1957 Single Cab
ryangabert
ryangabert is offline
PostPosted: Wed Nov 21, 2018 9:36 pm    Post subject: 1957 Single Cab Reply with quote
Just drug this heap home tonight. I believe it's a September 1956 build, but I'll have to check the numbers again on it. Has some good stuff, also has a few hacks. More pictures to come!
Z
Z is offline
PostPosted: Wed Nov 21, 2018 10:15 pm    Post subject: Re: 1957 Single Cab Reply with quote
Love early singles. That looks like a pretty solid start!
Jack-Fatboy
Jack-Fatboy is offline
PostPosted: Thu Nov 22, 2018 1:28 am    Post subject: Re: 1957 Single Cab Reply with quote
Lovely SC. I like it Cool
More pics please. I want to see it.
Peter_N
Peter_N is offline
PostPosted: Thu Nov 22, 2018 3:33 am    Post subject: Re: 1957 Single Cab Reply with quote
I saw your post in the bus hunting thread.
Nice score! Are you planning to leave that patina Smile
My 1958 PGSG project topic
Jung Restoration
Jung Restoration is offline
PostPosted: Thu Nov 22, 2018 10:05 am    Post subject: Re: 1957 Single Cab Reply with quote
Sweet looking truck, congrats on the purchase. One vote to leave the OG paint.
Wanted : January '57 Palm Green Sand Green Bus Parts - Middle and Rear Seat Frames - flat back. I have original seat covers but would consider covered frames.
Jung Restoration - Jung is my last name and restoration is what I do for work. I restore antique windows and doors here in the Northeast. Check out my site www.antiquewindowrestoration.com
ryangabert
PostPosted: Thu Nov 22, 2018 5:16 pm    Post subject: Re: 1957 Single Cab Reply with quote
We got the truck cleaned up a bit today. We’ve been chasing this one for awhile - I got some pictures of it a few years ago but could never quite figure out where it was at. Heard it was sold a few months ago and chalked it up to a loss, but it came up for sale locally yesterday. Here’s a few pictures of the good parts!
Here’s the not so good part!
Blue Baron
VW Aficionado
Blue Baron is offline
PostPosted: Sat Nov 24, 2018 12:05 am    Post subject: Re: 1957 Single Cab Reply with quote
I wonder what they hauled back there?
Heinz Nordhoff
norcalmike
norcalmike is offline
PostPosted: Sat Nov 24, 2018 12:37 am    Post subject: Re: 1957 Single Cab Reply with quote
That is an odd mod
ryangabert
PostPosted: Sat Nov 24, 2018 8:03 am    Post subject: Re: 1957 Single Cab Reply with quote
Supposedly it was used for hauling a water tank around - I don’t see why they couldn’t have just put it on the bed instead. Maybe it was too tall?
The underside of the truck is awesome, with hardly any rust. Just a little on the short rocker behind the treasure chest door, and the same spot on the other side. Front floor needs the outer edges done, but other than that it’s in good shape. We just finished fixing a bunch of rocker/outrigger/jack point rust on our 60 Single Cab, so this one will be a little different. At least you can weld this one from the top!
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Sat Nov 24, 2018 9:12 am    Post subject: Re: 1957 Single Cab Reply with quote
Perfect bus perfect year and month Wink
Congratulations.
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
Squilly
Squilly is offline
PostPosted: Sat Nov 24, 2018 10:03 am    Post subject: Re: 1957 Single Cab Reply with quote
Looks super solid apart from that home improvement. Luckily you can keep that awesome faded paint intact too.
Clara Premium Member
Clara is offline
PostPosted: Sun Nov 25, 2018 8:09 am    Post subject: Re: 1957 Single Cab Reply with quote
gorgeous pic!
maybe the handing was better with the weight lower down?
They wanted a low loader, but just hacked it into one. Decent project, though. Love the patina.
ryangabert
PostPosted: Sun Nov 25, 2018 5:45 pm    Post subject: Re: 1957 Single Cab Reply with quote
We're trying to get our title situation figured out right now, and are a little confused since we've never had a pre-M Code bus titled. Should the number on the title be the body number stamped behind the seat? Or should it be the number stamped on the chassis plate on the passenger side of the engine?
Thanks for the help!
b-man
b-man is offline
PostPosted: Sun Nov 25, 2018 6:00 pm    Post subject: Re: 1957 Single Cab Reply with quote
Your VIN should be stamped on the ID plate and on the body just below the ID plate.
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
PostPosted: Sun Nov 25, 2018 6:29 pm    Post subject: Re: 1957 Single Cab Reply with quote
Yes, what b-man said.
The number stamped into the metal in the engine compartment, which will match the number stamped into the VIN plate.
If your Truck is titled by the body number this was a mistake made in the past and I would get it corrected with an inspection.
jeremy57ride
jeremy57ride is offline
PostPosted: Wed Nov 28, 2018 11:48 am    Post subject: Re: 1957 Single Cab Reply with quote
Just a heads up, that is a bus vin above, not early truck.. the truck vins are stamped on an angle. Great single cab- wish my chassis was that solid!
"If you don't do it this year, you'll be one year older when you do." -Warren Miller
curbo
curbo is offline
PostPosted: Wed Nov 28, 2018 12:22 pm    Post subject: Re: 1957 Single Cab Reply with quote
For sale Ryan?
I did message you but no reply...please pm me
PostPosted: Wed Nov 28, 2018 6:15 pm    Post subject: Re: 1957 Single Cab Reply with quote
True
Example
ryangabert
PostPosted: Sat Dec 26, 2020 7:11 pm    Post subject: Re: 1957 Single Cab Reply with quote
After we let it sit for a couple years, we finally got around to getting started on the 57 single cab. We found some gates on the samba that had lots of repaints, but we had good luck with Easy Off to get them back to original paint. The gate hinge bolts on the truck were insanely stuck, so we ended up pounding the pins out and replacing them instead. We painted some wheels and got tires mounted so we can finally roll it around as well. Should be a good winter project!
Jung Restoration
PostPosted: Sat Dec 26, 2020 7:21 pm    Post subject: Re: 1957 Single Cab Reply with quote
Looks awesome guys, nice work! love this truck
