DurocShark Samba Member
Joined: April 05, 2004 Posts: 6635 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Wed Sep 11, 2019 6:35 pm Post subject: Holley Fuel Pressure Regulator |
OK, what the hell?
I adjusted this a couple weeks ago down to 1.5psi for a Progressive carb. I look now, and it's back up to 3psi. You can see the adjustment is pretty much maxed out.
What. The. Hell.
I'm guessing it's toast, but I've never seen a FPR fail before. Pic below.
_________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Wed Sep 11, 2019 6:38 pm Post subject: Re: Holley Fuel Pressure Regulator |
And yes, I know the throttle cable tube has popped. I'm gonna stick a hose clamp or something on the back side. Haven't decided how best to address it yet.
The progressive works great, but things like poor throttle placement make me consider throwing the duals on there. And I still might. They're on my 2180 right now, but I'm planning on going FiTech for that engine... _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
gbaker Samba Member
Posted: Wed Sep 11, 2019 6:45 pm Post subject: Re: Holley Fuel Pressure Regulator |
They sell rebuild kits but those chrome Holley regs suck. |
jason Samba Member
Clean it out, maybe some crud in it holding it open. I always dead head the line when setting the psi. |
Posted: Wed Sep 11, 2019 6:50 pm Post subject: Re: Holley Fuel Pressure Regulator |
Thanks. Any recommendations for a quality FPR? I'm running a "low pressure" rotary pump, but it still goes over 4psi if I'm not managing it. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2281 Location: Jacksonville, FL
Posted: Wed Sep 11, 2019 6:54 pm Post subject: Re: Holley Fuel Pressure Regulator |
What spring is in the Holley regulator? They offer 2 different springs in case you did not know. The "standard" spring is for fuel systems needing anywhere from 5-10psi. The less common spring is for 1-5psi as I recall. I'll check Holley or Summit to see if I find the part number. _________________ www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Posted: Wed Sep 11, 2019 6:58 pm Post subject: Re: Holley Fuel Pressure Regulator |
the Holley 12-804 regulator has a range of 1-4psi. You need to make sure you have THAT regulator or the rebuild kit for THAT regulator.
As far as i know all those regulator housings are the same. _________________ www.LoCashRacing.org
Posted: Wed Sep 11, 2019 6:59 pm Post subject: Re: Holley Fuel Pressure Regulator |
Really? Well, crap. You're gonna make me go out and work on the thing Saturday in 97 degree heat, aren't you?
This thing came on my 2180 with the dual brosols (no idea which ones at the moment) and it was running 3psi. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
HBRag Samba Member
Joined: April 29, 2005 Posts: 735 Location: Huntington Beach, CA
Posted: Wed Sep 11, 2019 7:00 pm Post subject: Re: Holley Fuel Pressure Regulator |
If that is a liquid filled pressure gauge, then it will change reading with increased engine bay temperature. If so that reading will only be accurate when you first start the car. |
Posted: Wed Sep 11, 2019 8:09 pm Post subject: Re: Holley Fuel Pressure Regulator |
HBRag wrote: |
That pic was taken cold, engine off, with the electric pump on.
I got the same reading hot with the engine running. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1386 Location: Southern California
Posted: Wed Sep 11, 2019 8:45 pm Post subject: Re: Holley Fuel Pressure Regulator |
Aeromotive makes a low pressure regulator made for 1.5 psi. Just under 200.00. Summit sells them. The holley ones suck.
madmike Samba Member
Joined: July 11, 2005 Posts: 5300 Location: Atlanta,Michigan
Posted: Thu Sep 12, 2019 4:42 am Post subject: Re: Holley Fuel Pressure Regulator |
X2 on the Aeromotive  _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
slalombuggy Samba Member
Posted: Thu Sep 12, 2019 5:13 am Post subject: Re: Holley Fuel Pressure Regulator |
I used a Malpassi regulator from CB works perfect and less than 1/2 the cost of the automotive fpr.
brad |
Jebchevelle Samba Member
Posted: Thu Sep 12, 2019 9:42 pm Post subject: Re: Holley Fuel Pressure Regulator |
never had a problem with those cheap holley regulators in a carb setup. the rebuild kits are not much like $14-$18 I would rebuild it and make sure everything it clean. also make sure you have the low pressure spring. |
jason Samba Member
Posted: Thu Sep 12, 2019 9:51 pm Post subject: Re: Holley Fuel Pressure Regulator |
The rebuild kits are $9.99 and comes with both springs around here. I have 3 of those holley regs and haven’t had a problem yet. The insides are basically all the same, a diaphragm and a spring. The bigger the diaphragm, better. |
Posted: Fri Sep 13, 2019 5:15 am Post subject: Re: Holley Fuel Pressure Regulator |
Rebuild kit was $13 including shipping direct from Holley.
Thanks everybody! _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11159 Location: Oregon
Posted: Fri Sep 13, 2019 6:03 pm Post subject: Re: Holley Fuel Pressure Regulator |
slalombuggy wrote: |
brad |
^^^^^ I use this! Never a problem. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Sun Sep 22, 2019 5:20 pm Post subject: Re: Holley Fuel Pressure Regulator |
Rebuilt it with the Holley kit. Found some odd crap, but nothing that should impact the pressure. Ball and spring work as they should, but it never goes below 2.5 psi. And that only when running, if I just energize the fuel pump it hits 3psi.
I don't think this is actually the cause of the rich idle problem I have, just eliminating suspects. And since I had no idea about the condition the FPR was in, figured I'd tackle it.
I think it's just crap.
Here's the odd thing I found. On one side of the output, there's what looks like a wall that has rotted away. I'm guessing flashing from the casting process. But it's pretty damn thick. Couldn't chip it out with a screwdriver.
jason Samba Member
Posted: Sun Sep 22, 2019 9:22 pm Post subject: Re: Holley Fuel Pressure Regulator |
Whats the fuel pressure without the reg? |
Posted: Mon Sep 23, 2019 5:12 am Post subject: Re: Holley Fuel Pressure Regulator |
It'll go over 4psi straight off the pump.
OK, yeah. It's not doing nothing at all. Just not what I want it to do.
I did a video of the rebuild...
