I built a tow bar
old_man
old_man is offline
PostPosted: Wed May 27, 2020 5:41 pm    Post subject: I built a tow bar Reply with quote
Well, I couldn't get a beetle one for cheap to modify so I built my own. I'm still learning to weld so I didn't have 100% confidence in my welds thus I probably over built it a bit.
These are the hook ups that came with the car.
This is my tow bar.
The noble stead. It handled quite nicely on the highway. The bar is perhaps a little low. Took it up to 110 kph (downhill) and there was no swaying or anything of the sort. Hills are....interesting.
Would I recommend someone else do this? No. I think the preferred method is where you build that tube bracket that allows you to use a regular beetle tow bar. Why? because beetle tow bars are usually more readily available to easier to borrow instead of this one off I made.
Hopefully this posts helps someone in the future.
pedro sainz
pedro sainz is offline
PostPosted: Wed May 27, 2020 6:02 pm    Post subject: Re: I built a tow bar Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=364117&highlight=tow+bar
68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There
old_man
old_man is offline
PostPosted: Wed May 27, 2020 7:36 pm    Post subject: Re: I built a tow bar Reply with quote
That's originally the one I wanted to do. I couldn't find a beetle tow bar for cheap. I also coudn't find anyone/anyway to bend that size tube without kinking it.
Bobnotch
Bobnotch is offline
PostPosted: Thu May 28, 2020 9:53 am    Post subject: Re: I built a tow bar Reply with quote
I used a Super beetle tow bar as a starting point, and added 24" of 2" tubing to the length, and welded it up. The SB plate, is bolted to the bottom of the beam with U bolts. Here's some pics.
I've used this set up a few times, and have even loaned it out twice. No issues with it at all.
Note: These pics were before I trimmed the U bolts down.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
notchboy
notchboy is offline
PostPosted: Thu May 28, 2020 10:41 am    Post subject: Re: I built a tow bar Reply with quote
Ha. I remember that. Laughing
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Bobnotch
Bobnotch is offline
PostPosted: Thu May 28, 2020 11:30 am    Post subject: Re: I built a tow bar Reply with quote
This is my tow bar.
That tow bar looks like it must weigh a ton. Probably needs 2 men and a boy just to pick it up. Definitely over kill.
Tram wrote:
Tram wrote:
old_man
old_man is offline
PostPosted: Thu May 28, 2020 1:24 pm    Post subject: Re: I built a tow bar Reply with quote
Over kill - Yes, probably.
Weights a lot - Yes, but I can carry it myself.
Hook up? - I can do it myself. I just slide it under the front and then it 'levers' easily into place.
1/8" 2" square tube. Irony being that I chose this route over a tow dolly because of weight. Dollies are heavy.....
Erik G
Erik G is offline
PostPosted: Thu May 28, 2020 1:29 pm    Post subject: Re: I built a tow bar Reply with quote
after seeing a very nice beetle wrecked using a standard towbar, I don't think it's overkill at all.
notchboy
notchboy is offline
PostPosted: Thu May 28, 2020 1:56 pm    Post subject: Re: I built a tow bar Reply with quote
True that.
1964 1500 S
old_man
old_man is offline
PostPosted: Thu May 28, 2020 2:34 pm    Post subject: Re: I built a tow bar Reply with quote
I there a link to this misfortune? I wish to learn.
ALLWAGONS
ALLWAGONS is offline
PostPosted: Thu May 28, 2020 8:12 pm    Post subject: Re: I built a tow bar Reply with quote
Pretty awesome towbar Me Oldman!
Martin
Allwagons
