dabaron Samba Member
Joined: June 21, 2018 Posts: 2693 Location: Philly, mang
Posted: Mon Jan 27, 2020 2:54 pm Post subject: The mania deepens: 1991 Full Westy rescue |
i am finalizing the sale and bringing home a 1991 full westy tomorrow. it was a backyard find in NJ and sat for over a decade before being rescued recently by a very interesting gentleman. he spent some time getting this running and replaced the tires with Hankook RA-08's before driving it about 10 miles to his house. it's not a beauty queen and has some minor rust, a few dings, a crunched right rear wheel arch and there is some seam rot on the driver's side rear that will need addressed. i'm going to have it towed the 50 miles to my house since there is no way i'm driving this, esp. since it has to go over the Delaware River on the PA turnpike!
the engine will need some work since both heads leak coolant until things heat up, then it just drips coolant. it will need all new belts, hoses, and fuel lines. it has just under 120k on it so it might have a few years on the bottom end until i need to be concerned. i'll check the torque on the head bolts, check the oil pressure and do compression and leak down tests to see how it looks overall. i'm thinking i might be able to drop the engine and just do the top end reseal, water pump, and anything else that jumps out at me while it's on the bench.
the tencentlife heads are tempting, it really depends on what i find when i pull the heads. i may end up putting the split case rebuild i did last year for the tintop into the westy to get it going and do a full rebuild later this year. that would be a fun project to do with my 12 year old son.
there are some electrical issues to be sorted out. the power door locks do the cycle routine, the turn signal LED is constantly on (water in the lenses), and the ignition switch will need replaced. it is being started by shorting the starter with a screwdriver. there appears to have been an alarm system and remote starter added and that will need to be addresed as well. i'll check the operation of the windows when i pick it up.
as you will see, this is a bit of a project which i hope to have roadworthy and camp ready for Vanagons in the Valley 10 this July in Duncannon, PA. it's a lofty goal, but it's good to have a deadline to work toward.
on to the pictures!
i think the rust on the front is from water getting behind a bra. in the photo the area is still wet from power washing it so it looks worse than it is, the seams on each end are good. a bit of sanding, some build up primer, more sanding, and a rattle can of LA5B and clear coat should do the trick (i'm being optimistic).
the tent is well past it and will be replaced with a Bus Depot three screen model.
the skylight will need to be completely replaced. it was covered with a large baking sheet with a tire to hold it in place, but it has allowed water in over the years. the pop top latch will need refurbished, i'm planning on getting this powder coated or painting it with a hammer finish. the pop top will get a bleach solution treatment and allowed to air out when i replace the tent.
the driver's lower seam is rust free. the LP tank will need to be wire brushed and have updated fittings added before it can be used safely.
the rear hatch is in good shape. it will need new struts and the electric lock actuator fixed/replaced.
nothing a bottle of bleach, a box of magic erasers, and a shop vac can't sort out, right? i plan on removing the interior and really giving this a good cleaning. i'll remove the insulation behind the kitchen and check for leaks around the ports. i'll most likely replace all three of them.
i have my work cut out for me, but the cabinets are in good condition and all the curtains are intact. all fabric items will be washed and all surfaces sprayed with a bleach solution.
this is the worst of the known rust. i'll remove the rust and apply a rust convertor and then primer and paint it when i do the front. at some point in the future i'll replace the panel but slowing the rust is the priority.
i haven't told my son about the westy yet. having his own space i think will make trips more enjoyable. of course i'll need to install a USB port up there so he can charge up his phone or plug in an LED light so he can read. i can't wait to see the look on his face when he sees this parked out back.
there is no way i would consider buying this if i had not cut my teeth on the 1990 tintop. it has given me the confidence to tackle this project knowing that no matter what trouble i find or corner i back myself into, i can seek out advise/help here on thesamba. _________________ 1991 Vanagon GL Camper
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15332 Location: Syracuse, NY
Posted: Mon Jan 27, 2020 2:59 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
Nah man, that's not how it works here.
we helped you out on the 1st one.. this one's on you..
/JK nice score man.. and congrats on moving on up
dabaron wrote: |
there is no way i would consider buying this if i had not cut my teeth on the 1990 tintop. it has given me the confidence to tackle this project knowing that no matter what trouble i find or corner i back myself into, i can seek out advise/help here on thesamba. |
Posted: Mon Jan 27, 2020 3:03 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
danfromsyr wrote: |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6921 Location: Fort Lauderdale, Fl.
Posted: Mon Jan 27, 2020 3:08 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
A large hammer and a larger vocabulary will fix anything.
Good find!  _________________ This free advice is worth exactly what you paid for it.
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 351 Location: Atlanta, GA USA
Posted: Mon Jan 27, 2020 3:49 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
Looking forward to watching your progress!
I've become a big fan of using Boraxo instead of bleach on the ceiling. Worked wonders for me. _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right directionโ - unknown |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32983 Location: Reading Pennsylvania
Posted: Mon Jan 27, 2020 5:35 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
djkeev wrote: |
When is the divorce? |
7 years ago
only thing breaking my heart is the Digifant FI system _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
HackAl Samba Member
Joined: March 12, 2016 Posts: 343 Location: Bergen County, NJ
Posted: Mon Jan 27, 2020 5:59 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
We own the same van. Same year, same color. We don't have power locks or windows. We camp often and use it every weekend in the summer. This will be our 5th season. We love it like the day we bought it. Our daughter is also 12.
I was eyeing this van on FB marketplace and asked the seller to contact me if he decided to part it out as I could use a better sliding door and rear hatch. He was confident he'd sell it. I looked at it again and thought,- yeah someone who knows what they are doing will snatch this up, clean it, get some use out of, make repairs, get some more use out it, etc.
I'm glad it found a good home.
Maybe I'll see you in the Valley!
Best,
Al _________________ 91 Westy.
Ever consider temporarily trading your van? Join the list. |
Posted: Mon Jan 27, 2020 6:08 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
B.O.B.Wanders wrote: |
I've become a big fan of using Boraxo instead of bleach on the ceiling. Worked wonders for me. |
are you making a paste or diluting it pretty heavily to make a "wash" with it? _________________ 1991 Vanagon GL Camper
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12160 Location: Port Manteau
Posted: Mon Jan 27, 2020 8:04 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
Don't eff it up...we're watching |
elizer Samba Member
Joined: May 02, 2016 Posts: 1501 Location: Northern Virginia
Posted: Mon Jan 27, 2020 8:15 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
The underbody looks like it may be really clean.
Dont forget to add the mattress cover and top bunk mattress cover to the wash too! Dont use high heat or your will kick yourself putting the cover back on the bunk mattress cover.
Looking forward to this! |
Posted: Tue Jan 28, 2020 11:44 am Post subject: Re: The mania deepens: 1991 Full Westy purchase |
ignoring the recent thread DO NOT BUY A VANAGON, i am throwing caution to the wind and moving forward with the purchase. unless i discover a show stopper when i give it another once over, this is a done deal.
i fully plan on popping the top and then popping a top and having a cold one in the new to me Vanagon this evening. _________________ 1991 Vanagon GL Camper
joetiger  Samba Member
Joined: January 27, 2005 Posts: 5220 Location: denver
Posted: Tue Jan 28, 2020 12:17 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
Congratulations! Can't wait to see it returned to its former glory. And it's my favorite color. _________________ Joe T.
'02 Baja-ish Beetle "Bubbles"
Check out my book: Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com
www.pigpensyncro.com |
Posted: Tue Jan 28, 2020 5:43 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
well, the deal is done. anyone want to buy a 1991 Vanagon Westy?
it's going to be a large amount of cleaning. found some dead critters in the closet. what have i gotten myself into?
elizer Samba Member
Posted: Tue Jan 28, 2020 6:55 pm Post subject: Re: The mania deepens: 1991 Full Westy purchase |
I applaud you on your color choice |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Wed Jan 29, 2020 12:49 am Post subject: Re: The mania deepens: 1991 Full Westy purchase |
"Critters in the closet"
better do some searching on mice damage and prevention. _________________ This free advice is worth exactly what you paid for it.
jimf909 Samba Member
Posted: Wed Jan 29, 2020 1:13 am Post subject: Re: The mania deepens: 1991 Full Westy purchase |
You had me at: "it currently starts by shorting the starter with a screwdriver". I love that feature!
I sure enjoyed your previous engine rebuild and the naysayers (were they all on fb?). I also like your camping trips with the kid. Most of what needs to be fix d looks tedious but doable. Also, I have great memories of learning about cars, motorcycles, etc. with my dad. The skills gained have been helpful; the time spent with dad is the best of all.
Enjoy. _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1377 Location: Halifax, N.S.
Posted: Wed Jan 29, 2020 5:37 am Post subject: Re: The mania deepens: 1991 Full Westy purchase |
12 years ago that would have scared the life out of me!
Now, except for the bodywork, I'd be all in for the right price.  _________________ 2020 T@B 320 Teardrop(Has been van guy)
21 Ford Ranger XLT
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23616 Location: NYC/Upstate/ROW
Posted: Wed Jan 29, 2020 6:11 am Post subject: Re: The mania deepens: 1991 Full Westy purchase |
Most excellent.
In Berkeley all week, scoping Vanagons _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
