scottf1887 Samba Member
Joined: March 14, 2014 Posts: 139 Location: Tejas Baby!!
Posted: Sun Jun 09, 2019 5:44 pm Post subject: Help please! What are the symptoms of a broken axle? |
So I have a new to me 61 that I took out tonight and pushed home. I let off the clutch from a red light (nothing crazy, but a fun start) and a loud clunk came from my rear end. On each rotation of the axle there is a heavy bind and clunk. In neutral the car rolls just fine, but from motor power I get the crazy clunk and it'll lock up and stop. For what it's worth it's a 180 how 2387 with a 3.88 ring and pinion and super diff pro street box. If it helps I can try to get a video, I'm just hesitant to run it again. I know it has stock axles so I'm thinking and hoping it's those or the fulcrum plates. I've mostly had stock bugs so this is a new one to me. Thanks!! |
Posted: Sun Jun 09, 2019 6:09 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Also, it's a solid mounted transaxle that really hasn't been lowered much.
Posted: Sun Jun 09, 2019 6:24 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Below is a link to a video of it under a load. You can see/hear the clunk a bit under the noise of the motor.
https://youtu.be/9Z9m4Vn4xtI |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20802 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jun 09, 2019 7:01 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
First thing I would check on is torque on both rear axles.... People sometime don't torque them properly and it will allow a axle to spin inside brake drum (eats the splines) and it resemble a broken axle or some other no-go situation.....
Axles should be torqued to 217 ft-lbs, and go tighter till castle nut aligns with hole in axle shaft for cotter pin...
If that does not resolve situation, yes you will need to go deeper...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Sun Jun 09, 2019 7:18 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Thanks Dale. I'm going to dig into it tomorrow. The only thing that really concerned me is that a a certain point in the rotation the car won't even move. I'm really hoping it's not inside the gear box, but I'll keep you posted. Thanks! |
esde Samba Member
Joined: October 20, 2007 Posts: 6320 Location: central rust belt
Posted: Sun Jun 09, 2019 7:45 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Had you driven the car before? _________________ modok wrote:
Posted: Sun Jun 09, 2019 7:48 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Yeah. I've only owned it for a week but I've probably put 50 easy miles on it around town with no noises or issues. I've been searching the forums for similar symptoms with no luck. |
Posted: Mon Jun 10, 2019 11:14 am Post subject: Re: Help please! What are the symptoms of a broken axle? |
So the drums were pulled and retorqued, all is good there. While it's up on stands I'm turning the drums while it's on gear and all is smooth turning. I'm lost. I'm guessing I need to pull the motor and see if maybe in the bell housing? I doubt it is, but that'll be needed if I need a new trans I guess...any guesses? |
Posted: Mon Jun 10, 2019 11:16 am Post subject: Re: Help please! What are the symptoms of a broken axle? |
jason Samba Member
Posted: Mon Jun 10, 2019 12:00 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Does it do it at all in reverse? Say if you reverse far. Sounds like diff area or axles to me. Also sounds like loose nosecone but that wouldn’t explain the binding |
Posted: Mon Jun 10, 2019 12:21 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Same in reverse. I have it in reverse and spins nice and smoothly....I'm lost |
Posted: Mon Jun 10, 2019 1:11 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Well still no luck but just got the motor out. Not the way I wanted to spend my first week with a new car...oh well I'm able to clean up and do a few things better that I noticed before. I'll keep you posted!
Posted: Mon Jun 10, 2019 1:20 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Turning the input shaft with it in gear and a lock/ bind. Let's keep digging!! |
DeathBySnuSnu Samba Member
Posted: Mon Jun 10, 2019 1:26 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
The only times I have had something very similar it was the fulcrum plates at the axle spade.
One had fallen out of place while installing axle in the car. It was pushed up behind the spade.
It all went together as best I could feel with it in car. Like you say...seems to spin smooth by hand.
Car drove back and forth from the college a few times before making sounds simular yours.
Pulled the axle spade out and had crunched up fulcrum plates. _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4145 Location: Georgia
Posted: Mon Jun 10, 2019 1:29 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Look at the clutch and throw out bearing and the arm.
See anything there? _________________ Volkswagen!
(Compression 8.7:1) |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13545 Location: Tejas!
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4924 Location: sanger ca
Posted: Mon Jun 10, 2019 1:32 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
Ring and pinion or crosshaft for spiders is coming out. Have you drained the trans oil and inspected the magnet? _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon Jun 10, 2019 2:18 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
I'm really hoping it's not the R&P, but we'll see. The chuncks from the drain plug are below. Hard to say what it's from, but they were torn apart pretty good!
Posted: Mon Jun 10, 2019 2:19 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
If that is the case...any good transaxle shops in Central Texas that y'all know of? |
Posted: Mon Jun 10, 2019 4:55 pm Post subject: Re: Help please! What are the symptoms of a broken axle? |
I just shipped one to Bryan (?) Texas last month. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
