SolarPoweredPickles Samba Member
Joined: May 13, 2009 Posts: 1273 Location: California
Posted: Sun Apr 19, 2020 4:41 pm Post subject: What have you done (to your bus) on quarantine? |
Thought we could start a fun post.
What have you put off for years (with your bus) that you've finally gotten to?
Also, what do you plan on doing, this upcoming week?
Photos encouraged! Feel free to comment by number below.
I'll get the ball rolling:
1) Finally replaced door seals and felts, LOVE IT.
2) (In process) of fixing 2 rear dents/ block sanding filler
3) Might consider shortening my bumper brackets, they need work anyways, to "tuck" the bumpers in closer to the body.
Stay safe cool peeps!
GeorgeA Samba Member
Posted: Sun Apr 19, 2020 5:43 pm Post subject: Re: What have you done (to your bus) on quarantine? |
Installed a headliner and new interior in my ‘66
Malokin Martin Samba Member
Posted: Sun Apr 19, 2020 5:47 pm Post subject: Re: What have you done (to your bus) on quarantine? |
Perhaps not the bus, but I did finally get the signs up. My neighbor is likely less than enthusiastic.
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Sun Apr 19, 2020 5:58 pm Post subject: Re: What have you done (to your bus) on quarantine? |
First off...nice bus and great idea for a thread.
As far as your bus plans go, well done on starting back at it. It does feel good to complete something that you've put off far too long.
Your plans for the bumper gap...best investigate that one before diving in.
I know all the hot rod shows make a real point out of taking up that gap. Foose, Kindig and The Count all love to fix that problem.
The problems you'll run into with just shortening the brackets are: splash pan alignment, or support bolt alignment. And, the bumper can't just come closer in one direction. The bumper would need to be cut and shortened to take up the side gap as well or it would just look like it was already in an accident. The level of skill it takes to do this correctly and not look weird is way up there. So, dive in and do it if you want, but go in with your eyes open.
As far as my bus goes, I'm considered essential services and am still working, but with abbreviated shifts. This has given me a bit more time to work on my bus, which is in the ninth year of it's project status.
Stay safe people, you bus won't give you covid, so you know where you should be.
gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
Posted: Sun Apr 19, 2020 6:07 pm Post subject: Re: What have you done (to your bus) on quarantine? |
GeorgeA wrote: |
Good lord that's hot! |
Posted: Sun Apr 19, 2020 6:08 pm Post subject: Re: What have you done (to your bus) on quarantine? |
flemcadiddlehopper wrote: |
Your plans for the bumper gap...best investigate .... |
Yeah the more I look at it, and the corners, it would be a pretty tough challenge, def. more so than looking at it at a glance and be like "Sure I'll just cut off an inch and be done" ha... not quite, interesting idea, probably will keep at cleaning up my body work and finishing my interior. |
Posted: Sun Apr 19, 2020 6:09 pm Post subject: Re: What have you done (to your bus) on quarantine? |
Malokin Martin wrote: |
Love it! |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3351 Location: Birmingham, Alabama
Posted: Sun Apr 19, 2020 7:26 pm Post subject: Re: What have you done (to your bus) on quarantine? |
I'm still essential so I've just driven it to work some and to the grocery store.
Driving my Bus is therapeutic. It's my little escape from life's complexities, so driving it has helped me stay sane and keep some normalcy. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1291 Location: Surprise, AZ
Posted: Sun Apr 19, 2020 8:17 pm Post subject: Re: What have you done (to your bus) on quarantine? |
Removed engine and replaced a stripped oil cooler stud, which had let oil into the fan and promptly distributed throughout the engine compartment. Cleaned up whole engine of oil, replace soft lines since I was there and all accessible. Cleaned and adjusted spark plugs, basically checked and cleaned/tightened everything. Reinstalled engine and drove the piss out of it, then had a leaky passenger side valve cover gasket - damnit - replaced that, then continued on driving.
Not quarantined and still working, but the timing was right for something to need fixin’. Going to remove and re-install a rebuilt steering box next weekend, then all tierods, draglink, dampener, and shocks. My double cab gets better maintenance than anything else I own hahaha _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
langsmer Samba Member
Joined: November 18, 2004 Posts: 1127 Location: CO/NM border
Posted: Sun Apr 19, 2020 10:36 pm Post subject: Re: What have you done (to your bus) on quarantine? |
Well, I had my 65 shipped from storage in Oregon to my new house in Colorado where I'm from. Showed up a few days ago. Got the engine out last night to pull the tins off to replace the oil cooler seals, clean out the heat risers, clean the long block, etc. Got the parts to rebuild the brakes with a dual circuit master in the mail. Hopefully it will be ready to take into the mountains for some social distancing in a few weeks.
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1661 Location: Budapest, Hungary
Posted: Mon Apr 20, 2020 2:12 am Post subject: Re: What have you done (to your bus) on quarantine? |
I've been driving my bus as much as possible in Poland's beautiful spring weather, but as far as projects are concerned, I wired up my clam shell lights.
Installed and wired my water pump
And installed my breadbox
I also researched and found some of the parts for my future projects.
Looking forward to more inspirational posts, keep up the good work. |
perello Samba Member
Joined: April 15, 2005 Posts: 894 Location: where social security comes for free
Posted: Mon Apr 20, 2020 4:27 am Post subject: Re: What have you done (to your bus) on quarantine? |
Changed oil
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1488 Location: Richmond, VA
Posted: Mon Apr 20, 2020 10:12 am Post subject: Re: What have you done (to your bus) on quarantine? |
My bus is at my parent's place 200 miles away, but dad has been cranking away on the cargo doors metalwork! I've knocked out the gauges and some other things on my drift car. My next project is building a Westfalia-style table for my Previa. I may even finally get to the brakes on my 66 bug! _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
Posted: Mon Apr 20, 2020 10:59 am Post subject: Re: What have you done (to your bus) on quarantine? |
vwuberalles wrote: |
My bus is at my parent's place 200 miles away, but dad has been cranking away on the cargo doors metalwork! I've knocked out the gauges and some other things on my drift car. My next project is building a Westfalia-style table for my Previa. I may even finally get to the brakes on my 66 bug! |
I am looking to do similar, and make my interior, not really a camper, but something a little more "hang out" friendly for outtings, table, or shelving, extra seat across from my "rock n' roll bed/ bench"
That green bus getting up on the the lift, what a great photo! |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8237 Location: San Dimas
zozo Samba Member
Joined: October 15, 2005 Posts: 5216 Location: South of Ol' San Antonio
Posted: Mon Apr 20, 2020 12:02 pm Post subject: Re: What have you done (to your bus) on quarantine? |
Fixed "Joy" as she's called. She was naked. I was bored. I sort of sprung it on her. Pun intended.
I also stuck a neodymium magnet on the bottom to mount her on the dash.
Posted: Mon Apr 20, 2020 6:20 pm Post subject: Re: What have you done (to your bus) on quarantine? |
c21darrel wrote: |
tail light holes caught my eye. And frenched lic plate spot. |
Compliments of the previous owner in the 90's. Not something I would have done but I've grown to love her for all of what she is. My bus also had suicide doors (done incorrectly) it was terrible, first thing I changed back as the new owner. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10325 Location: Prime Meridian, ID
Posted: Mon Apr 20, 2020 7:12 pm Post subject: Re: What have you done (to your bus) on quarantine? |
zozo wrote: |
She makes all your oilers happy  _________________
EverettB wrote: |
FU#5 |
Help Help Samba Member
Joined: May 03, 2013 Posts: 119 Location: Running willy-nilly with scissors in So Cal
Posted: Tue Apr 21, 2020 8:59 am Post subject: Re: What have you done (to your bus) on quarantine? |
1) Changed out the radio head unit.
2) Started messing with a bamboo headliner (a little different than the usual).
And tonight I'm going to pull the engine to look at the heads/cyls and probably replace them and change out my fuel sending unit. |
Posted: Tue Apr 21, 2020 2:03 pm Post subject: Re: What have you done (to your bus) on quarantine? |
Help Help wrote: |
Did you buy a bamboo kit or going from scratch? Ive looked into this myself. I tried birch, but I couldnt get it to bend the way I needed, maybe too thick. |
