67 balljoint adjustable beam
Page: Previous  1, 2
travis1488
travis1488 is offline
PostPosted: Mon Sep 16, 2019 8:34 pm    Post subject: Re: 67 balljoint adjustable beam Reply with quote
travis1488
PostPosted: Mon Sep 16, 2019 8:38 pm    Post subject: Re: 67 balljoint adjustable beam Reply with quote
I couldn't get the pic tured the right way sorry. This is with a 2in narrowed adjustable beam all the way down and drop spindles.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Tue Sep 17, 2019 6:23 am    Post subject: Re: 67 balljoint adjustable beam Reply with quote
That should be acceptable, any lower then you start to cause problems with ball joint angles & (Lack of) suspension travel.
riverart
riverart is offline
PostPosted: Tue Sep 17, 2019 7:20 am    Post subject: Re: 67 balljoint adjustable beam Reply with quote
I would expect it to be a lot lower especially if you are using the drop spindles.
TDCTDI
TDCTDI is offline
PostPosted: Tue Sep 17, 2019 7:26 am    Post subject: Re: 67 balljoint adjustable beam Reply with quote
If you're still using stock length shocks, it's possible that they have bottomed out. Remove the shocks & see if it gets any lower.
travis1488
PostPosted: Wed Sep 18, 2019 7:14 pm    Post subject: Re: 67 balljoint adjustable beam Reply with quote
Any of you that if replied on this post that's smarter than me I'd like to call and discuss this beam issue with someone instead of typing it lol. If you wouldn't mind a call about it PM me your number and a good time for when I can call thanks
Torkwerks
Torkwerks is offline
PostPosted: Tue Apr 11, 2023 6:30 pm    Post subject: Re: 67 balljoint adjustable beam Reply with quote
Did you get this issue resolved, because I have the exact same problem. As soon as I attach the arms to the spindle I get zero suspension travel.
ashman40
ashman40 is offline
PostPosted: Thu Apr 13, 2023 9:08 am    Post subject: Re: 67 balljoint adjustable beam Reply with quote
Some things you can try...
    With all four torsion arms removed, loosen the center adjuster screws and make sure the center disc the springs pass thru rotates freely. Depending on the design of the center adjusters, tightening the screw may bind the disc to the inside of the tube. This is fine once the adjusters are locked in their final position but not great when tryin to make adjustments.
    Slide the springs part way out on one side and slide the opposite side torsion arms into the ends of the tube. Make sure the torsion arms rotate freely when fully seated in the bearing/bushings without being engaged to the ends of the springs. Repeat for the opposite side arms. This confirms the arms rotate freely with minimum friction. If you find one or more arms are difficult to rotate, investigate. Maybe there is damage to the bearing/bushing or the torsion tubes are bent? Or worse case the shaft of the torsion arms are bent?
    Center the springs but leave the center screws loose. Looking at the ends of the tubes are the springs centered in their tubes on both ends? If not it could mean bent springs or bent tubes. Identify which. Lay the springs on a known flat surface and roll them to confirm they are not bowed.
    Slide on just ONE torsion arm into place and confirm it can rotate the center disc/adjuster as you move the arm up/down. Remove that arm and install another and test. Do this for all four arms individually. Next install them in pairs. Is there one arm that specifically makes the spring hard to rotate?
Try the above and confirm everything rotates smoothly before tightening any screws. Also try moving arms side to side and see if it is the tube, the spring or the arm that is causing resistance.
AshMan40
Torkwerks
PostPosted: Thu Apr 13, 2023 3:14 pm    Post subject: Re: 67 balljoint adjustable beam Reply with quote
Thank you for the guidance, I will go through your list thoroughly this weekend and I'll will get back to you with the results.
Page: Previous  1, 2
Page 2 of 2
