Flanged Main Bearings from CB
kangaboy
kangaboy is offline
PostPosted: Sun Sep 27, 2020 8:03 am    Post subject: Flanged Main Bearings from CB Reply with quote
How are these superior to standard bearings and what is their application (street/strip/daily)? Are they worth the almost 4x price of standard mains?
https://www.cbperformance.com/product-p/1845.htm
-74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote:
Shocked
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out Laughing
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Sun Sep 27, 2020 8:13 am    Post subject: Re: Flanged Main Bearings from CB Reply with quote
They aren’t simply a replacement stock size bearing set. They have a very specific use for a flanged crank with Type 4 main journals in an unmachined standard linebore case. The other more common way was to take two sets of standard Type 4 bearing sets to create the two piece flanged bearing, then have the case line bored to accept the larger Type 4 bearing. Comparing prices to their counter parts are about the same, but there isn’t the additional machine work to the case needed.
Stripped66
Stripped66 is offline
Are you running a flanged crank?
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
kangaboy
kangaboy is offline
PostPosted: Sun Sep 27, 2020 8:21 am    Post subject: Re: Flanged Main Bearings from CB Reply with quote
Awesome, thanks for the response. I never heard of them before, so was just asking about their general application.
Nope, so now I don't need to worry about using these.
-18 GTI SE
Shocked
Dan Ruddock
Dan Ruddock is offline
PostPosted: Sun Sep 27, 2020 10:49 am    Post subject: Re: Flanged Main Bearings from CB Reply with quote
Makes me think 🤔 CB is going to start selling flanged cranks SOON. Dan
stealth67vw
stealth67vw is offline
PostPosted: Sun Sep 27, 2020 11:32 am    Post subject: Re: Flanged Main Bearings from CB Reply with quote
CB had flanged cranks in their booth at Sacramento Bugorama 4 or 5 years ago and had wondered why they haven't been selling them. I would assume bearing supply was the main issue.
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/
Dan Ruddock
PostPosted: Sun Sep 27, 2020 11:38 am    Post subject: Re: Flanged Main Bearings from CB Reply with quote
The current Empi/bugpack should be available to CB also. Wish a Porsche journal version was produced. Dan
[email protected]
PostPosted: Sun Sep 27, 2020 6:36 pm    Post subject: Re: Flanged Main Bearings from CB Reply with quote
The main issue with a flanged crank is the cost. That’s why Empi contacted Revmaster to start making the ones they used to do for Bugpack again. Empi has them listed for a little over $1500 for a crank/flywheel. That’s a bargain compared to the $2200+ the Scat ones are up to. And you don’t want to know what the Pro-Stock/Pro-Mod cranks are going for.
CB definitely is an innovator in creating something to fill a market void, or make performance stuff more available to the common hobbiest. With everyone complaining about aluminum rod bearings, they should of had King make some tri-metal VW/Chevy journal bearings.
UK Luke 72
UK Luke 72 is offline
PostPosted: Mon Sep 28, 2020 12:17 am    Post subject: Re: Flanged Main Bearings from CB Reply with quote
[quote="stealth67vw"]
We got a double Cool
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
SLAKKER
SLAKKER is offline
PostPosted: Mon Sep 28, 2020 1:34 pm    Post subject: Re: Flanged Main Bearings from CB Reply with quote
On the flanged crank how do the seal work is there a pic
of the crank in a block somwhere , haven't seen one in a block
yet
[email protected]
PostPosted: Mon Sep 28, 2020 2:53 pm    Post subject: Re: Flanged Main Bearings from CB Reply with quote
yet
The seal rides on the outer diameter of the rear flange section of the crank, as opposed to riding on the flywheel. The flanged seals are larger in diameter than a stock VW one, so the case needs machined for the seal.
Dauz
Dauz is offline
PostPosted: Mon Oct 12, 2020 9:34 am    Post subject: Re: Flanged Main Bearings from CB Reply with quote
I wound up buying these bearings. They're basically 411 adapters for standard type 1 mains. I opted out of doing the thrust conversion this time around since it is built into the bearing.
vw donvieira
vw donvieira is offline
PostPosted: Mon Dec 26, 2022 10:16 pm    Post subject: Re: Flanged Main Bearings from CB Reply with quote
How is the crankshaft end play managed? I have a flanged crank and was going to have GEERS do the bronze bushing, but this seems reasonable alternative.
"No Give Up"
