Engine noise
cooltings
cooltings is offline
PostPosted: Sat Jan 26, 2019 8:54 pm    Post subject: Engine noise Reply with quote
When I shift to 3rd gear it starts sluggish and then I hear a loud crank in the engine department and sounds like something is rattling around back there. Any ideas
BarryL Premium Member
BarryL is offline
PostPosted: Sun Jan 27, 2019 11:41 am    Post subject: Re: Engine noise Reply with quote
Any more details?
cooltings
PostPosted: Sun Jan 27, 2019 5:07 pm    Post subject: Re: Engine noise Reply with quote
Could this be the flywheel. It makes a awful sound like something broke. But only does it in high gears
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sun Jan 27, 2019 8:39 pm    Post subject: Re: Engine noise Reply with quote
Does the sound change with throttle: accel. , decel. ,float ? Hot or cold engine?
Can you make the same sound with a slight dump of the clutch? Or, make it go away with slight pressure on the clutch pedal?
Loads on the engine and trans are higher in 3rd and 4th gears, check that your clutch free play is right, and check crank end play.
If you can record the sound so we can all hear it.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
