Earliest brown faced speedo?
sinclair
sinclair is offline
PostPosted: Thu Jun 25, 2020 8:58 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
Here’s a conundrum then.
My 100mm August 49 speedo has the larger Deluxe bezel. But it’s in original brown paint, certainly never been chromed... so where does that fit in the chronology?
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Thu Jun 25, 2020 9:13 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
john Henry wrote - So perhaps none of the three cars with brown face speedos at the March '49 auto show would have been considered "production" vehicles (which I think, is Zen's point) and actual use of the part in line production started 3 months later in June.
John Henry
when I make the corrections lists to the Car of the Century, I will include a note that the information in Garwood's volumes reflect production vehicles and only MAY reflect VW coach builds, like Hebmuller, Drews and etc. i'll bet this info was understood by Mr. Garwood, but a note is in order...
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
sinclair
sinclair is offline
PostPosted: Fri Jun 26, 2020 2:54 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
Unfortunately the pod doesn't seem to have a date on the earth tab.
johnshenry
johnshenry is offline
PostPosted: Fri Jun 26, 2020 7:46 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
Some do not. Do you have a pic of the backside of your pod?
John Henry
'57 Deluxe
'56 Single Cab
sinclair
sinclair is offline
PostPosted: Fri Jun 26, 2020 10:13 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
Nothing that will help much at the moment. It had one of those mask the glass and paint inside and out resprays.
finster
finster is offline
PostPosted: Sat Jun 27, 2020 2:36 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
as we are talking about a car made in the early post-war years could there have been problems with parts supply causing anomalies like this to occur?
pastellgreen
pastellgreen is offline
PostPosted: Sat Jun 27, 2020 7:21 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
There is an anecdote in the book "Kleiner Wagen in großer Fahrt", published in 1949, that a truck loaded with bearings and speedometer slipped into a river. The factory sent out a Volkswagen with staff and a diving equipment, the staff had never seen before. They dived after the speedometer and bearings, brought them to the factory how much they could find. The speedos have been thrown away immediately but they tried to save the bearings, putting them into oilbaths. But at the end, inspection marked them as waste... To the question, why they did such an effort, the answer was: "such goods have been in short supply" during that time.
1961 pearl white beauty from Portugal
https://www.thesamba.com/vw/forum/viewtopic.php?t=759951
chthemonkey
chthemonkey is offline
PostPosted: Sat Jun 27, 2020 7:27 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
not 100% relevant but here's my 53 barn door speedo that was repaired at some point by vdo I'm not sure on the age of the brown Bakelite pod it could be older than 53
ZENVWDRIVER
PostPosted: Sat Jun 27, 2020 9:07 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
... Are the TYPE 2 brown pods and speedometers 95 mm or 100mms?
1960 single cab
'87 Toyota MR2
PostPosted: Sat Jun 27, 2020 9:36 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
95mm, I have one right here and my NOS Barndoor Deluxe chrome-ringed speedo doesn't stick through the face.
It sits recessed downward.
Recessed
Non-recessed
chthemonkey
PostPosted: Sat Jun 27, 2020 9:43 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
its 95mm but sits on a rim on the inner which is 100/101mm the speedo is a 53 barndoor and I think the pod is a earlier beetle it is for my 53 barn door ambulance
sinclair
sinclair is offline
PostPosted: Sun Jun 28, 2020 11:14 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
Here it is. Nothing on the earth strap but it has the piggy back fuse and cloth wiring. Key is P series.
I double chesked the bezal though. definately never been chromed.
ZENVWDRIVER
PostPosted: Tue Jun 30, 2020 5:19 pm    Post subject: Re: Earliest brown faced speedo? Reply with quote
… why do POs cut the wires of the harness, to the pods? I see lotza' Sinclair's cut also -The PO of my '50 cut mosta' the cloth-covered wires - I guess he thought that was easier and was gunna' replace the harness too - i'm not gunna replace, but will just splice in - just haffta' match the colors - since that car was mine, 40 years back, i know, it had a new harness, then - i'm sad he sorta' ruined a great harness...
… that car is in the Trust for our kid - he's not gunna' like my handiwork and will replace the harness again, i'll bet.
1960 single cab
'87 Toyota MR2
splitjunkie
splitjunkie is offline
PostPosted: Tue Jun 30, 2020 6:44 pm    Post subject: Re: Earliest brown faced speedo? Reply with quote
John can verify but I believe that the pods with the piggyback fuse are later parts and either came into effect in '52 or were only on later replacement parts.
Chris
johnshenry
PostPosted: Wed Jul 01, 2020 7:42 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
Correct. Documentation shows the fuse piggybacked on the ignition switch came in '52.
John Henry
'57 Deluxe
'56 Single Cab
sinclair
sinclair is offline
PostPosted: Wed Jul 01, 2020 12:38 pm    Post subject: Re: Earliest brown faced speedo? Reply with quote
And a deluxe 100mm bezel in brown painted bare metal?
keedub
keedub is offline
PostPosted: Tue Jul 21, 2020 8:18 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
I believe there were a lot of changes going in March-June/July period when VW was developing their deluxe features. Since some of it was running changes, there was probably some inconsistencies. For the first ivory deluxe pods, perhaps, the brown pods were painted white, before the development of the all white bakelite pods were introduced.
The earliest Baketlite all ivory Pod I have seen was from September of '49. Perhaps someone on here has one with an earlier date. Or perhaps an original ivory painted '49 pod before 9/49 that has 90 mm hole. Few possible ivory pod scenarios:
1. All ivory bakelite with 100mm hole
2. All ivory bakelite with 90 mm hole (hmmm?)
3. Ivory painted brown bakelite with 100 mm hole
4. Ivory painted brown bakelite with 90mm hole
5. Some deluxe speedos had chrome, some did not.
Also, as Peter Schepmuller pointed out, the early deluxe knobs were ivory. Were they all ivory or painted ivory?
It's fun to try and figure this out without a time machine. Smile
sinclair
sinclair is offline
PostPosted: Tue Jul 21, 2020 11:20 am    Post subject: Re: Earliest brown faced speedo? Reply with quote
Well in the end I tidied it up to use what I have. Not point perfect but not too shabby either. Brown bezel paint is a Ford rattle can, close enough.
ZENVWDRIVER
PostPosted: Thu Jul 23, 2020 4:39 pm    Post subject: Re: Earliest brown faced speedo? Reply with quote
… your '49 pod, looks fabulous!
1960 single cab
'87 Toyota MR2
johnshenry
PostPosted: Tue Jan 19, 2021 6:50 pm    Post subject: Re: Earliest brown faced speedo? Reply with quote
johnshenry wrote:
sinclair wrote:
My late July 49 Standard pod, given the deluxe bling at some point.
What is the speedo opening size? 95 or 100mm? looks like a brown painted chrome bezel, but a deluxe speedo bezel will not fit into a std pod.
Ok, back on this, and first I have to correct myself from what I said above. "a deluxe speedo bezel WILL fit into a std pod". There has always only been one SIZE of speedo bezel for deluxes or standards, only difference is stds are steel and painted brown (check with magnet), and deluxes are brass with chrome plating. But dimensionally, they are the same. You CAN put a deluxe bezel/speedo into a 95mm opening standard pod, but the bezel will not protrude through the face as the 2.5mm ridge will stop it.
In the 100mm deluxe pods, the ridge is not there, and the bezel (either one) will protrude through the bezel and be visible from the front. This is why on the std pods, the speedometer is held into the pod with M5 screws and washers, whereas on the deluxe pod, the speedo sits farther into the pod, and it is secured by M5 screws and those metal "L" tabs.
So the only real dimensional difference between the std and deluxe pods is the presence of that ridge inside the speedo opening. And again dimensionally, the std. and deluxe speedo bezels are the same.
Lastly, I just discovered in my stash another 4.49, April 1949 brown face speedo. This one has a chrome bezel, but also a "Repariert Durch VDO, Munchen" sticker on it. So did it start it's life as a chrome bezel/deluxe speedo, perhaps in the pre-production realm? Or was the chrome bezel added by VDO at some point after?
John Henry
'57 Deluxe
'56 Single Cab
Page 3 of 4
