J-Gaz. Samba Member
Joined: November 19, 2007 Posts: 743 Location: 253 Then, Now 206.
Posted: Wed Nov 20, 2019 9:48 pm Post subject: Might be the end of the 70 |
Ok Team.
Looking for encouragement, but seems irresponsible at this point.
Gland nut came loose and apparently the Flywheel bent the Crankshaft.
Just got the report from George @ Porbug.
Can only blame myself as I put it on after replacing the main seal.
Had a torque wrench that was equipt for the job - but as my brother pointed out, it may not have been calibrated...
Who Knows.
Anyway, Shell is in OK shape, needs seals around the front and back window, needs Window Regulators on both sides & It's time for a suspension upgrade. Plus, it would be nice if the interior was cleaned up by the back window & the Dollar bill size hole in the Driverside rear pan was patched... andy maybe the wiring was fresh...
Other than that
and the fact that the engine is toast . . .
She's a fine auto...
So, whats the Verdict.
Stay or go?
Stay = 3750+ tax for the engine (more or less) And drive it, make upgrades when I can. . .
(PS: No shop or garage of my own)
Go = 800 bucks(?) No Beetle & Move on.
How do you Weigh something like this?
The thing I keep coming back to is I've got to street park it in town.
AND, "there's always a list" of "Stuff" to fix.
Having no shop, no garage, and no real place to store it makes this a little less desirable.
Thanks for listening.
Any thoughts, either way, are welcomed. _________________ 1970 Beetle | Basically Stock 1600 SP |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11787 Location: Redding, CA
Posted: Wed Nov 20, 2019 10:56 pm Post subject: Re: Might be the end of the 70 |
If I were in your position, I’d sell the car. You have no place to work on it, and it needs a lot of work. I’d say this to anyone in the same situation.
In fact, I don’t understand why anyone—unless they have a lot of money—would continue to own a vintage car ... unless they do most of the work themselves.
Labor isn’t cheap, and if you can’t supply most of the labor on your own, then be prepared to have others restore the car, piece by part, until it’s all renewed.
If I need a new alternator, carburetor, a brake job, clutch, main seal, wiper motor, wheel bearings, whatever and etc., I can do it myself. I have a garage and a lot of tools, though. I also have another car to use while working on my bug. For those who don’t have these amenities, and don’t do most of the work themselves, I say they should get a newer model car, like a Honda, or Toyota.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
TonyPgh Samba Member
Posted: Wed Nov 20, 2019 11:20 pm Post subject: Re: Might be the end of the 70 |
Tim Donahoe wrote: |
Tim |
I could never afford to pay anyone. If I had to, I would not any vintage cars.
I just did my timing belt and valve cover gaskets, on my Camry V6, that was fun!  |
Tim |
bomberbob Samba Member
Posted: Thu Nov 21, 2019 5:34 am Post subject: Re: Might be the end of the 70 |
I agree, people who own a vintage car but can't do the work themselves, will need to be wealthy. I try and do as much work on my cars as I possibly can because I am not wealthy. Just bought a caster/camber tool yesterday so I can do my own front end alignments on my cars. Tired of paying to have it done. Probably the only twilight zone I have never delved into is automatic transmissions.
Gaz, if you didn't live too far away I might be interested in looking at your project but my wife told me if I bring home another VW she will serve me up with a warm set of divorce papers, so I will have to pass. _________________ 1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1290 Location: IRELAND
Posted: Thu Nov 21, 2019 5:53 am Post subject: Re: Might be the end of the 70 |
Why not buy a replacement running engine or rebuilt long block? |
J-Gaz. Samba Member
Posted: Thu Nov 21, 2019 7:15 am Post subject: Re: Might be the end of the 70 |
baz76 wrote: |
That's an Idea.
But I'd have nowhere to install it.
I dont think the Shop would want to install someone else's motor...
My Uncle used to have a great shop that I used to use, great tools too - but has since moved.
So I'm in an apartment with street parking! ha!
Need to buy a house with a garage!!!
That seems to be the least expensive way to keep the car... Ha!
(Cheap Fix right!) _________________ 1970 Beetle | Basically Stock 1600 SP |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3579 Location: 802 The Pointless Forrest
Posted: Thu Nov 21, 2019 7:17 am Post subject: Re: Might be the end of the 70 |
Where is 206? _________________ "Albatross"! |
raydog Samba Member
Joined: February 09, 2006 Posts: 1206 Location: Cape Cod
Posted: Thu Nov 21, 2019 8:17 am Post subject: Re: Might be the end of the 70 |
It sounds to me like you know what you need to do under the circumstances, and I agree with you. I would move on and get something when life better suits you.
Like Baz said, you can get a cheap used motor to get you through, but in the end , you will still have a car that needs work and no place to fix it. If you like the car that much, what about finding someplace to store it until you are ready?
windfish Samba Member
Posted: Thu Nov 21, 2019 8:18 am Post subject: Re: Might be the end of the 70 |
J-Gaz. wrote: |
That's an Idea.
I dont think the Shop would want to install someone else's motor... |
Depends on the shop.
I haven't asked, but I don't see either of my local shops turning down an engine install. They wouldn't warranty it, but they'd plop it in.
One builds engines, the other does not.
A garage is great, but just a driveway of your own works fine.
Til you have one Tim is probs right, to own a vintage car you really need somewhere to work on it.
Good luck. |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1508 Location: Chicago IL/CHandler AZ
Posted: Thu Nov 21, 2019 8:41 am Post subject: Re: Might be the end of the 70 |
I see both sides. There are reasons that shops do exist. If everyone did their own work, they would not. If you do not have the ability or desire or time to do your own work, have it done as long as the shop is competent (most shops, in my experience, are hacks), and you can afford it and like the car.
If you are not at that point in your life, it may be best to sell it. Old cars can be a lot of fun, but if you do not have the desire/abilty/place to work on it AND you cannot afford it at this time, they can make your life a misery.
Another option of course is to join a local club. I got very involved in my Model A Ford club and members are not only willing but enthusiastic to help each other out. I imagine there must be a VW Club in your area also willing to do the same. Plus you will learn a lot along the way, as long as those members do things right. |
bluebus86 Banned
Posted: Thu Nov 21, 2019 9:11 am Post subject: Re: Might be the end of the 70 |
You can obtain a motor for less money than what you posted. you may consider an used motor as well. as for owning a classic car with no place to work on it, keep in mind millions of folks owned Bugs as daily drivers with no place to work on them.
Of course doing a restoration requires work space, but to maintain it, not much expensive work needs be farmed out.
even with limited space, general stuff like a valve adjust, oil change and tune up can be done in a parking lot in under an hour. You do NOT need a full,on shop, nor even a garage to maintain a Bug, anymore so than if you own a brand new toyota.
Keep the Bug if the body is sound, and she is relatively rust free. source a less expensive engine if need be.
Join a local aircooled VW club, you may find friendly like minded folks there that may offer you assistance in general maintenance, maybe some one has a good used motor for you, maybe club folks can help you with a motor swap. a motor swap can be done in under an hour in a driveway with basic tools, a jack and stands
Good Luck, Keep the Bug! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Thing is with selling vws is regret, I've regretted selling all mine. Just something else to consider. That said an old EF civic would be a cool reliable classic, they are great cars and need little maintenance. My first car was an EF Civic and had 330,000 miles on the clock when I sold it, 330,000 trouble free miles I might add. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33083 Location: Hot Arizona
Posted: Thu Nov 21, 2019 9:22 am Post subject: Re: Might be the end of the 70 |
J-Gaz. wrote: |
Just got the report from George @ Porbug. |
Did George pull the engine to make this determination?
How did George make this determination? Did he just try to turn the engine with a wrench on the crankshaft pulley bolt?
Because I wonder if this could be an instance of just needing to drill new dowel holes and bolt together? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bluebus86 Banned
Posted: Thu Nov 21, 2019 9:31 am Post subject: Re: Might be the end of the 70 |
Also, for the gland nut and rear wheel nut, I dont use a torque wrench, I know my weight, and length of the lever arm I need to stand on to give me the correct torque. Simple, and effective. Using a weight and known lever length is how wrenches can be calibrated, Used to work in a place that calibrated them regularly this way, known weight and lever length for flight hardware for NASA. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Nov 21, 2019 12:32 pm Post subject: Re: Might be the end of the 70 |
When I mentioned that vintage car owners are better off doing most of the work on their cars, I meant “most” of the work. This did not include such items as rebuilding an engine, or transmission. These are items I prefer to farm out. Almost everything else is another matter. Maintenance, interior restoration, brakes, etc., can be accomplished without having a garage, of course.
And, back in the day, millions owned these bugs without having a place to work on them; but back then, those cars were relatively new, and before the Idiot Book was published, most Of those owners relied upon the VW dealer, or the thousands of VW shops to keep their cars running.
Today, 95% of those VW shops are gone, and VW dealers don’t have the expertise to work on forty-year-old cars. Also, the cars are older, and subsequently require more than just maintenance.
I’ve pulled my engine a good five or six times since I bought it in 2012. In 1970, I didn’t even change my own oil. You just took it down to the dealer and he changed it, adjusted the valves, carb, whatever. If you wanted to save money, you had a local non-authorized VW shop do the work. One, I remember in Antioch, Ca, actually cleaned your windows as a courtesy.
Those days of relatively inexpensive farmed-out car maintenance are gone. Our bugs are old. If we want them to be reliable, we pretty much have to replace all the moving parts ourselves.
Vintage car ownership today is simply a hands-on endeavor (unless you have a budget that allows a mechanic to do the work).
Richard O'Brien |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1615 Location: The South Zone
Posted: Thu Nov 21, 2019 2:19 pm Post subject: Re: Might be the end of the 70 |
Let me tell you a little story that might give you some inspiration:
In the late 90's, I relocated from northern Indiana to Anchorage, AK, and drove my Bug to get there. It had a single-port 1500 in it back then (a tougher mule there never was!). A few weeks after I arrived, I took it to get it smogged (back then the car was still "new" enough to require emissions testing to get it registered). On the way to the shop, I heard a strange "PING" and felt the engine shudder briefly, but it kept running so I didn't stop. It failed the smog test, and on the way home, every time I stopped at an intersection or took a right-hand curve too fast, blue smoke would pour out of the exhaust. At the time, I was living at an apartment complex that had an empty gravel parking lot beside it, so I parked my car there and did some investigating. Turns out the #3 wrist pin clip had popped loose (that was the "PING" I heard) and chewed a huge hole into the cylinder wall. So I tore it down right there in the dirt and mud and replaced the cylinder and piston, took it back to get it smogged, and passed with flying colors.
Several years later, my girlfriend at the time decided to leave Anchorage and move back to Massachusetts, and I decided to follow her (she ended up breaking up with me two weeks after I arrived in Mass., but that's a different story!). Once again, I drove my Bug all the way across the country to get there, and just as I was pulling into the driveway of the apartment she had rented (also gravel, and also full of dirt and mud), I hear a loud grinding sound coming from the back of the car. So, I dropped the engine right there in the dirt and sure enough, discovered that the flywheel had come loose. Just like you, and just like the time in Alaska, I didn't have a garage to work in, so I tore it down in the dirt and mud, drilled out the dowel pin holes with a hand drill, hammered in some larger dowels, and torqued that flywheel down as tight as I could get it.
Over the next few years, I ended up driving that Bug back to the mid-west, then down to Miami and back again, and then out to San Diego by way of Denver, where I finally replaced that old 1500 single-port with a beautiful (and very expensive!) mill that I had been planning to build for 30 years or so. Now, it is a work of art.
So ask me if I think it was worth all the suffering and money and doubt and frustration.
Every bit of it!
I will leave you with a quote that always helps get me through whenever I am frustrated with a project and feel like giving up:
"We choose to go to the Moon in this decade and do the other things, not because they are easy, but because they are hard; because that goal will serve to organize and measure the best of our energies and skills, because that challenge is one that we are willing to accept, one we are unwilling to postpone, and one we intend to win, and the others, too." -John F. Kennedy
Cusser wrote: |
J-Gaz. wrote: |
Because I wonder if this could be an instance of just needing to drill new dowel holes and bolt together? |
I want to add something to this, too. I think the Cusser is spot on, here. I won't say it's not possible, but I have never personally heard of a loose flywheel actually "bending" the crankshaft, not in a stock engine, at any rate. Usually it just wobbles out the dowel holes and dings up the mating surfaces pretty good. That $3800 price tag sounds like what we call in the business "F-off money." When a mechanic doesn't really want to do a job, he tells the owner of the car it will cost an outrageous amount of money to fix it, in the hopes that the owner will just take his car and "f-off", and if he's a big enough sucker to actually pay it, then what the hell, at least the mechanic will make bank on the job.
It wouldn't surprise me if your engine just needed to have the flywheel and crank cleaned up and re-doweled. It's not difficult to do, but it's a pain in the ass and your mechanic won't make any money doing it, nor will he be able to guarantee the work. As mentioned above, you can buy brand new engines for less than $3800.
Good luck with whatever you decide to do! _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Thu Nov 21, 2019 3:35 pm Post subject: Re: Might be the end of the 70 |
Well said, Floating VW! _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
J-Gaz. Samba Member
Posted: Thu Nov 21, 2019 3:40 pm Post subject: Re: Might be the end of the 70 |
calvinater wrote: |
Where is 206? |
@Calvinater - 206 is the Prefix for Seattle. _________________ 1970 Beetle | Basically Stock 1600 SP |
J-Gaz. Samba Member
Posted: Thu Nov 21, 2019 3:46 pm Post subject: Re: Might be the end of the 70 |
@Cusser,
Yeah, he pulled it.
and last I ran it I did notice the Front (Rear) Crank Pully Wobble so bad it through the Generator Belt.
I didn't know what to make of the wobble but do now.
It's not something I mentioned to the Shop when I took it in either...
Cusser wrote: |
J-Gaz. wrote: |
