T2 The Boss Samba Member
Posted: Wed Jul 29, 2020 7:44 am Post subject: Stripped case saver...What are my options? |
Hello.
I've purchased dual relief case with 10mm studs, which is overall in good condition except the savers that were installed after the studs pull out from the case.
Unfortunately someone puted self tapping savers 14mm which are almost ready to pull out...
What are my options now? Can I make custom savers with the following parameters - outer diameter 16mm and inner 10mm or even 8mm so I can use later type studs?
[/b] |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Wed Jul 29, 2020 8:16 am Post subject: Re: Stripped case saver...What are my options? |
you could...but will the time/effort to do so be worth it vs. just starting with another case?
sound like several hours of work |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2186 Location: Laurel Canyon, CA
Posted: Wed Jul 29, 2020 9:27 am Post subject: Re: Stripped case saver...What are my options? |
You say they are just loose or feel like they could come out easily?
I'm no expert on this but I would think if you remove all of them and then re-install new ones ( or possibly even the same ones just cleaned very well ) using some kind of locktite it might just work fine.
The sell a green colored type called retaining compound (loctite 290 is the number?) _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Posted: Wed Jul 29, 2020 10:53 am Post subject: Re: Stripped case saver...What are my options? |
vwinnovator wrote: |
I think its worth it.
The case is freshly line bored to .040 , thrust is std. I received it like that, so I could spent some hours on fixing the savers.
My concern is if I drill it to M16 would there be enough material to hold the studs, it will be too close to the barrel opening... |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 2072 Location: North Carolina
Posted: Wed Jul 29, 2020 10:59 am Post subject: Re: Stripped case saver...What are my options? |
Be extremely careful if you drill it yourself to make sure the drill goes in absolutely straight up and down. A while back there was a nightmare engine case someone had with the studs protruding at weird angles due to misaligned drilling.
I wouldn't even think about hand drilling but would use a quality drill press, or, better yet send it to a vw machine shop and let them undertake that task.
Good luck |
Posted: Wed Jul 29, 2020 11:46 am Post subject: Re: Stripped case saver...What are my options? |
There is no such thing as "self tapping case savers"
There is a stud with slightly oversized threads. The threads are cut like a tap... those are called "self tapping studs" but are not that common and even if someone did use those you should still be able to have a machine shop tap the case for regular 14mm OD case savers.
Its hard to tell what the actual problem your having is from the photo and description provided.
Is the problem simply that a few of the case savers have backed out a little and are loose? _________________ 1967 Bug ( the daily rod )
Posted: Wed Jul 29, 2020 12:28 pm Post subject: Re: Stripped case saver...What are my options? |
evanfrucht wrote: |
Is the problem simply that a few of the case savers have backed out a little and are loose? |
This type of insert was used. And now the threads in the case are gone. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23947 Location: SHALIMAR ,FLORIDA
Posted: Wed Jul 29, 2020 1:51 pm Post subject: Re: Stripped case saver...What are my options? |
yes it can be saved. or replaced. I wood replace with a good aluminum case..but Im that kind of guy I like better stuff. |
Posted: Wed Jul 29, 2020 2:04 pm Post subject: Re: Stripped case saver...What are my options? |
T2 The Boss wrote: |
evanfrucht wrote: |
Idk where you found that first picture but those are not meant for a VW. No vw/aircooled parts place sells what you pictured.
Also it doesnt look like thats what you even have. That appears to be a regular case saver on your stud. If you could describe your problem better maybe someone can help more.
If the case savers are loose, a fix would really depend on how loose they actually are. You need to bring it to a machinist if you cannot tell yourself by feel. Or if they arent even that loose and simply came out with the stud that should not be a problem so long as the case is not stripped. Just clean very well and use threadlocker or retaining compound or some other type of glue or sealant when you re-install.
Dont quote me on any of this and get a second opinion first. _________________ 1967 Bug ( the daily rod )
EVfun  Samba Member
Posted: Wed Jul 29, 2020 3:54 pm Post subject: Re: Stripped case saver...What are my options? |
mark tucker wrote: |
Yew argh loaded. May bee The Boss isn't. Savor by? _________________
Wildthings wrote: |
Rome Samba Member
Joined: June 02, 2004 Posts: 10612 Location: Pearl River, NY
Posted: Wed Jul 29, 2020 8:28 pm Post subject: Re: Stripped case saver...What are my options? |
The description for these Time-Serts indicate they would serve your purpose, though you'd end up having to use 10 mm head studs. http://vwparts.aircooled.net/Big-Sert-Thread-Repair-Insert-10-x-1-5-x-20mm-p/50153.htm
In addition to buying 1 for every head stud (16x) you'd also need to rent the installation tool/kit. And then you'd still need to drill the holes in the case accurately. Are all 16 of the case's stud holes stripped, or are there some that can still use new 10 mm stud case savers + thread lock compound?
Same vendor also sells case savers for case holes that first had 10 mm studs but would now use 8 mm studs.
Remember also that the head studs themselves do not need to be run all the way into the case savers and then torqued down or tightened. Instead, and this is something I only learned here on theSamba in the last maybe 10 years, is that you run the stud down by hand until it stops, then back it out a small amount such as 1/2 turn. So if your solution to the case savers ends up using your 10 mm head studs, run an M10 x 1.5 mm die over both of the threaded ends so that they turn easily into the new case savers. |
RWK Samba Member
Posted: Thu Jul 30, 2020 5:33 am Post subject: Re: Stripped case saver...What are my options? |
Yes, if you bottom studs out, then torque them down and the turn some in the bottomed out thread,you will distort the stud thread and or the hole thread, then when they are removed,you can damage the threads, best to back them off at least a 1/2 to full tread then mark, so you can see if they turn while torquing, some studs have a different fit at each end for this purpose. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Thu Jul 30, 2020 7:58 pm Post subject: Re: Stripped case saver...What are my options? |
Is that really a dual relief case? I thought they were all AS41 or AS21 cases. _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Thu Jul 30, 2020 10:04 pm Post subject: Re: Stripped case saver...What are my options? |
earthquake wrote: |
Is that really a dual relief case? I thought they were all AS41 or AS21 cases. |
Yes It's dual relief, I am also curios why it is not AS41 or AS21 marked... |
