Different Deck Heights
i_luv_my_bus76
i_luv_my_bus76 is offline
PostPosted: Sat Jan 19, 2019 6:05 pm    Post subject: Different Deck Heights Reply with quote
I just checked the deck height on all 4 cylinders
1& 2 are .035
3&4 are .039
I can live with .039 but I'm a little concerned with the .035
Should I be concerned or has anyone else ran the deck that close
mcmscott
mcmscott is offline
PostPosted: Sat Jan 19, 2019 6:12 pm    Post subject: Re: Different Deck Heights Reply with quote
Trim 1-2 then rebalance
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
i_luv_my_bus76
PostPosted: Sat Jan 19, 2019 6:19 pm    Post subject: Re: Different Deck Heights Reply with quote
If I trim 1&2 won't that bring the deck closer?
Vanillagurilla
Vanillagurilla is offline
PostPosted: Sat Jan 19, 2019 6:23 pm    Post subject: Re: Different Deck Heights Reply with quote
Lol yeah you can trim the other side or shim up the close side.
Pruneman99
Pruneman99 is offline
PostPosted: Sat Jan 19, 2019 6:27 pm    Post subject: Re: Different Deck Heights Reply with quote
I think he was taking about the pistons. Bit that seems like a lot of work unless this is a race engine.
Just shim them out where you feel comfortable. Maybe .01?
Howard 111
Howard 111 is offline
Put an .004 cylinder shim under 1&2.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
i_luv_my_bus76
PostPosted: Sat Jan 19, 2019 6:34 pm    Post subject: Re: Different Deck Heights Reply with quote
The thinnest shim I can find is .01, is there a place that makes custom shims
If I shim them both at .01 it will throw my compression ratio off
i_luv_my_bus76
PostPosted: Sat Jan 19, 2019 6:36 pm    Post subject: Re: Different Deck Heights Reply with quote
It's an engine for my daily driver
I'm building a 1955cc
If I shim both sides I will knock my compression ratio off...I'm shooting for 9:1...with .039 I'm right there
rugblaster
rugblaster is offline
PostPosted: Sat Jan 19, 2019 6:52 pm    Post subject: Re: Different Deck Heights Reply with quote
how thick is a paper gasket?
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
i_luv_my_bus76
PostPosted: Sat Jan 19, 2019 6:59 pm    Post subject: Re: Different Deck Heights Reply with quote
Good question, never thought of that! I'll measure when I get home!
I've always tossed those things aside...i probably have 50 of them sitting around somewhere in a box since i never throw anything away
FreeBug
FreeBug is offline
PostPosted: Sun Jan 20, 2019 1:05 am    Post subject: Re: Different Deck Heights Reply with quote
Genius!
But if that doesn't work, I would turn down the cylinders quite a bit, so you can use thicker shims. If you get a full set, no two really match, so you mix & match until you get the deck you want.
Alstrup
Alstrup is offline
PostPosted: Sun Jan 20, 2019 4:55 am    Post subject: Re: Different Deck Heights Reply with quote
Genius!
Never use papewr gaskets! Even copper gaskets are dubius.
In your case either trim 2 pistons and rebalance, or machine the cylkinders to accomodate a 0,5 mm shim or similar would be the way.
T
rodeking
rodeking is offline
PostPosted: Sun Jan 20, 2019 6:44 am    Post subject: Re: Different Deck Heights Reply with quote
I had the same problem, cut the pistons and re-balanced. I checked the gaskets I had, they were .005 before I threw them in the trash.
volksworld
volksworld is offline
PostPosted: Sun Jan 20, 2019 7:05 am    Post subject: Re: Different Deck Heights Reply with quote
paper gaskets are just one more thing to go wrong....have you cc'd the heads? cause if they're not new and have been flycut before one side could have larger chambers than the other....then you may be able to put a .010 under all 4....i personally wouldnt run 9 to 1 on the street but its your car....
i_luv_my_bus76
PostPosted: Sun Jan 20, 2019 7:39 am    Post subject: Re: Different Deck Heights Reply with quote
The heads are new...dual port big valve, single high rev springs, cc'd to 55.
Why wouldn't you run 9 to 1? What compression is the highest compression you feel comfortable running on the street?
esde
esde is offline
PostPosted: Sun Jan 20, 2019 8:43 am    Post subject: Re: Different Deck Heights Reply with quote
If it's balanced already, trim the cylinders and get shims to sort it. If it's not balanced, trimming the pistons would be my choice.
No need to make more work if you don't need to
modok wrote:
vwracerdave
vwracerdave is offline
PostPosted: Sun Jan 20, 2019 9:13 am    Post subject: Re: Different Deck Heights Reply with quote
I don't have a machine shop in my garage, I have to pay to have it done.
The best solution would be trim .004" off 1&2 pistons then rebalance all 4. That would give you .039" deck height across all 4 cylinders.
If it were my engine I would put a .010" shim under the barrels and build it. Worrying about 8.9 or 9.0 compression won't make a bit of difference on a street engine and is just plain being anal.
mark tucker
mark tucker is offline
PostPosted: Sun Jan 20, 2019 12:22 pm    Post subject: Re: Different Deck Heights Reply with quote
eazy put them all at .035, mine are .034 seems to work just fine.
rugblaster
PostPosted: Sun Jan 20, 2019 12:37 pm    Post subject: Re: Different Deck Heights Reply with quote
I am old enough to have had the opportunity to have repaired original VW air-cooled engines from the factory. (virgin engines, if you will) They all had paper gaskets on the cylinders. I also remember using a single edge razor blade to physically remove the paper gaskets. They were stuck pretty good. Paper gaskets are still used in some instances, not just VW cylinders. It is just easier to slop some RTV on the cylinder base and slap in on. You actually have to pay attention when using the paper and that is difficult for some people
to grasp. In certain circumstances, paper would be a viable choice.
Also, with larger cylinders, the paper gaskets choice is mute anyway.
i_luv_my_bus76
PostPosted: Mon Jan 21, 2019 11:14 am    Post subject: Re: Different Deck Heights Reply with quote
Can I get some clarification...if it were your engine would you trim then shim with a .010...or just shim with a .010
