Ultimate redux swap thread
Page: Previous  1, 2, 3 ... , 14, 15, 16  Next
Hebster52
Hebster52 is offline
PostPosted: Thu Aug 03, 2017 9:29 am    Post subject: Re: Ultimate redux swap thread Reply with quote
I can measure tomorrow.
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Hebster52
PostPosted: Sat Aug 05, 2017 6:27 am    Post subject: Re: Ultimate redux swap thread Reply with quote
I measures mine to 38mm. Adapterplate + spacer.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Thu Aug 09, 2018 9:15 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Reductiongboxes installed! Still need to change from dropspindles to liftspindles.... Laughing
~Kris~
The 912ST
The KidVRod project
thefladge
thefladge is offline
PostPosted: Thu Aug 09, 2018 9:36 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Looks good. Is there much wheel hop?
1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate.
Hebster52
PostPosted: Thu Aug 09, 2018 10:14 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Not driven it yet. Need to lift the front too.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Wed Sep 19, 2018 10:34 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
~Kris~
The 912ST
The KidVRod project
heywebonya
heywebonya is offline
PostPosted: Wed Sep 26, 2018 4:36 am    Post subject: Re: Ultimate redux swap thread Reply with quote
Hebster,
Looks great, any pictures of the mounting?
What method did you use to install the boxes? Any anti-hop braces?
Thank you, Jeff
If I knew what I was doing; I wouldn't be building a buggy!
Hebster52
PostPosted: Fri Oct 19, 2018 12:40 am    Post subject: Re: Ultimate redux swap thread Reply with quote
This is the axles I used for my 66. The kit was built by some local blacksmith or something way back in early 60's... So the reductiongear was also reduced even more. with the custom gears it is way too loud so now I'm building a new set of original reductionboxes that I then fit to these. Hoping the original gears are better manufactured.. Smile
~Kris~
The 912ST
The KidVRod project
oldschool5er
oldschool5er is offline
PostPosted: Fri Oct 19, 2018 9:10 am    Post subject: Re: Ultimate redux swap thread Reply with quote
You will get much more gear noise from that early original split case transmission you are showing in your picture. The gear noise from the outboard redux gears is not as much as the early split case trans itself. You can still use the early redux axles and setup into a later year tunnel type transmission that alone will significantly quiet up the gear noise over the splitcase trans. If you can find a later year redux box and tunnel type trans it will be a whole lot quieter. The big nut redux box is a better option over the small nut redux you are showing.
HRE in Westerville,Ohio
Full machine shop with all types of CNC. Rapid prototyping available, CNC Plasma cutting, 3D printing and Laser engraving.
Hebster52
PostPosted: Fri Oct 19, 2018 10:51 am    Post subject: Re: Ultimate redux swap thread Reply with quote
FYI. I did not use the splitcase. Just the axles. Click on the "1966 Kommanderwagen" link in my signature below for more info.
~Kris~
The 912ST
The KidVRod project
oldschool5er
PostPosted: Fri Oct 19, 2018 3:17 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
I see that now lol. Nice bug very clean job.
There was some good tidbits in your thread that I enjoyed, especially the way they went about using the odd ratio Alpine gear. I doubt anybody would ever see that done like that again lol.
Hebster52
PostPosted: Fri Oct 19, 2018 11:55 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Yes. Got to say it is powerful with the alpine gear but unfortunately too noisy so I will make a new set with original small nut gears this winter.
~Kris~
The 912ST
The KidVRod project
MjrBummer
MjrBummer is offline
PostPosted: Mon Nov 12, 2018 1:55 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Oh man! I was hoping that by the time I read through all 15 pages, I'd find the blueprints for the no-hop kit that were mentioned early in the thread. I figured RGB's in the rear and a complete Thing beam up front on my 61 Baja would be just what I need to get a few more inches of ground clearance. I'll just have to keep my open for a NOS, used kit.
Oh well, it was still a good read. It's good to see there are still some do-it-yourselfers out there.
Bill
mtbuicknut
mtbuicknut is offline
PostPosted: Thu Jan 31, 2019 2:00 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
So what E brake cables did anybody use. The previous owner of my buggy said that the stock cable for a bug wouldn't last. Does the distance from the backing plate to the tubes increase? So wouldn't you use a bus w/RGB setup??
Thanks Rick
thefladge
PostPosted: Thu Jan 31, 2019 2:22 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Thanks Rick
I used 1956 to 1957 Bug E brake cables. They are longer than later model Bug cables.
Hebster52
PostPosted: Mon Apr 29, 2019 1:29 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Here's mine now with new adapterplates. Also turned springpiates about half an inch to get the rear up that much.
~Kris~
The 912ST
The KidVRod project
mr_bill
mr_bill is offline
PostPosted: Mon Apr 29, 2019 2:19 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
Shocked PLEASE, replace that COPPER BRAKE LINE in the last pic!!
see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org
Hebster52
PostPosted: Mon Apr 29, 2019 7:30 pm    Post subject: Re: Ultimate redux swap thread Reply with quote
It is NOT copper.... Rolling Eyes
~Kris~
The 912ST
The KidVRod project
heywebonya
PostPosted: Tue Apr 30, 2019 4:54 am    Post subject: Re: Ultimate redux swap thread Reply with quote
Those are amazing adapter plates! They look like a factory option. Do have any issues with the rear dropping during acceleration?
Kind regards, Jeff
Hebster52
PostPosted: Tue Apr 30, 2019 6:15 am    Post subject: Re: Ultimate redux swap thread Reply with quote
Thanks! Not driven with this setup yet. Just filled the transmission with oil. Battery is in charge so very soon. I drove it last year too with basically similar setup and it did not bother me at all.
~Kris~
The 912ST
The KidVRod project
Page 15 of 16
