1st Tune up attempt
Ltcjc754
Ltcjc754 is offline
PostPosted: Fri Apr 24, 2020 1:29 pm    Post subject: 1st Tune up attempt Reply with quote
I'm attempting my 1st tune up of my '75 SB (PO swapped out FI for a 1300cc carb engine) I'm looking to ID my Distributor for points and condenser. The only ID stamped on the Dist. Cap is CST09A, it has two (2) vacuum lines going to the advance can. Any assistance is welcomed. Pics included. Thanks
mukluk
mukluk is offline
PostPosted: Fri Apr 24, 2020 1:55 pm    Post subject: Re: 1st Tune up attempt Reply with quote
Two vacuum lines running to the vacuum can means it's a DVDA distributor. All DVDA distributors used the same points, Bosch part number 01011, and they'll use either an 02054 or 02074 condenser. The distributor model number will be stamped into the aluminum body similar to the one pictured below. The markings on the cap aren't useful to determine what specific model you have.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Fri Apr 24, 2020 2:41 pm    Post subject: Re: 1st Tune up attempt Reply with quote
Visually the look like this:
https://www.thesamba.com/vw/gallery/pix/1279798.jpg
Roads Scholar
Member# 2059
ashman40
ashman40 is offline
PostPosted: Fri Apr 24, 2020 3:14 pm    Post subject: Re: 1st Tune up attempt Reply with quote
Once you ID your distributor model# from the stamping in the body, you can look up the Bosch part#s for consumable parts (eg. cap, rotor, points, condenser).
https://www.thesamba.com/vw/archives/manuals/Bosch_Tune_Up_Parts/Bosch_Tune_Up_Parts.pdf
You can also look up the distributor model# here where the part#s and timing specs are also given:
www.type2.com/~keen/ignition.html
Be sure to set your ignition timing based on the distributor installed and not the spec for your model year (unless still have the original parts). The model year/transmission timing spec assumes you have the original distributor and carb that the car left the factory with. Many Beetles no longer have the original parts.
AshMan40
Ltcjc754
Ltcjc754 is offline
PostPosted: Fri Apr 24, 2020 3:26 pm    Post subject: Re: 1st Tune up attempt Reply with quote
Thanks to one and all. I'll be pulling the distributor tomorrow to find the serial #.
jay64
jay64 is offline
PostPosted: Fri Apr 24, 2020 3:30 pm    Post subject: Re: 1st Tune up attempt Reply with quote
You don’t have to pull the distributor. It’s stamped on the side of it.
'76 BUG 2054cc
67rustavenger
67rustavenger is offline
PostPosted: Fri Apr 24, 2020 3:41 pm    Post subject: Re: 1st Tune up attempt Reply with quote
That cap has a NAPA part number on it. I have a set of points on my table that starts with "CS" on the part number.
Also, don't throw away the condenser if the engine was running well. The new ones today are hit and miss on quality. Keep the old one as a spare. You never know when you might need it. In a pinch! Wink
Good Luck
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Ltcjc754
Ltcjc754 is offline
PostPosted: Fri Apr 24, 2020 4:37 pm    Post subject: Re: 1st Tune up attempt Reply with quote
Thanks, Ashman, etal, I found the Mod# (had to use a mirror and read it backward) on the Dist. went to the listed site and have all the info needed to get a tune up kit. Thanks again to all.
tasb
tasb is offline
PostPosted: Fri Apr 24, 2020 4:49 pm    Post subject: Re: 1st Tune up attempt Reply with quote
Some of the SVDA part numbers are readable insitu but most other distributors the part numbers are facing front of car or center of engine case and not easily read. You can use a light and a mirror but then you have to deal with reversed letters and numbers. It's frequently easier/better to just pull the distributor.
Roads Scholar
Member# 2059
