Post Your Roof Rack Setup
stuzbot
stuzbot is offline
PostPosted: Thu Oct 10, 2019 12:16 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
One of the few jobs the PO did that actually seems well executed; my van has a Treadplate [I think you lot call it 'Checker Plate'?] roof and, bolted through it, a roof rack made from what looks like thin diameter scaffolding bar.
PO told me he'd intended to use the van as a mobile viewing platform for watching his son Go-Kart racing, hence the weight-bearing Treadplate roof.
Click to view image
1992 VW LT35 2,4D [SOLD]
1993 VW LT35 2,4D [SOLD]
1992 VW T3 1,6TD Syncro [SOLD]
danfromsyr
danfromsyr is offline
PostPosted: Tue Oct 22, 2019 9:08 am    Post subject: Re: Post Your Roof Rack Setup Reply with quote
spotted this on a search.
seems this is as good a place to share the pic as any.
Photo by @elsrdelasfurgos
found on this site
https://vanclan.co/van-life-ideas/
Van Go77
Van Go77 is offline
PostPosted: Sat Nov 09, 2019 1:13 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
Can share where I could get that rack set up for my t3? Thank you
jimf909
jimf909 is offline
PostPosted: Sat Nov 09, 2019 1:28 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
At this point you're seeing a lot of custom one-off racks and you're not clear on which rack you're asking about. I'm in a similar scenario and and deciding between custom (a good fabricator will cost $$) or seeing if I can make an off the shelf solution by commercial rack problem solvers is where I'm at.
- Jim
Butcher wrote:
Guilty as charged.
Steve M.
Steve M. is offline
PostPosted: Sat Nov 09, 2019 4:50 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
In the USA, "Diamond Plate" is used to describe the plate the P.O. used.
50/50 whether I like it! I'm just against the idea of drilling holes in my roof!
outcaststudios
outcaststudios is offline
PostPosted: Sat Nov 09, 2019 7:35 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
this appeals to my interests...
'88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791
jimf909
jimf909 is offline
PostPosted: Sat Nov 09, 2019 8:26 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
Winner!
Have you considered having some fun with the hardware? I was thinking button head screws but these look fun too...
https://www.etsy.com/listing/620838984/forged-scre...gLoePD_BwE
- Jim
Butcher wrote:
Guilty as charged.
outcaststudios
PostPosted: Sun Nov 10, 2019 8:46 am    Post subject: Re: Post Your Roof Rack Setup Reply with quote
oh those are cool, ill have to track some down , im sure MSC has them!
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
space
space is offline
PostPosted: Sun Nov 10, 2019 9:29 am    Post subject: Re: Post Your Roof Rack Setup Reply with quote
Heres mine
Wanted to have the weight on the factory gutters and still be able to lift the top
aluminum Bars are set to my Thule cargo box and my kayaks
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Sun Nov 10, 2019 6:11 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
Hi,
Kinda hesitant about posting, it’s unfinished, unpainted, and forward wind deflector needs re do. But it’s a thing I’ve been dicking with for a while just meant to carry my two 80 watt Siemens glass solar panels ( old school, heavy, not as partial shade tolerant as modern panel, but free).
Turns out I could fit one of my fibreglass waffle type bridging ladder in front of panels.
Rear mounts on rear hinge bolts, front support on new holes .
Oh, yes, 1/4” aluminum and 25-50 aluminum extrusion cross bars.
Alistair.
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
jimf909
jimf909 is offline
PostPosted: Sun Nov 10, 2019 7:22 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
That's a nice rack. Glad you posted it!
- Jim
Butcher wrote:
Guilty as charged.
Vanlife Geek
Vanlife Geek is offline
PostPosted: Tue Nov 12, 2019 12:37 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
I have a BajaRack MegaMule that I found on Craig's list for $50, which was a real find. Came with a cargo net, too. I mounted mine towards the rear for easier pop-top lifting and so I could add lights and a camera off the back. I also mounted two LED lights on both sides. Having it mounted to the rear also allows me to open my roof vent all the way and have room for a couple of solar panels. I still needed Jack Bombay lift assists to pop the top easily but when the rack is loaded, that still isn't enough. The Hi Lift Jack mounted up there certainly doesn't help. I purchased a set of GoWesty list assists and will be adding those to augment the Bombay lifts.
Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era)
jimf909
jimf909 is offline
PostPosted: Tue Nov 12, 2019 3:59 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
A Hi-lift jack or spare tire on the pop-top are heavy and difficult to lift even with struts. The spare for me was the last straw in going too far in strapping stuff to the roof.
Are you using the heaviest gas springs possible with your Jack Bombay lift?
60 psi = JB regular strut
90 psi = JB HD strut
120 psi = JB extra HD strut
* the above each available from Jack Bombay and I *believe* I have the numbers right.
150 psi = super heavy duty, Jack Bombay sent me to Amazon or McMaster Carr when I needed those to compensate for too much crap on the roof.
My point is you may have an option (s) before drilling the van for the GW struts.
Here's a link to the 150 psi gas spring that works with the Bombay system and may just give you the lift you need:
JR Products GSNI-2300-150 Gas Spring https://www.amazon.com/dp/B004LF513G/ref=cm_sw_r_cp_apip_jDub3AlKsyytP
I had a long metal basket and roof-top box when using 150 psi struts:
- Jim
Butcher wrote:
Guilty as charged.
Vanlife Geek
PostPosted: Tue Nov 12, 2019 4:24 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
I contacted Bombay and he said he didn't think the stronger struts would cut it in my case and recommended getting the GW struts as an addition. Perhaps he doesn't sell the 150 psi versions you linked on Amazon... I can't remember the details. I've already drilled the holes in the metal, but am not sure I've got the right struts since they line up at the very front of the pop-top and every picture I've seen shows the top mount back from the front a little further. I need to get it sorted out. I wish I had your link before I bought the GW struts to see if they work as it would have been a relatively inexpensive experiment.
Man, that's a rack and a half you have!
Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
jimf909
jimf909 is offline
PostPosted: Tue Nov 12, 2019 4:52 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
He may have determined that you need a full extra set to accommodate your load. It was quite a rack that eventually encouraged packing too much gear up top and was eventually swapped out with a high-top while moving a lot of storage inside or to the rear hitch.
- Jim
Butcher wrote:
Guilty as charged.
elizer
elizer is offline
PostPosted: Tue Nov 12, 2019 5:50 pm    Post subject: Re: Post Your Roof Rack Setup Reply with quote
I have a full width gary lee hatch rack.
He has half racks since you have a swingaway.
http://www.telusplanet.net/public/gary2a/rack/VanagonRack/VanagonRack.htm
You could move your shovel/hi lift and ease that load off your top.
wolfburger1303
wolfburger1303 is offline
PostPosted: Thu Nov 14, 2019 5:43 am    Post subject: Re: Post Your Roof Rack Setup Reply with quote
[img]
[/img]
1974 VW 1303
1974 VW 1303 S
1987 VW Transporter Doka
Jake de Villiers
Jake de Villiers is offline
PostPosted: Thu Nov 14, 2019 9:17 am    Post subject: Re: Post Your Roof Rack Setup Reply with quote
wolfburger1303 wrote:
[/img]
That's awesome! If you make that logo in the stock size I'd be happy to buy a pair for the van! Very Happy
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
wolfburger1303
PostPosted: Fri Nov 15, 2019 10:05 am    Post subject: Re: Post Your Roof Rack Setup Reply with quote
[/img]
I will try Very Happy .
Where are you from?
1974 VW 1303
1974 VW 1303 S
vanagonjr
vanagonjr is offline
PostPosted: Fri Nov 15, 2019 10:33 am    Post subject: Re: Post Your Roof Rack Setup Reply with quote
ragnarhairybreeks wrote:
Hi,
Alistair.
I think it's just awesome! Also, thanks for the links and maintaining your website- I wind up there several times a year.
Page 7 of 8
