Pertronix Distrbutor Choices 1915
Nightshift
Nightshift is offline
PostPosted: Mon Jan 13, 2020 4:26 pm    Post subject: Pertronix Distrbutor Choices 1915 Reply with quote
I have a Chenoweth, street driven with a 1915cc/Engle 120/9.5-1/compression/Mofoco Heads. Currently has a 009 mechanical advance and running a Bosch blue coil. I am considering a new Pertronix distributor. I see they have a few choices. Should I change to Vacuum advance or stick with mechanical and still multiples to choose from either way I go?
I would like to keep the blue coil if that helps. What one and why?
Thanks Ken
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jan 13, 2020 4:52 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
Get the cb magnaspark. The pertronix are of low quality.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Nightshift
PostPosted: Mon Jan 13, 2020 5:06 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
Thanks Glen, I will do some research on them. Not much more money.
JWHracing
JWHracing is offline
PostPosted: Tue Jan 14, 2020 8:02 am    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
Agreed with Glenn. Absolute best bang for your buck and great performance. I have had mine for 4 years with 0 issues.
65 Baja - Class 5 Unlimited Race Car
2021 STORR Pro Air Cooled Buggy Champion
2019 AZOP Unlimited Buggy Champion
2017 SADR 1300 Class Champion
2016 AZOP Limited Buggy Champion
Currently "retired" from racing
Nightshift
PostPosted: Tue Jan 14, 2020 6:29 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
I will be ordering the kit Wednesday. I run the blue coil at this time. Any thought on the one that comes with the kit? Also a light rail like mine driven on the streets mostly, what weight and spring recommendations?
Thanks
Mr. 010
Glenn is offline
PostPosted: Tue Jan 14, 2020 6:53 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
Thanks
It depends on the engine specs, not the vehicle.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jimmyhoffa
jimmyhoffa is offline
PostPosted: Tue Jan 14, 2020 6:56 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
Thanks Ken
Quite a coincidence! I have a Chenowth rail, street driven, 1915 with MOFOCO heads. Came from an old Bosch 009 to the CB Magnaspark, and love it. Just buy the kit with their coil- nice powerful spark.
1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous.
Nightshift
PostPosted: Wed Jan 15, 2020 2:52 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
1915cc/Engle 120/9.5-1/compression/Mofoco Heads/1.1-1 rockers,IDF44
Magnaspark is on the way. Happy.
jimmyhoffa
PostPosted: Thu Jan 16, 2020 9:56 am    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
Single 44IDF centermount or duals?
Nightshift
PostPosted: Thu Jan 16, 2020 6:13 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
Single IDF 44, I had a sacrificial exhaust left over from when I bought the rail. I installed it and did some Delta P testing across the 4 exhaust outlet to the mufflers downstream side to make sure I would have enough exhaust flow.(4"h20 depreciation) I broke out the Tig welder and made some stainless steel piping and welded on a flanges to pipe leaving the #4 ex port and into the downstream side of the muffler. Manifold heat works well. Runs much better. A work in process, Nice car, clean. Engine was a mess when I bought it, it has come around.
New distributor going in and re-jet again. LOL.
jimmyhoffa
PostPosted: Thu Jan 16, 2020 7:45 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
What will really amaze you is how little Delta P it really takes! Check out some stock VW Thing exhausts, they get the differential they need simply by how the heat flange tube enters the #2 cylinder and exits the #4. I also kind of assume that one direction would be better than the other just based on firing order, if you take the #2 to #4 flange approach. I believe it's Vintage Speed that has an exhaust that uses little scoops kind of like VW did with the Thing, it apparently works well without porting to after the collector like you did. Who would have thought! I like your way too. It's a sure fire way to a result without needing to corral exhaust pulses with a little scoop.
How's that bad boy idle with a Centermount and an Engle 120? I'd love to see a video!
Nightshift
PostPosted: Thu Jan 16, 2020 8:00 pm    Post subject: Re: Pertronix Distrbutor Choices 1915 Reply with quote
The distributor should be arriving next week. A bit of ingenuity out in the shop and I should be able to tune the advance for a bit more lower end. I gave a thought to the 2/4 exhaust pulse. I did not want to deal with any reversion during valve overlap. The fact is I did not have enough cam specs to run it on my simulator. So out the exhaust (Muffler) it went.
Jimmy Hoffa You have a PM
