AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1706 Location: The Old Pueblo
Posted: Sun May 03, 2020 5:27 pm Post subject: 85 Weekender AC overhaul |
Im disassembling my van in an effort to access all the AC components. This afternoon I brushed off a very resistant hangover and began removing the overhead cabinet, the evaporator and expansion valve.
1st thing I noticed as is par for the course with this van....The PO had already been in the cabinet and this guy was not a fan of tightening nuts and bolts or replacing all the parts. I removed the hand tight hardware and dropped the cabinet. The expansion valve appears to be a replacement and has an r134a sticker attached. It looks fairly new.
The hoses dont look that old either. Is there a way to determine if these are original hoses before I get too deep into the removal process. Would there be a diff in diameter or appearance? My hoses are labeled in standard measurements, not sure this matters. They also don't show a lot of wear or signs of being dried out as one might expect from an AZ vanagon.
Ill post pics. in a few mins. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
Posted: Sun May 03, 2020 5:53 pm Post subject: Re: 85 Weekender AC overhaul |
Smack! I’m no longer hopeful but here’s the pics. Just loaded them all. I realize a few won’t tell us much
Previously
and a 67 bug. |
Posted: Sun May 17, 2020 11:09 am Post subject: can wires in white engine connectors be removed and replaced?? |
So it turns out that my AC guy thinks my AC hoses are not that old. We decided to leave the line from the receiver drier to the expansion valve and the line from the condenser to the drier. Ive flushed those hoses, the condenser, the evaporator and the expansion valve (by itself off the van). Ive replaced the drier and am in the process of pulling the compressor to drain and refill the PAG oil.
While dicking around under there I had a mishap
Accidentally toasted a ground coming from my 4 pin connector.
Anyone know if the wire can be removed and replaced. Its the ground between the two white connectors. If removable it could be a quick fix. Do these connectors come apart. I searched but didnt find anything in 30 mins.
Appreciate your thoughts.
Previously
and a 67 bug. |
jlrftype7 Samba Member
Posted: Sun May 17, 2020 11:55 am Post subject: Re: can wires in white engine connectors be removed and replaced?? |
AZ Landshaper wrote: |
. Round Pin?
Usually a round pin removal tool make short work of depressing the little tabs that hold the pin into the connector body, then a plunger that’s inside the hollow portion of the round tab depressing part, pushes the pin out of the connector. You just need the right size removal tool , they are a bit pricier than flat pin removal tools since there’s more to them. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Sun May 17, 2020 12:13 pm Post subject: Re: 85 Weekender AC overhaul |
Something u buy at Napa? _________________ Support Small Business.
Previously
and a 67 bug. |
Posted: Sun May 17, 2020 4:50 pm Post subject: where are the 85 AC relays. (Not behind closet). |
Wiring repaired using a Macdonald’s straw to remove the old pin.
Anyone know where the relays and such are in the 85 AC system. There’s nothing behind my closet but two hoses and a small wiring loom headed to the evap and blower. 1985 Relays location? _________________ Support Small Business.
Previously
and a 67 bug. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10270 Location: Mt Lemmon, AZ
Posted: Sun May 17, 2020 6:25 pm Post subject: Re: where are the 85 AC relays. (Not behind closet). |
...Anyone know where the relays and such are in the 85 AC system... |
On my 84 they are behind the upper grille on the left hand (drivers) side. |
khughes Samba Member
Joined: July 13, 2013 Posts: 905 Location: Phoenix AZ
Posted: Mon May 18, 2020 6:46 am Post subject: Re: where are the 85 AC relays. (Not behind closet). |
Anyone know where the relays and such are in the 85 AC system. There’s nothing behind my closet but two hoses and a small wiring loom headed to the evap and blower. 1985 Relays location? |
If it's dealer installed (single AC control on left side of steering column) all the relays should be under the dash. If you have the 3-speed fan the relays are likely attached to the fuse panel. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Westified Samba Member
Posted: Mon May 18, 2020 8:19 am Post subject: Re: 85 Weekender AC overhaul |
On my 1984 wolfsburg they are above the fuse panel on drivers side A pillar. Here is a diagram of my AC.
_________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Posted: Mon May 18, 2020 8:44 am Post subject: Re: 85 Weekender AC overhaul |
Westified wrote: |
My '86 is basically the same, except with a 3-speed fan, so I have low, 2nd stage, and 3rd stage (12VDC direct to fan, no dropping resistor) relays. Fan relays on mine are attached to the fuse panel, with the rest shown as in your diagram. I also added relays for the evaporator fan (now fans since I modified the headbanger to accept the later evap with the dual fans) since the fan switch wasn't really rated for the load. Smoked a couple. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Posted: Wed May 20, 2020 6:35 am Post subject: Re: 85 Weekender AC overhaul |
Thanks for the diagram. Seems these aftermarket 85 AC systems are a bit diff than the later model factory stuff.
Anyone know if it’s possible to use the ez clip stuff w standard barrier hose? I need to decrease hose lengths and add a trinity switch port. I’ll look for an o-ring style to attach to the drier but in leu thought it might be possible to splice something in w ez clip system, but not if it requires all new hose
As some old koot told me a couple weeks back. There are some great posts on this site re the AC refurb. Just takes a few mins to understand what your reading. I’ve finally had an ahh haa moment and am comprehending the literature. Lol.
Thanks a lot to those who have posted info on these systems.
As I slowly move forward on the backs of those who went before me. _________________ Support Small Business.
Previously
and a 67 bug. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8464 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed May 20, 2020 7:29 am Post subject: Re: 85 Weekender AC overhaul |
djkeev did a complete AC resurrection with EZclip fittings, although also all new hoses.
I'm sure it was easier than my project (all new crimped fittings on new hose).
It's definitely a b!tch trying to snake the fittings through the existing holes, nooks &
crannies. But then I'm cheap, plus now I know how much smarter he is than me...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Wed May 20, 2020 8:04 am Post subject: Re: 85 Weekender AC overhaul |
From the $ I see online the ez clip system may not be very expensive. The savings from doing the job yourself is pretty substantial. The pinchers and clamps are fairly cheap. I would do myself some good by being more cheap. Wife has me beat there. _________________ Support Small Business.
Previously
and a 67 bug. |
Posted: Wed May 20, 2020 8:14 am Post subject: Re: 85 Weekender AC overhaul |
Turns out ez clip requires ez clip hose. Not applicable to other hoses due to variety of hose Outside diameters. _________________ Support Small Business.
Previously
and a 67 bug. |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 605 Location: Scappoose, OR / Oakland, CA
Posted: Wed May 20, 2020 8:36 am Post subject: Re: 85 Weekender AC overhaul |
Sorry if I missed it- but why are you trying to avoid the Eaton hose? It is thinner, so easier to maneuver, and far stronger than the original hose- sounds like a win/win? _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
Posted: Wed May 20, 2020 5:35 pm Post subject: Re: 85 Weekender AC overhaul |
AC guy in town says my hoses are relatively new. Installed just a few years back. Why spend the money if the AC pro thinks its not necessary?
Its all barrier hose. _________________ Support Small Business.
Previously
and a 67 bug. |
Posted: Wed May 20, 2020 5:40 pm Post subject: Re: 85 Weekender AC overhaul |
Its all barrier hose. |
Ah, gotcha. Carry on! _________________ 1986 Westy Weekender
Now a full camper
Posted: Sat May 30, 2020 5:39 pm Post subject: Re: 85 Weekender AC overhaul |
Ok got the system back together after replacing some hose, adding oil, pulling a vac for four hours charging with red tek. I also replaced the drier and installed an updated condenser.
Ive got 30/200 for pressures and still have 77 degree air coming through the vents. The compressor runs as it should and the rad fan is on as soon as the switch goes on.
Any suggestions? _________________ Support Small Business.
Previously
and a 67 bug. |
Farf Samba Member
Posted: Sat May 30, 2020 7:16 pm Post subject: Re: 85 Weekender AC overhaul |
What was the ambient temperature when you recorded those pressures? Seem a bit low if your in the 90's +. |
