CapeDory Samba Member
Joined: December 01, 2013 Posts: 14 Location: Lewes, Delaware
Posted: Sun Feb 11, 2018 7:30 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| Just getting back to the topic subject. I found that same problem...the pipes pulled easily out of the carb and out of the fuel pump. I could not stop thinking about a fire when I drove my '67. I sent the carb and the fuel pump to Tim at Volksbitz.com and he did a terrific job of replacing all of the potential disaster pipes with barb fitting threaded connectors. Not expensive. I also had the carb and fuel pumps fully cleaned and it has been well worth it. I recommend these fittings for peace of mind. |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Sun Feb 11, 2018 8:46 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
Question: if you have a carb inlet that is not loose, can you put a bead of solder or JB weld around the tube/boss connection or will those products not stick to the two metals? Then safety wire it in addition?
The ultimate fix seems to be send it off to be tapped and install a threaded tube. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33471 Location: Hot Arizona
Posted: Sun Feb 11, 2018 8:56 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| HippyTom wrote: |
The carb is aluminum casting, the tube is brass.
If the tube is not loose, I'd say to just safety wire it. That's what I've done on mine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bluebus86 Banned
Posted: Sun Feb 11, 2018 9:53 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| Cusser wrote: |
| HippyTom wrote: |
If the tube is not loose, I'd say to just safety wire it. That's what I've done on mine. |
ditto that...
solder wont work well with the metals used, aluminum is difficult to solder...
https://app.aws.org/wj/2004/02/046/
I have used locktite and the safety wire when the fitting was found loose, and removed, if not loose, safety wire only.
Bead of jb weld on the exterior may do very little good, unless maybe it is really gooped on, then it is a mess to look at. Id not do that. if the fitting is tight, simply wire it up and you should have zero problem with it falling out and causing a leak/fire,
good luck, bug on! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
wcfvw69 Samba Purist
Posted: Sun Feb 11, 2018 10:00 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| CapeDory wrote: |
I've restored 100's of the Pierburg fuel pumps. The vast majority of the tubes are still tight in the bodies. Some are loose and they are re-installed with epoxy and will NEVER come out again.
You don't need to screw barb fittings into the bodies of the carb or fuel pump. Will it hurt, absolutely not. However, epoxy or certain Loctite products will secure the tubes in the body for life.
What's important is for people to NOT yank, tug on or pull on the fuel hoses when removing them off the tubes. That's what causes the tubes to be loose or pulled out of the bodies. Another No-NO is to hang a heavy fuel filter between the fuel pump and carb. The weight of the full fuel filter can over time pull the tube out of the carb causing an obvious fire.
When I remove my fuel hoses from the carb or fuel pump tubes, I slit the fuel hose lengthwise down the brass tube to relieve the gripping tension of the hose off the tube. I then can remove the hose w/out putting any tension on the tube. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Feb 11, 2018 11:13 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
I'm going to safety wire both my Bugs first chance I get.
I had a fuel pump dumping gas everywhere recently, but it wasn't tube related. Just swapped it out with all new stuff and it was fine. I keep a few extras on hand. |
Cusser Samba Member
Posted: Sun Feb 11, 2018 11:40 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| wcfvw69 wrote: |
| When I remove my fuel hoses from the carb or fuel pump tubes, I slit the fuel hose lengthwise down the brass tube to relieve the gripping tension of the hose off the tube. I then can remove the hose w/out putting any tension on the tube. |
There used to be a series on cable TV called ShadeTree Mechanic, was very good, check YouTube https://www.youtube.com/watch?v=Pq0w_YMflr0. Anyway, the mechanics there recommended slitting hoses too to remove. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bluebus86 Banned
Posted: Sun Feb 11, 2018 4:15 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
Even if your fitting has never been tugged on, always slitted hose for removal, the fitting may still come loose. The carb material can creep, effectively expanding the fitting bore, thus causing the fitting to be loose. I have found some with the bore so enlarged, that there is no longer a press fit, more like a clearance fit. The bores can open up!
If the bore has opened just a bit, it will weaken its grip on the fitting, then if you tug a hose, even gentle like, its grip can fail and come loose.
But just because your not tugging on it, dont assume it is still factory tight.
In some ways however, tugging on the hose for hose removal is a good thing, tugging on it proof tests the grip. doing so can detect a very loose one.
I have had them pull out during hose removal, not a big tug, but enough to easily have it fall out. It was ready to fail, was very loose, I am glad I did tug it! Better it fail then and there, in my driveway, engine off, than when on the road, driving, with fire risk!
Good Luck Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
VinoLush Samba Member
Joined: October 24, 2013 Posts: 29 Location: Ventura, CA
Posted: Sun May 03, 2020 1:16 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
Guys... I didn't see specifically in the posts... Does this tube issue only happen on Solex Carbs? Empi or others have the same issue?
I guess the pump tube could also be safety wired? _________________ It Takes About A Half Day To Get There....
If We Travel By My Dragonfly.... |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Sun May 03, 2020 1:30 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| VinoLush wrote: |
I guess the pump tube could also be safety wired? |
It's not just Solex carbs that can exhibit this problem, all manufacture of carbs and fuel pumps with press in fittings can have this happen. You can safety wire the fittings on carbs and pumps to keep them from popping out. _________________ 1960 Ragtop w/Semaphores "Inga" |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11557 Location: Oregon
Posted: Sun May 03, 2020 1:42 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
It can happen on any brass to aluminum tube. They are mostly press fit and are susceptible to being pulled out of their respective socket when the hose is pulled on. It's a good practice to cut a slit on the fuel line to remove it from the brass nipple.
This came out of a Borsol carb while driving. Luckily the engine didn't catch fire.
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
CarolineL Samba Member
Joined: September 08, 2019 Posts: 1 Location: Hobart Tasmania AUS
Posted: Mon Aug 21, 2023 3:03 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
My first post is a huge thank you to all who wrote on fuel leaks arising from pressed tubing into fuel pumps or carburetors.
I’m working on a 1970 1500cc bug with original fuel pump and carburetor. She has been leaking fuel and I thought I had fixed it with new fuel lines & jubilee clamps. But still the leak at the fuel pump kept coming. Did some reading of historic Samba posts and then checked the car. Low and behold the fuel pump inlet spigot pulled right out of the pump. Hell! Yesterday we drove all day in blissful ignorance, with a catastrophic engine fire just waiting to happen.
Today went shopping for locktite 609 and safety wire. Oddly 5 auto suppliers I contacted don’t stock it (one had never heard of it). Not too worry I will track it down and learn a new skill to keep our bug going. Thank you Samba contributors. |
Cusser Samba Member
Posted: Mon Aug 21, 2023 8:14 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| CarolineL wrote: |
| Today went shopping for locktite 609 |
Buy online, but Search Loctite 609, no "k".
There also a ton of similar products..... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Aug 21, 2023 5:12 pm Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| CarolineL wrote: |
You want to use Loctite 603 retaining compound on that brass tube. Rough up the area of the tube that will be pressed into the casting of the pump. Scratch up the bore as well where the tube will slide into. Then clean both areas with alcohol or brake/carb cleaner. Apply the Loctite to the tube all the way around. Press in and wipe off excess. Once it sets up, the tube won't come out again. You should do the same to the tube on the carb. _________________ Contact me at [email protected]
wdfifteen Samba Member
Posted: Tue Aug 22, 2023 5:45 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| Bill, I got a fuel pump from you. Do you routinely pull out the tube and Loc-Tite it back in? If not, I assume I should safety wire the fuel pump outlet. |
Posted: Tue Aug 22, 2023 6:07 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
| wdfifteen wrote: |
Yes, every fuel pump I rebuild has the brass tubes removed and then Loctited back in so they don't come out again.
It's still a good practice for owners to slice the rubber fuel hoses lengthwise down the tube to remove or peal off the braided fuel lines from the carb tubes and pumps. Most carb inlet tubes are not very tight in their bores. Too many people yank or pull the rubber hoses off the tubes which can then loosen or pull the tubes out partially. Bad things happen then.
If the tube/s have been loctited in with the retaining compound, there's zero need to lockwire them as well. The tubes won't come out again unless you heat up the tube/bore to like 500° to melt the loctite. Even then they are a bear to remove.  _________________ Contact me at [email protected]
67conv Samba Member
Joined: July 10, 2005 Posts: 464 Location: Simi Valley, California
Posted: Tue Aug 22, 2023 8:08 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
Just a graphic reminder of what can, and in my case DID happen last Friday! The bottom photo clearly shows the outlet pipe had popped out of the fuel pump housing, allowing fuel to spew out and ignite!
I was extremely fortunate that someone who was witnessing the fire ran over with a fire extinguisher, as I foolishly didn't have one on board! Be forewarned! I never thought it would happen to me in 50 years of acvw ownership! _________________ 1967 VW Convertible, owned 35 years.
1957 DKW 3=6, owned 21 years.
PREVIOUS: 1972 "Baja Champion SE" Spec. Edition Beetle bought NEW @ Pierce VW in Denver; 1979 Super Beetle Convertible bought NEW @ Downtown LA VW; 1967 type 1 savanna beige; 1967 Porsche 2.0 911S; 1973 Porsche 2.4 911T; 1963 356 T6 B Cabriolet; 1964 356 SC sunroof coupe; 1972 Type-3 Squareback; 1968 + 1969 Type-3 Fastbacks; 1987 Vanagon GL Weekender |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7576 Location: Houston, Texas
Posted: Tue Aug 22, 2023 8:52 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
The factory press fit the tubes into the pump. There's a reason they become loose.
I'd be more concerned with rebuilders who shelter themselves behind an LLC. The end customer has little recourse if the pump leaks, causes a fire, and burns the whole car. _________________ www.vwnos.com [email protected]
Posted: Tue Aug 22, 2023 9:01 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
That sucks!
That's an Airtek brand economy fuel pump sold at most FLAPS. They are notorious for those tubes coming out. They are also known to put out more than 5psi for fuel pressure too. A customer said he got 7 psi out of his before pulling it off and replacing it with a rebuilt German Pierburg pump. _________________ Contact me at [email protected]
67conv Samba Member
Posted: Tue Aug 22, 2023 9:04 am Post subject: Re: Fuel Pump Failure, Huge Leak, Safety Wire Fix |
This was an aftermarket pump, from Autozone. Bought in a pinch a couple years ago. Not sure about what sort of factory QC methods apply to these Chinese things. LESS than 600 miles usage, I can't imagine why it would come loose like that! _________________ 1967 VW Convertible, owned 35 years.
