crankbait09 Samba Member
Joined: October 10, 2016 Posts: 1415 Location: Cincinnati, Ohio
Posted: Mon Sep 02, 2019 3:02 pm Post subject: POR prep question |
For those of you that have used POR-15, I have a question about the prep work. In October, I plan on POR'ing my floor pan, the underside. Currently the floor pan is black, and there is minimal surface rust. I was going to sand off the surface rust using sand paper or a wire wheel. Since I don't have much rust I need to get rid of, is there any reason I would need to use the POR-15 METAL PREP? I was going to sand, then use the de-greaser to clean it up.
I wouldn't think I'd need to remove ALL the black finish, just to take it to bare metal. would I? Would the POR-15 Metal Prep be needed for this? _________________ 1963 Ragtop |
bluebus86 Banned
Posted: Mon Sep 02, 2019 4:04 pm Post subject: Re: POR prep question |
| crankbait09 wrote: |
I wouldn't think I'd need to remove ALL the black finish, just to take it to bare metal. would I? Would the POR-15 Metal Prep be needed for this? |
you should degrease prior to sanding, as sanding can trap grease in the sand marks, folded over paint, making it resistant to degreasing after sanding. degrease both before and after sanding.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon Sep 02, 2019 4:06 pm Post subject: Re: POR prep question |
ok. I get that.
what about the metal prep stage? since I am not working with complete bare metal, can this part be skipped? _________________ 1963 Ragtop |
wayne1230cars Samba Member
Posted: Mon Sep 02, 2019 4:10 pm Post subject: Re: POR prep question |
That seems like a lot of work. I have used POR15. It’s good stuff albeit a little on the pricey side.
POR15 has a web site with tech support for their products. I emailed a question to them and had a response within a few hours. That would be my suggestion for your question. _________________ 1960 beetle
1970 beetle convertible |
Posted: Mon Sep 02, 2019 4:11 pm Post subject: Re: POR prep question |
Didn't know that was an option. I'll ask them and see what they say. thank you _________________ 1963 Ragtop |
viiking Samba Member
Joined: May 10, 2013 Posts: 3427 Location: Sydney Australia
Posted: Mon Sep 02, 2019 9:46 pm Post subject: Re: POR prep question |
My experience with POR15 is that it is not much good over painted metal. POR= Paint over rust.
You are better off removing all of the paint, letting it flash rust, then use POR15 metal prep to remove the flash rust and provide the key then the POR15 paint. Painting over the already painted area may cause the new POR15 to lift off in sheets. POR15 needs the rusty surface to work the best.
Many people have used the KBS equivalents or the Master Series which also gets good reviews.
Just my 2c! _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1328 Location: Beautiful New Zealand
Posted: Mon Sep 02, 2019 9:59 pm Post subject: Re: POR prep question |
I'm guessing that in response to any such query, POR's response will be to use their product system as recommended...
You don't want this to happen because you took a sortcut
_________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
shakers73 Samba Member
Joined: June 14, 2011 Posts: 832 Location: Saltville, Va
Posted: Tue Sep 03, 2019 5:53 am Post subject: Re: POR prep question |
Try this. I like it better than POR 15
http://www.masterseriesct.com/ _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3483 Location: Vulcania
Posted: Tue Sep 03, 2019 7:47 am Post subject: Re: POR prep question |
ok. I get that.
what about the metal prep stage? since I am not working with complete bare metal, can this part be skipped? |
Por15 can go right over bare metal and it works best if it has rust on it. Just remember after Por15 goes down you need to use the Tie coat primer over it before you can paint over it. In other words Por15 is NOT a top coat. Read the Por15 instructions, it will tell you about it's characteristics and the Tie coat primer. |
Posted: Tue Sep 03, 2019 8:51 am Post subject: Re: POR prep question |
POR's response was to use the metal prep only on areas that are bare or rusty.
I haven't bought anything yet. I will compare to other products. Looking for the least amount of work since I don't have a whole lot to treat or repair _________________ 1963 Ragtop |
