to run. Spark is the most frequent culprit.
Did you hotwire the bus and drive it home?
Wanted:
iamdonquixote
iamdonquixote is offline
PostPosted: Mon Nov 05, 2018 8:57 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
just a hunch but I'm going to guess you ran a wire from the battery to the coil since power to the coil was no good?
ToolBox
ToolBox is offline
PostPosted: Mon Nov 05, 2018 10:05 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Run the wire from a tail or the tag light and you can turn it off with the light switch....
Erik G
Erik G is offline
PostPosted: Mon Nov 05, 2018 10:37 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
this
unfortunately, also how to steal a vw...
Braukuche
Braukuche is offline
PostPosted: Mon Nov 05, 2018 11:37 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
By pass the ignition switch.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
Tizian
Tizian is offline
PostPosted: Mon Nov 05, 2018 2:09 pm    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Propably the speaker wires did help...
Stocknazi
Stocknazi is offline
PostPosted: Mon Nov 05, 2018 2:10 pm    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
WTF is a freeway?
WANTED:
Thomas Jefferson
Clara is offline
PostPosted: Mon Nov 05, 2018 4:01 pm    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Yes, moving to California.
And yes it’s a riddle. Smile
It did seem like the ignition switch died, so I ran a speaker wire from the battery to the coil. Using the taillight would have been a good idea, it if I have to do it again I’ll keep that in mind.
Abscate
Abscate is offline
PostPosted: Mon Nov 05, 2018 7:42 pm    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
StockNazi wrote:
WTF is a freeway?
It’s a road paid for by others.
mandraks
mandraks is offline
PostPosted: Tue Nov 06, 2018 7:12 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Abscate wrote:
StockNazi wrote:
WTF is a freeway?
Smile
Expressway here in the south.
regards
Uli
BulliBill
BulliBill is offline
PostPosted: Tue Nov 06, 2018 7:37 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
"What went wrong? 61 dead on freeway."
Clara's title to this thread kinda cracks me up! I keep imagining a "Dateline" TV expose on a highway disaster and how a Split Bus could have been involved.
LOL
Bill
I'm looking for these license plate frames from old Volkswagen dealerships for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
crofty
Judas of the North
crofty is offline
PostPosted: Tue Nov 06, 2018 11:11 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Abscate wrote:
StockNazi wrote:
WTF is a freeway?
"Others"? Check out what taxes are on gas and registration in California for road repairs and construction. If you live here, YOU pay for the roads.
HamburgerBrad wrote:
Lind
Lind is offline
PostPosted: Tue Nov 06, 2018 11:42 am    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
crofty wrote:
Abscate wrote:
StockNazi wrote:
WTF is a freeway?
I don't live there, but I still pay on the tollways if I want to cross bridges in the bay area. Not that I really have a problem paying for the roads and bridges, etc.
Wanted:
crofty
Judas of the North
crofty is offline
PostPosted: Tue Nov 06, 2018 1:51 pm    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Lind wrote:
crofty wrote:
Abscate wrote:
StockNazi wrote:
WTF is a freeway?
That goes to it from what ive been told but we have some of the worse roads in the US so go figure.
Today we can vote to repeal the tax that went into effect a few years back and raised my reg fees an additional +$100.
campingbox Premium Member
campingbox is offline
PostPosted: Tue Nov 06, 2018 7:56 pm    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
LOL
Bill
I would be surprised it that wasn’t intentional.
You should always include your children when baking cookies.
cdennisg
cdennisg is offline
PostPosted: Tue Nov 06, 2018 11:49 pm    Post subject: Re: What went wrong? 61 dead on freeway. Reply with quote
Exclamation Question
Page: 1, 2, 3  Next
