Holley Fuel Pressure Regulator
DurocShark
Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
DurocShark is offline
PostPosted: Wed Sep 11, 2019 6:35 pm    Post subject: Holley Fuel Pressure Regulator Reply with quote
OK, what the hell?
I adjusted this a couple weeks ago down to 1.5psi for a Progressive carb. I look now, and it's back up to 3psi. You can see the adjustment is pretty much maxed out.
What. The. Hell.
I'm guessing it's toast, but I've never seen a FPR fail before. Pic below.
No boom today. Boom tomorrow. There's always a boom tomorrow.
DurocShark
PostPosted: Wed Sep 11, 2019 6:38 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
And yes, I know the throttle cable tube has popped. I'm gonna stick a hose clamp or something on the back side. Haven't decided how best to address it yet.
The progressive works great, but things like poor throttle placement make me consider throwing the duals on there. And I still might. They're on my 2180 right now, but I'm planning on going FiTech for that engine...
gbaker
gbaker is offline
PostPosted: Wed Sep 11, 2019 6:45 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
They sell rebuild kits but those chrome Holley regs suck.
jason
jason is offline
Clean it out, maybe some crud in it holding it open. I always dead head the line when setting the psi.
DurocShark
PostPosted: Wed Sep 11, 2019 6:50 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
Thanks. Any recommendations for a quality FPR? I'm running a "low pressure" rotary pump, but it still goes over 4psi if I'm not managing it.
Lo Cash John
Lo Cash John is offline
PostPosted: Wed Sep 11, 2019 6:54 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
What spring is in the Holley regulator? They offer 2 different springs in case you did not know. The "standard" spring is for fuel systems needing anywhere from 5-10psi. The less common spring is for 1-5psi as I recall. I'll check Holley or Summit to see if I find the part number.
www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
Lo Cash John
PostPosted: Wed Sep 11, 2019 6:58 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
the Holley 12-804 regulator has a range of 1-4psi. You need to make sure you have THAT regulator or the rebuild kit for THAT regulator.
As far as i know all those regulator housings are the same.
DurocShark
PostPosted: Wed Sep 11, 2019 6:59 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
Really? Well, crap. You're gonna make me go out and work on the thing Saturday in 97 degree heat, aren't you? Evil or Very Mad
This thing came on my 2180 with the dual brosols (no idea which ones at the moment) and it was running 3psi.
HBRag
HBRag is offline
PostPosted: Wed Sep 11, 2019 7:00 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
If that is a liquid filled pressure gauge, then it will change reading with increased engine bay temperature. If so that reading will only be accurate when you first start the car.
DurocShark
PostPosted: Wed Sep 11, 2019 8:09 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
That pic was taken cold, engine off, with the electric pump on.
I got the same reading hot with the engine running.
King_vw61
King_vw61 is offline
PostPosted: Wed Sep 11, 2019 8:45 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
Aeromotive makes a low pressure regulator made for 1.5 psi. Just under 200.00. Summit sells them. The holley ones suck.
madmike
madmike is offline
PostPosted: Thu Sep 12, 2019 4:42 am    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
X2 on the Aeromotive Wink
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
slalombuggy
slalombuggy is offline
PostPosted: Thu Sep 12, 2019 5:13 am    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
I used a Malpassi regulator from CB works perfect and less than 1/2 the cost of the automotive fpr.
brad
Jebchevelle
Jebchevelle is offline
PostPosted: Thu Sep 12, 2019 9:42 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
never had a problem with those cheap holley regulators in a carb setup. the rebuild kits are not much like $14-$18 I would rebuild it and make sure everything it clean. also make sure you have the low pressure spring.
jason
jason is offline
PostPosted: Thu Sep 12, 2019 9:51 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
The rebuild kits are $9.99 and comes with both springs around here. I have 3 of those holley regs and haven’t had a problem yet. The insides are basically all the same, a diaphragm and a spring. The bigger the diaphragm, better.
DurocShark
PostPosted: Fri Sep 13, 2019 5:15 am    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
Rebuild kit was $13 including shipping direct from Holley.
Thanks everybody!
67rustavenger
67rustavenger is online now
PostPosted: Fri Sep 13, 2019 6:03 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
brad
^^^^^ I use this! Never a problem.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
DurocShark
PostPosted: Sun Sep 22, 2019 5:20 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
Rebuilt it with the Holley kit. Found some odd crap, but nothing that should impact the pressure. Ball and spring work as they should, but it never goes below 2.5 psi. And that only when running, if I just energize the fuel pump it hits 3psi.
I don't think this is actually the cause of the rich idle problem I have, just eliminating suspects. And since I had no idea about the condition the FPR was in, figured I'd tackle it.
I think it's just crap. Sad
Here's the odd thing I found. On one side of the output, there's what looks like a wall that has rotted away. I'm guessing flashing from the casting process. But it's pretty damn thick. Couldn't chip it out with a screwdriver.
jason
jason is offline
PostPosted: Sun Sep 22, 2019 9:22 pm    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
Whats the fuel pressure without the reg?
DurocShark
PostPosted: Mon Sep 23, 2019 5:12 am    Post subject: Re: Holley Fuel Pressure Regulator Reply with quote
It'll go over 4psi straight off the pump.
OK, yeah. It's not doing nothing at all. Just not what I want it to do.
I did a video of the rebuild...
