Thread Sealer
Mikes57BuginPA
Mikes57BuginPA is offline
PostPosted: Tue Aug 27, 2019 1:50 pm    Post subject: Thread Sealer Reply with quote
Does anyone use a thread sealer that is a better alternative to teflon tape?
Thanks
slalombuggy
slalombuggy is offline
PostPosted: Tue Aug 27, 2019 1:53 pm    Post subject: Re: Thread Sealer Reply with quote
I use liquid thread sealant on all my pipe fittings. Available at any FLAPS
brad
74 Thing
74 Thing is offline
PostPosted: Tue Aug 27, 2019 2:00 pm    Post subject: Re: Thread Sealer Reply with quote
Blue loctite
mcmscott
mcmscott is offline
PostPosted: Tue Aug 27, 2019 3:08 pm    Post subject: Re: Thread Sealer Reply with quote
74 Thing wrote:
Blue loctite
This^^
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
mark tucker
mark tucker is offline
PostPosted: Tue Aug 27, 2019 3:18 pm    Post subject: Re: Thread Sealer Reply with quote
either tape or otay liqued pipe sealant wif tef lon is what I use. most of the time the tape, eazy fast no mess ,no leek. for head stud&nuts the liquid otay pipe dope...
theDrew
theDrew is offline
PostPosted: Tue Aug 27, 2019 3:48 pm    Post subject: Re: Thread Sealer Reply with quote
huge fan of the loctite anaerobic gasket maker -- works on everything I've tried it on -- oil lines, water lines, air lines, vacuum lines etc
Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25
Dale M.
Dale M. is online now
PostPosted: Tue Aug 27, 2019 4:11 pm    Post subject: Re: Thread Sealer Reply with quote
I use this or car plumbing, and home plumbing, just about everything that needs a thread "sealer"...
Dale
jimmyhoffa
jimmyhoffa is offline
PostPosted: Tue Aug 27, 2019 7:00 pm    Post subject: Re: Thread Sealer Reply with quote
Loctite 565 has to show up in here because it is the real business. (Anaerobic magic Teflon sauce)
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
67 Sunroof
67 Sunroof is offline
PostPosted: Tue Aug 27, 2019 7:37 pm    Post subject: Re: Thread Sealer Reply with quote
Loctite 565
Razz
chrisflstf
chrisflstf is offline
PostPosted: Tue Aug 27, 2019 7:50 pm    Post subject: Re: Thread Sealer Reply with quote
Threads need to be super clean for most sealers to work well.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Aug 27, 2019 9:39 pm    Post subject: Re: Thread Sealer Reply with quote
I have used this for decades. GM makes it. I use it on most anything that would require Teflon tape.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Bruce Amacker
Bruce Amacker is offline
PostPosted: Wed Aug 28, 2019 6:04 am    Post subject: Re: Thread Sealer Reply with quote
Great, another "What oil should I use" thread......
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
Cusser
Cusser is offline
PostPosted: Wed Aug 28, 2019 7:39 am    Post subject: Re: Thread Sealer Reply with quote
Actually, someone makes this for GM and puts the GM information on it.
Just like Dexcool, Dextron....oil filters, spark plugs, etc.
Loctite and Permatex are huge in sealers and thread lockers manufacture, and are excellent products.
jeffrey8164
jeffrey8164 is offline
PostPosted: Wed Aug 28, 2019 9:23 am    Post subject: Re: Thread Sealer Reply with quote
Over the years I’ve used everything from products that say thread sealant on them to tub and tile caulk. They’ve all worked for the application.
Can you use tub and tile caulk on the space station?
I dunno.
Volkswagen!
(Compression 8.7:1)
Cusser
Cusser is offline
PostPosted: Wed Aug 28, 2019 12:58 pm    Post subject: Re: Thread Sealer Reply with quote
I dunno.
Sure. In the space station bathroom.
Dale M.
PostPosted: Wed Aug 28, 2019 1:40 pm    Post subject: Re: Thread Sealer Reply with quote
Technically TEFLON tape (not actually a trade name of company that holds copyright for "TEFLON") is not a thread sealer, its a thread lubricant so you can tighten tapered thread connections tighter and possible get better interference in tapered threads.... The correct definition for "the tape" is PTFE....
Dale
andy198712
andy198712 is offline
PostPosted: Wed Aug 28, 2019 3:34 pm    Post subject: Re: Thread Sealer Reply with quote
Dale
Dupoint is it? That own that name
Alstrup wrote:
I like 5,5inchers in the rear at least.
modok
modok is offline
PostPosted: Wed Aug 28, 2019 5:22 pm    Post subject: Re: Thread Sealer Reply with quote
the dealer stuff is probably loctite 565, except just you pay more for it.
Dale M.
PostPosted: Wed Aug 28, 2019 6:46 pm    Post subject: Re: Thread Sealer Reply with quote
andy198712 wrote:
Dale
Not sure, maybe past tense.... .... These sites tells a different story....
https://www.chemours.com/Teflon/en_US/index.html
https://www.chemours.com/Teflon/en_US/products/safety/what_is_it.html
Dale
Cusser
Cusser is offline
PostPosted: Wed Aug 28, 2019 6:50 pm    Post subject: Re: Thread Sealer Reply with quote
PTFE is poly tetrafluoroethane.
