licketysplit Samba Member
Posted: Thu Jan 03, 2019 10:13 am Post subject: Front tophat removal for 66 standard |
So I'm replacing my cargo floor, removed the front portion to expose the top-hat. Found the ends are toast as expected, the middle between the frame is ok-ish, but the metal behind that (which I assume is the bottom few inches of the bulkhead) has some rust and holes.
Should I replace the entire top hat+the bottom bulkhead metal? Or just the ends? and try and patch those holes?
If I do replace the whole thing, what order of removing parts do I take?
Do I have to remove the bottom most part of the spare tire well? I think it's just tacked to the front side of the bottom of the bulkhead as seen in the last pic.
I dont plan on removing the tubes, so if I do replace the whole tophat I'm just going to notch it. Jack-points and supports are getting removed as well.
Thanks for having a look. |
mdege Samba Member
Joined: January 16, 2018 Posts: 1055 Location: Niederkruechten, Germany
Posted: Thu Jan 03, 2019 2:07 pm Post subject: Re: Front tophat removal for 66 standard |
OK yeah I guess you just cut off the whole bottom of the bulkhead and the top-hat, gotcha.
What a cool fire truck project! So Awesome!
Did you buy the bottom bulkhead strip somewhere? Or did you make it?
Also I love your homemade frame/tipper. Do you happen to have plans/dimensions for it?
Thanks again for responding. |
Dubskii Samba Member
mdege Samba Member
Skim Rants Master
Joined: April 15, 2001 Posts: 17095 Location: GFK 31 Year Vet
Posted: Fri Jan 04, 2019 12:13 pm Post subject: Re: Front tophat removal for 66 standard |
I usually replace the ends where they are bad and then weld in the new back splash panel after all's said and done.
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
