notchboy Samba Member
Joined: April 27, 2002 Posts: 22668 Location: Escondido CA
Posted: Fri Sep 30, 2016 11:23 am Post subject: Re: factory headlight washer system? |
I dont know why its like that - pump seems to work fine. I made sure its all clear too. I need to play with it more.
How did you mount the overrider? Did you drill a hole through the rubber strip? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Globusoverland Samba Member
Posted: Fri Sep 30, 2016 11:57 pm Post subject: Re: factory headlight washer system? |
Yes, I did. I had to. And it is a tricky part .
You have to be 100% sure the trim is installed properly before making the drill marks. You need to draw back the metal sheet strip and drill a hole in the centre of of it. The correct hole will leave you enough sheet material to re-install the trim properly and keeping the possibility of tensioning it. Dont forget to treat the holes afterwards with some rust protector.
Take your time to do this project. Measure and re-measure! Get a beer and re-measure again. (As well for cutting out the material from the washers!) You've got only one chance, because once drilled wrongly (read: too much up or down), you need to replace the metal strip. It wont be strong enough anymore. Besides that, with the washers installed and the holes drilled wrongly, you wont be able to tension the strip properly.
I am glad my project is over and finished. I am very happy with the result because everything went so smooth. But, it took me more than 5 years to get it started. I was quite in doubt whether doing it or not. (In terms of succeeding the way it should )
Good luck buddy. And keep up posting pics. |
Posted: Sat Oct 01, 2016 9:46 am Post subject: Re: factory headlight washer system? |
That was going to be another question - is there a metal strip in the rubber? I was not sure.
I'm glad you found it and succeeded in making the modification. There is hope for me then
That was the bad news. The good news is I have two sets of the overriders -
Good to hear all this new. Thanks again Globusoverland for getting it done  _________________
t3kg wrote: |
1964 1500 S
Posted: Sun Oct 02, 2016 5:30 am Post subject: Re: factory headlight washer system? |
Happy to help. Let me know when more help needed. Please keep updating pics!  |
Posted: Sat Oct 15, 2016 10:51 am Post subject: Re: factory headlight washer system? |
Id like to give a shout out and thanks to chimneyfish. He offered up am overider bolt cover cap to me through a PM.
I offered to pay - but he decided to just pay it forward. I have the two for a set I have - but one was buggered up. He sent me a better one on the house, hooking a brother up.
chimneyfish - thanks again brother
t3kg wrote: |
1964 1500 S
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Mon Nov 06, 2017 7:35 pm Post subject: Re: factory headlight washer system? |
Stuartzickefoose wrote: |
Otis, why haven't I seen your bus yet in person? |
Thanks for your help getting those intermittent wipers set up.
_________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
Posted: Mon Nov 06, 2017 7:41 pm Post subject: Re: factory headlight washer system? |
notchboy wrote: |
Did you get it all working and squirting? I was only able to get one to squirt. I bought some other pumps and might go with one pump per squirter like modern cars do.
The Vanagon headlight washer has a valved splitter that equalizes the pressure between the two nozzles. Did you get this sorted?
If not, I have a spare of the T3 part that could solve it. _________________ 1978 Sage Green P22 Westfalia
Posted: Mon Nov 06, 2017 8:42 pm Post subject: Re: M-288 Factory headlight washer system? |
What do you have? I think my main pump for the headlights took a dump. I bought two inline modern squirters I hope to do the fix.
Let see the T3 one. _________________
t3kg wrote: |
1964 1500 S
Posted: Wed Nov 08, 2017 8:07 pm Post subject: Re: M-288 Factory headlight washer system? |
I have a spare of the big head light squirter as well, never used it and not planning on drilling the front. Untested though, but was sold as a working unit.
Here are pics of the T3 washer fluid splitter, The fluid will take the path of least resistance without an equalizer valve.
Posted: Wed Nov 08, 2017 8:19 pm Post subject: Re: M-288 Factory headlight washer system? |
A little off topic, but I was at the PS Speicher Museum in Einbeck last month. https://ps-speicher.de/en/ They have an exhibition on the 50 years of the Type 2 VW Kombi. I noticed one of the busses there that was a Police Bus had a very unusual windshield washer set up that I had not seen before.
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3232 Location: South Benfleet, Essex, UK
Posted: Mon Dec 30, 2019 9:49 am Post subject: Re: M-288 Factory headlight washer system? |
In the near future, I shall hopefully be joining the club of those with electrically-pumped headlamp & front-windscreen washers.
Noting that the 8 litre water tank has only one hose outlet, how does one connect the windscreen-washer pump to the water supply?  _________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
Posted: Mon Dec 30, 2019 11:54 am Post subject: Re: M-288 Factory headlight washer system? |
You have to put in an inline T to service both squirters - after the pump. I have yet to see a qualified club member with working washers, me included.  _________________
t3kg wrote: |
1964 1500 S
Posted: Tue Dec 31, 2019 3:43 am Post subject: Re: M-288 Factory headlight washer system? |
notchboy wrote: |
You have to put in an inline T to service both squirters - after the pump. I have yet to see a qualified club member with working washers, me included.  |
At some time in the not too distant future, I hope to have all of the minimum necessary parts to upgrade my RHD – right-hand drive, British specification, 1973 model-year, VW “1600” Type 2 Westfalia Continental motor-caravan, with the M-288 electrically-pumped headlamp-washer & windscreen-washer system.
Official 1968~79 VW Type 2 Replacement Parts Catalogue, Page 55, Items 5A to 5E (front-bumper over-rider parts)
https://volkswagen.7zap.com/en/rdw/typ+2+syncro/t2/1976-29/7/707-55000/
Page 55, Item 5A => Front bumper, rubber-covered left & right hand over-riders (2 off) (VW part Nos. 211 707 155 & 211 707 156)
Page 55, Item 5B => Hollow spacer (NLA) (2 off) – substitute custom-made stainless steel or nylon part of appropriate length, if not already present
Page 55, Item 5C => A8 washer (VW part No. N 0115 2520) (2 off) – substitute generic zinc-plated steel or stainless steel washer of appropriate size, if not already present or readily available second-hand
Page 55, Item 5D => M8 x 50 mm socket-head bolt (VW part No. N 0402 622) (2 off) – substitute generic zinc-plated steel or stainless steel socket-head bolt of appropriate size
Page 55, Item 5E => Over-rider trim-cover-cap (VW part No. 211 707 182) (2 off) – these are desirable & appropriate items, of which I would ultimately like to have a complete set of 2+2 for the front & rear bumpers.
Official 1968~79 VW Type 2 Replacement Parts Catalogue, Page 102-10, Items 1 to 21 (headlamp-washer system components)
https://volkswagen.7zap.com/en/rdw/typ+2+syncro/t2/1976-29/9/955-102010/
Page 102-10, Item 1 => Headlamp washer jet (VW Part No. 113 955 185) (2 off)
Page 102-10, Item 1A => Headlamp washer-jet seal (NLA) (2 off)
Page 102-10, Item 2 => Headlamp washer-jet connector cum non-return valve (VW Part No. 113 955 187) (2 off)
Page 102-10, Item 3 => Hose or hose-guide or hose-stiffener? (2 off ?)
Page 102-10, Item 4 => Headlamp washer-jet retaining spring (VW Part No. 113 955 199) (2 off)
Page 102-10, Item 5 => Headlamp washer-pump relay (NLA | VW part No. 113 955 200) (1 off)
Page 102-10, Item 6 => Windscreen-washer & headlamp-washer, washer-fluid reservoir (VW part No. 211 955 449) (1 off)
Page 102-10, Item 7 => Washer-fluid reservoir retaining clip (NLA) (1 off ?)
Page 102-10, Item 10 => Washer-fluid reservoir, filler-cap (1 off)
Page 102-10, Item 11 => Steering-column mounted, combination switch, for windscreen wipers & washers (electrically pumped) and headlamp washers (electrically pumped)? (1 off) - 1973~74 or 1974 VW Type 2
Page 102-10, Item 12 => Headlamp-washer, washer-fluid, electric pump (VW part No. 211 955 679) (1 off)
Page 102-10, Item 15 => Headlamp-washer, T-piece hose-connector (VW Part No. 113 955 975 B) (1 off)
Page 102-10, Item 16 => Front-panel grommet for headlamp-washer hose (VW Part No. 111 971 907) (2 off)
Page 102-10, Item 17 => Hose clips (6 off)
Page 102-10, Item 18 => Low-pressure, headlamp-washer hose – 570 mm length cut from 5 metre coil of hose (VW Part No. 1J0 955 964 F) (1 off)
Page 102-10, Item 19 => High-pressure, headlamp-washer hose – 200 mm length cut from 5 metre coil of hose (VW Part No. 1J0 955 964 F) (1 off)
Page 102-10, Item 20 => High-pressure, headlamp-washer hose – 850 mm length cut from 5 metre coil of hose (VW Part No. 1J0 955 964 F) (1 off)
Page 102-10, Item 21 => High-pressure, headlamp-washer hose – 580 mm length cut from 5 metre coil of hose (VW Part No. 1J0 955 964 F) (1 off)
I would imagine that a generic T-piece and high-pressure hose of the correct bore, would be a suitable alternative to the original VW Type 2 headlamp-washer T-piece hose-connector (VW Part No. 113 955 975 B) & hose (VW Part No. 1J0 955 964 F).
It will be “interesting” to see whether there will be any additional complications associated with transplanting this system into a RHD vehicle; possibly the first such vehicle to be so equipped!?! I hope it’s easier to refill the large 8•0 litre capacity, black-plastic washer-fluid tank, than it has been to refill the original lozenge-shaped, air-pressurised, circa 1•0 litre capacity, white-plastic windscreen-washer-fluid reservoir and re-pressurise it using a hand or foot operated pump, given the relative location of the RHD steering column, steering wheel & three pedals.
Once I have completed a trial fitting of the black-plastic washer-fluid tank, I need to investigate where & how I can retro-fit home-made under-dashboard parcel shelves; either two of half-width or one of full-width.
I recently managed to scrounge some long off-cuts of 9 mm x 250 mm & 9 mm x 300 mm boards (white uPVC, domestic, end-of-gable-roof trim boards with a circa 20~25 mm lip), which I think will be ideal for the purpose. To ensure that the screw-top & filler-neck of the black-plastic washer-fluid tank are accessible, it will probably be necessary to position the parcel shelf, level with or below the top of the tank.
Looking at the 8•0 litre capacity, black-plastic washer-fluid tank [VW part No. 211 955 449], there is only a single large-diameter fluid outlet, corresponding to the headlamp-washer hoses’ internal-diameter.
However, there seems to an additional small-diameter hose-connection of some sort, on what I imagine to be the inlet port of the headlamp-washer pump [Hella part No. 8WM 002 792-03 | VW-Audi part No. 211 955 679], which I suspect might be the low-pressure connection to the windscreen-washer pump [VW-Audi part No. 823 955 651]. Am I correct in this supposition?
Having yet to find any photographs or schematic drawings of how the headlamp-washer pump & hoses are located, orientated and shaped, I am interested to find out more about the factory-stock installation and whether a more maintenance-friendly configuration has been designed?
Would I be correct in thinking, that inside portions of the headlamp-washer hose, where there are small-radius bends, there should be an internal stainless-steel helical spring of some sort, to prevent kinking of the hose? I have something like this for the ½-inch garden hose, where it connects to the outlet, on my wall-mounted, Hasel through-feed hose reel. _________________ Regards.
Nigel A. Skeet
Posted: Tue Dec 31, 2019 7:43 am Post subject: Re: M-288 Factory headlight washer system? |
All the original hose I got with my system is just larger diameter cloth braided German stuff. No visual reinforcement for kinking. _________________
t3kg wrote: |
1964 1500 S
Posted: Fri Jan 10, 2020 9:07 am Post subject: Re: M-288 Factory headlight washer system? |
Opening my parcel from Christer Persson in Sweden, the water tank, headlamp-washer pump and windscreen washer pump appear to be in good condition, although I haven't yet had the opportunity to check the functionality of the pumps. However, the front-bumper over-riders are in very poor condition in my opinion and they are NOT a matched pair.
DAMAGED M-288 "headlamp-washer" over-riders from Christer Persson
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987833
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987832
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987831
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987830
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987829
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987828
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987827
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987826
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987825
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987824
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987823
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1987822
A few of the photographs clearly show that BOTH over-riders are same-handed and bear the same part number 211 707 155, rather than having a matched pair with slightly different part numbers 211 707 155 & 211 707 156, ending in 5 and 6 respectively. The direction of the chamfer, emphasised by the sloping pencils, suggest that they might both be left-handed; considering the horizontal curvature of the 1973~79 VW Type 2 style front bumper.
The distorted top of one over-rider and consequent splitting of the rubber in that area, can also be clearly seen. The long, wide splits in the rubber along the backs of the over-riders, associated with severe flaky corrosion of the underlying steel, would have been obvious even to someone who is half blind, and one can see that some of the flaky steel is already missing. If I were to probe the remaining flaky steel with a screw-driver or other implement, I am sure it would be easily dislodged; noting that flakes drop off of their own accord, when the over-rider is handled.
Given that the underlying, structural steel components of the over-riders are largely encapsulated within the rubber, I doubt whether they could be temporarily removed to repair the distortion of one and the major corrosion damage to both. Removal of the encapsulating rubber would probably further damage the rubber (probably irreparably!), so I doubt whether the repaired steel over-rider cores could be re-encapsulated within the original rubber.
The following pictures of undamaged, good-condition over-riders, found in The Samba Gallery, shows what those purchased and sold by Christer should have been like:
1974~79 VW Type 2 headlamp-washer system – good condition
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1842469
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1842468
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1842467
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1842466
Nigel A. Skeet
Posted: Fri Jan 10, 2020 9:17 am Post subject: |
Tcash wrote: |
Ran across this. 1974up_headlight_washer. In wiring diagrams.
Looking at the electrical-circuit wiring diagram above, I deduce that the wiring colours, wire cross-sectional area and connected terminals are as follows:
I have yet to formally translate the German text, but off-the-cuff, I interpret the component labels, terminal labels, wiring colours & sizes to be as follows:
https://www.deepl.com/translator
E – Schalter für Scheibenwisher => Switch for windscreen washer - Switches for windshield wipers
E1 – zum Lichtshalter Klemme 56 => to light switch terminal 56 - to light holder terminal 56
J39 – Relais für Scheinwerfer Reinigungsanlage => Relay for headlamp (?) - Relay for headlight cleaning system
S1 – An Sicherungshalter Klemme X (10. Sicherung) => on fuse-box terminal X (fuse No. 10) - To fuse holder Terminal X (10th fuse)
S2 - An Sicherungshalter Klemme 30 - To fuse holder Terminal 30
V – Scheibenwischmotor - wiper motor
V5 – Scheibenwashpumpe - windscreen washer pump
V11 – Pumpe für Scheinwerfer-Reinigungsanlage - Pump for headlamp cleaning system
Switch E, terminal-31 => brown/black cable (0•5 mm²) => Relay J39, terminal-S
Switch E, terminal-53 => black cable (1•0 mm²) => Wiper motor V, terminal-53
Switch E, terminal-53a => black/grey cable (1•0 mm²) => Wiper motor V, terminal-53a
Switch E, terminal-53a => black/grey cable (1•0 mm²) => Fuse S1, terminal-X
Switch E, terminal-53b => black/yellow cable (1•0 mm²) => Wiper motor V, terminal-53b
Switch E, terminal-53c => red/black cable (1•0 mm²) => Wiper motor V, terminal-53c
Switch E, terminal-53e => green cable (1•0 mm²) => Wiper motor V, terminal-53e
Relay J39, terminal-P => red cable (6 mm²) => Headlamp-washer pump motor V11
Relay J39, terminal-S => brown/black cable (0•5 mm²) => Washer switch E, terminal-31
Relay J39, terminal-30 => red cable (6 mm²) => Fuse S2, terminal-30
Relay J39, terminal-31 => brown cable (0•5 mm²) => Earth
Relay J39, terminal-56 => white/black cable (0•5 mm²) => Headlamp switch E1, terminal-56 _________________ Regards.
Nigel A. Skeet
Posted: Fri Jan 10, 2020 10:34 am Post subject: Re: M-288 Factory headlight washer system? |
Sorry to hear they are no a set. But I tell you what, even with the flakey corrosion, those are in good nick compared to what I've seen. Pulling as much of the rusty bits out, filling and clamping the gaps with epoxy will do the trick. Im surprised these overriders last as long as they do in the elements. _________________
t3kg wrote: |
1964 1500 S
Posted: Sat Jan 11, 2020 9:38 am Post subject: Re: M-288 Factory headlight washer system? |
notchboy wrote: |
Sorry to hear they are no a set. But I tell you what, even with the flakey corrosion, those are in good nick compared to what I've seen. Pulling as much of the rusty bits out, filling and clamping the gaps with epoxy will do the trick. Im surprised these overriders last as long as they do in the elements. |
If you have come across M288 bumper over-riders worse than those, I hope that you found them in the scrap bin rather being offered for sale!  _________________ Regards.
Nigel A. Skeet
Posted: Sat Jan 11, 2020 9:47 am Post subject: Re: M-288 Factory headlight washer system? |
Here is the headlamp-washer pump with which I was supplied. It looks good, but if it doesn't pump water I will be livid!
The small spigot which connects to the large spigot, had a shortened length of small-bore transparent tubing (would originally been 200 mm long I believe) attached to it, which I think would have connected to the inlet of the electric windscreen-washer pump.
These are the damaged windscreen-washer jets with which I was supplied; one of which has a retaining barb ripped off.
Nigel A. Skeet
Posted: Sat Jan 11, 2020 4:14 pm Post subject: Re: M-288 Factory headlight washer system? |
You will be lucky if the pump works. Mine worked for a day, then pooped out. Ive since bought two modern ones to fit inline to replace it. Id toss those windshield squirters in the bin. They are cheap to buy new with the two or thee holes. Same with the original pump for the windscreen. Its an old early Golf type pump. Loud as shit and takes a minute to pump up. Ive since bought a replacement for that as well.
The only value in your purchase is the tank, column switch, relays, wiring harness & overriders, the rest is rubbish or will be soon. _________________
t3kg wrote: |
1964 1500 S
