Mark Evans  Samba Member
Joined: April 21, 2004 Posts: 1930 Location: Alsea,Oregon
Posted: Sun Feb 23, 2020 7:57 am Post subject: Wife's new project-Joy! |
I should probably start a thread on our newly acquired '68 Kombi named Joy (wife's Mother's name)
My wife has had 2 other buses in the past, both were campers and this time she did not want a camper style bus, just a Kombi, so we picked up this '68 that was listed here and also on Craigslist in the Spokane area. Originally came from Arizona and then to the Spokane area, so not too much rust to deal with.
Previous owner had engine rebuilt about 4 years ago to a 1776, dual Kadron, larger heads/ports, but that's about the extent of his memory of the specifics. Said it broke a fan belt when driving one day, replaced it, then said it sounded "funny", so he pulled the engine in hopes to go through some things. Then his shop burned down leaving no choice but to sell the bus for funds to rebuild the shop.
This where we came into the picture. Not planning to restore or make it pristine, but to preserve what is there and prevent any more rusting in the usual places. We have already applied rust converter/encapsulator on most of the interior. Wife is now applying sound deadener to most of the interior panels, then plan to coat over everything with truck bed liner and a final sealant/deadener.
I have dismantled the top end of the engine so far, end play seems good, rod bearings feel good, so just planning for new p/c's. Going to replace the dual Kadrons with a rebuilt 34-3 Pict, changing out the 009 dizzy for a newly rebuilt 034, and install a new Jopex stock style exhaust. Basically wanting an overall stockish setup for dependability. My wife is planning to use it as Friday driver, occasional use rig. Of course, take it to the Woodburn show here in Oregon someday!
It came loaded with lots of goodies!
_________________ '63 Ragtop |
mwallace Samba Member
Joined: September 06, 2016 Posts: 53 Location: Ottawa
Posted: Sun Feb 23, 2020 10:16 am Post subject: Re: Wife's new project-Joy! |
Very exciting! I'm working on a 68 as well. I'm hoping its on the road this spring. |
Brian Samba Moderator
Posted: Sun Feb 23, 2020 11:51 am Post subject: Re: Wife's new project-Joy! |
Dang looks like a solid shell to work with, here's to hoping you don't find rust and bondo. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
steelheadrob Samba Member
Joined: January 03, 2020 Posts: 26 Location: North Idaho
Posted: Mon Feb 24, 2020 6:36 am Post subject: Re: Wife's new project-Joy! |
There are signs that this bus had had some bumps and bruises. Long panel on driver's side had some fill work done, driver's rear corner was replaced. Also signs that there may have been a front end clip job done, but really don't care. Not going to be a show piece or full restore, just a solid running driver to use and enjoy.
My wife worked on putting in sound deadener sheets on some inner areas. Planning for a double layer over the rear cargo area above engine bay. I will also install deadener behind fuel tank area since it is removed for deep cleaning.
My plan was to spray truck bed liner coating OVER all this sound deadener after it's installed so as to cover the shiny covering and also would be another layer of sound protection. That way, if any shows through around the cargo mats, it doesn't jump right out at you.
I meantime, finished setting the endplay and installed the new flywheel seal on the engine. Installed a new Gene Berg gland nut and washer set. Cleaned and painted engine tins in preparation when the new p/c's arrive. I dug out an original bus oil bath air filter I had, '71 model. Took a while to clean out the mouse nest inside that!
I also had a pretty nice front emblem for the bus, just hanging on the shop wall!
Posted: Sat Mar 07, 2020 6:22 pm Post subject: Re: Wife's new project-Joy! |
More progress: Wife is working hard at getting more of the sound deadener installed. She applied a second layer going across the rear cargo area in the opposite direction rather me having to apply it inside the engine compartment above the engine. She also started on some of the doors and hatches as well. I applied the same deadener to the inside of the engine compartment, but behind and under the fuel tank area.
I have also finished going through the heads, cleaned, then handlapped the valves. We received the new p/c kit, an AA set, but looks like I will now need to get a ring file to properly set the gaps as they are a bit tight.
As I was going through the items I removed from the engine, I noticed the label on the oil cooler, Gene Berg. Good sign and hoping there are more quality components used inside the lower end, as I am not splitting the cases at this time.
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23874 Location: NYC/Upstate/ROW
Posted: Sun Mar 08, 2020 4:31 am Post subject: Re: Wife's new project-Joy! |
There is a special place inHeaven for wives who want a DD tin top...the best part is you are living in that part right now,,, _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Posted: Mon Mar 16, 2020 4:24 am Post subject: Re: Wife's new project-Joy! |
The wife has finished applying the sound deadener to the front floor area and walk through. Only the driver's door left. She said she does not want to put on the main cargo floor area for now. We'll see how it sounds once it's driving. Can always easily put it in later.
I have completed assembling the long block, set valve lash. Cleaned and painted some more parts and tin.
Also completed sound deadener and final coat of sealant in engine bay area.
I will be removing the cold start relay hanging in the engine bay, rewire and clean up engine bay harness when I get closer to engine install. _________________ '63 Ragtop |
Posted: Sun Mar 29, 2020 4:19 am Post subject: Re: Wife's new project-Joy! |
Progress update: I have pretty much completed the engine assembly and is ready for install. I re-installed the fuel tank, removed the hard start relay that was mounted in the engine bay, and will finish going through the wiring before re-installing the engine.
I sprayed a truck bed liner system over the sound deadener for extra protection. Wasn't really happy with the spray delivery gun that was provided in the kit, but do like the applied product itself.
The wife recovered the drivers seat, stripped and painted the lower bases of the rear and middle seat, then said she needed "something to do", so I told her the front splash pan needed some straightening. Here's her handywork after spraying some undercoat to the inner side. I told her she was a good metalurgist!
She also was home this week for a day to be around for the installers of our new metal carport we had purchased, so she spent some time "restoring" the glovebox!
alman72 Samba Member
Joined: October 09, 2014 Posts: 2575 Location: MICHIGAN
Posted: Sun Mar 29, 2020 7:07 am Post subject: Re: Wife's new project-Joy! |
looks like the glovebox matches the seatcovers? I see a peek of a box with multi color stripes..
you sure are making it your own |
Posted: Sun Mar 29, 2020 7:52 am Post subject: Re: Wife's new project-Joy! |
Yeah, she's not wanting an original style rebuild. I'm fighting her to keep the flower stickers off the outside!  _________________ '63 Ragtop |
Posted: Mon Apr 13, 2020 4:19 am Post subject: Re: Wife's new project-Joy! |
Engine is in! Took some time to get it to fire up. Turns out, when cranking the engine over, there is no power at the coil, but when you let off the key, there is power...I'll have to figure out how someone wired up the aftermarket ignition. But by using a remote starter switch, voila! I also installed a fuel pressure regulator with gauge.
The wife got her seat cover kits installed and trimmed for the front seats.
And we installed the original rubbers matts. Just waiting for the ABS panel kit to finish up the interior. Yes, I know the front matt is the incorrect year.
All exterior lights are now working. _________________ '63 Ragtop |
Posted: Mon Apr 13, 2020 5:55 am Post subject: Re: Wife's new project-Joy! |
are those universal seat covers? kind of impressed at the fit. |
Posted: Mon Apr 13, 2020 12:25 pm Post subject: Re: Wife's new project-Joy! |
No, they are just off the shelf, but the wife has sewing machines and the skills to make them fit much better. It took her some time until she was happy with them. _________________ '63 Ragtop |
dembus Samba Member
Joined: February 02, 2005 Posts: 1272 Location: Fleming Island, Florida
Posted: Tue Apr 14, 2020 10:44 am Post subject: Re: Wife's new project-Joy! |
Mark Evans wrote: |
No, they are just off the shelf, but the wife has sewing machines and the skills to make them fit much better. It took her some time until she was happy with them. |
I like those too! Where did they come from please? _________________ "Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5975 Location: Los Alamos, New Mexico, USA
Posted: Tue Apr 14, 2020 2:11 pm Post subject: Re: Wife's new project-Joy! |
Not to be a Debbie Downer, but I hope that you do not regret using that black undercoater all over the place. I have had bad experiences with water getting underneath and surreptitiously causing rust issues. Then you get to remove it all, which is not fun.
Looks like this is going to be a really fun bus for you guys, though! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Wed Apr 15, 2020 3:47 am Post subject: Re: Wife's new project-Joy! |
dembus wrote: |
Mark Evans wrote: |
I like those too! Where did they come from please? |
We found them in the automotive section at our local Bimart store. _________________ '63 Ragtop |
Posted: Tue May 12, 2020 4:58 am Post subject: Re: Wife's new project-Joy! |
Been a while since an update, but we are making progress! All the ABS interior panels arrived from Werksberg. The wife really enjoyed installing them. Gives things a nice, finished look, yet utilitarian looking all the same! One more seat cover to go.
Mounted the front bumper. Rear brackets don't seem to fit the frame opening correctly, are '68 rear brackets special?
Also restored the wipers.
Once we get it "legal" to drive, we'll take it in to the shop for the ignition issue. I just won't have much more time to spend solely on Joy with Summer house remodeling season coming. _________________ '63 Ragtop |
chittychittybangbang Samba Member
Joined: August 12, 2006 Posts: 194 Location: portland, or
Posted: Tue May 12, 2020 8:24 am Post subject: Re: Wife's new project-Joy! |
I was wondering what happened to that bus. Glad it found a good home! _________________ If your into busses youve got issues and you likely donยดt know it yet. - El_Gรผero
The question of whether the resulting usage is "correct" or "incorrect" depends on one's notion of correctness. |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1785 Location: Newmarket, ON
