67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Wed Apr 01, 2020 7:53 pm Post subject: “Newer style” doghouse any good? |
I currently have the squared doghouse with heater ducts.
I’m considering the newer one from cb or scat that is rounded.
Questions:
Will I be able to utilize my current flaps?
Does it cool as well as my current one? (Or close)
Any recommendations as to brand on quality?
I do prefer the rounded ones and will NOT be running heater boxes. _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Wed Apr 01, 2020 8:12 pm Post subject: Re: “Newer style” doghouse any good? |
The rounded style shrouds are called 36 horse style because they are the same shape as the original 36 HP fan shroud. They are not new they have been around for 30 years.
There is extreme controversy about using them. I feel they cool fine. I have one on my 2165 & 2276 and neither use any auxillary oil cooler. I personally DO NOT run flaps on any engine that does not use the heater boxes. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Wed Apr 01, 2020 10:43 pm Post subject: Re: “Newer style” doghouse any good? |
They all fit crappy, so just buy from wherever. They work fine, but if you have a German ahroud now, I suggest you use it only because they're more valuable. Blast and repaint. Done. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
db69 Samba Member
Posted: Wed Apr 01, 2020 11:50 pm Post subject: Re: “Newer style” doghouse any good? |
vwracerdave wrote: |
There is extreme controversy about using them. I feel they cool fine. I have one on my 2165 & 2276 and neither use any auxillary oil cooler. I personally DO NOT run flaps on any engine that does not use the heater boxes. |
X2
Although i do use an external and stock cooler on my 2332 (probably overkill but to me it’s cheap insurance) |
pupjoint Samba Member
Posted: Thu Apr 02, 2020 12:51 am Post subject: Re: “Newer style” doghouse any good? |
I like the stock shroud for the same reasons mentioned here, but I had to use the 36hp aftermarket shroud on my recent build due to clearance issues on my 2332. I have not seen any engine yet to be damaged by the lack of cooling from these shrouds yet and they have been around for many years. I have also yet to see any real data that they cool less than the German doghouse. All so far have just been opinions. |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2557 Location: Seekonk,Massachusetts USA
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7861 Location: Videbaek Denmark
Posted: Thu Apr 02, 2020 10:32 am Post subject: Re: “Newer style” doghouse any good? |
There are at least 3 different manufacturers of the aftermarket 30 hp fan shroud. One product is very crappy, with shit poor assembly too. One is fair, with decent (not perfect) assembly quality, vanes in the correct position and distributes the air quite nicely. One is a nice product with good fit and vanes in the correct positions. The odd thing is that there are only about 10 bucks difference in retail prices. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
Tobias Bylund Samba Member
Joined: December 10, 2007 Posts: 213 Location: Varberg - Sweden
Posted: Thu Apr 02, 2020 11:48 am Post subject: Re: “Newer style” doghouse any good? |
The CSP shroud i installed a month ago was quality, fit was nice against OG german cylinder tin. Only thing with all of them is the bolt pattern for the Alt/Gen backing plate is slightly rotated compared to an original one so my CSP center pull linkage fouls on one of the bolt heads, will change the bolts to round headed allens instead. |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Thu Apr 02, 2020 11:52 am Post subject: Re: “Newer style” doghouse any good? |
Tobias Bylund wrote: |
This is what irritates me about aftermarket shrouds. That bolt pattern should be the easiest thing to copy! _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
Posted: Thu Apr 02, 2020 12:07 pm Post subject: Re: “Newer style” doghouse any good? |
I know SCAT did rotate the Alt/Gen backing plate bolt pattern so you COULD NOT use their competitors (Gene Berg) linkage and would have to buy their brand of dual carb linkage. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
txoval Samba Member
Joined: January 23, 2004 Posts: 3847 Location: The Woodlands, TX
Posted: Thu Apr 02, 2020 3:15 pm Post subject: Re: “Newer style” doghouse any good? |
I bought an empi version earlier this year. It has the vanes installed properly and is well made.
For fit, I had to trim it in the middle due to having a "bubble top" case...not really the fault of the shroud.
Stay away from the older versions that did not have the directional vanes.
I would also like to see the vendors Alstrup is describing |
Posted: Thu Apr 02, 2020 3:34 pm Post subject: Re: “Newer style” doghouse any good? |
Yeah Alstrup!! Spill the beans man!
I purchased the AA one. $40 shipping was a KILLER though!😡 _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79686 Location: Sneaking up behind you
Posted: Thu Apr 02, 2020 3:44 pm Post subject: Re: “Newer style” doghouse any good? |
Glenn  Mr. 010
Posted: Thu Apr 02, 2020 3:59 pm Post subject: Re: “Newer style” doghouse any good? |
Doesn't clocking the alternator backing plate move the cooling vent?
VW wanted it facing down for a reason. Maybe the aftermarket didn't get the memo. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Apr 02, 2020 4:26 pm Post subject: Re: “Newer style” doghouse any good? |
Yes I remember reading not to change the orientation of that small air slot on the backing plate! _________________ 1776cc, CB crank, CB 2241 cam, CB light lifters, CB H-beam rods, CB light flywheel, Mahle forged pistons, A1 Sidewinder exhaust, Dellorto drla 40’s, Hoover modded case, fully balanced, fully flowed, heads by www.type-emotorsports.com, Air ride suspension by https://www.airkewld.com/?Click=3989 |
Bama Dave Samba Member
Posted: Thu Apr 02, 2020 5:21 pm Post subject: Re: “Newer style” doghouse any good? |
The scat shroud and scat backing plates work as it should, vent down.
Photo from Scat:
Photo of the Scat shroud I am putting together right now:
_________________ David Richerson
!964 Beetle Sedan
1970 Beetle Sedan
1971 Super Sedan
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1150 Location: Western Washington State
