1967 front seat belt labels
harrymarlin
harrymarlin is offline
PostPosted: Fri Aug 14, 2020 1:43 pm    Post subject: 1967 front seat belt labels Reply with quote
In my attempt to be *way* too nit-picky with my 1967 Beetle convertible, I started looking at my seat belts. I thought I would share a bit of information I have I have found during my investigation.
Seat belt webbing
I found out, because of regulations, all of the US seat belt webbing pretty much currently looks the same. I expanded out to other countries to find a similar webbing to original, and found some in the UK. A company called FDTS has a grey "ladder webbing" (code ZV), which was the closest I found to what I originally had. They also have a black "Pebbing webbing" (code Z1) which is very similar to the webbing used later (in Beetles and in Porsches, I believe), and in back seat belts. I was interested in this, as I have a rear lobster claw seat belts from a 1971 Beetle I was using in my rear seat.
Seat belt labels
I collected a few pictures of labels used in the correct seat belts (for those seat belts I could find still with labels!), and it appears as though they were manufactured in 1967 and 1966. The labels themselves were very similar to each other, but showed a different part number, and different modification number between convertibles (143 1509 061 KLIPPIN - MOD II) and sedans (111 857 706 KLIPPIN - MOD I). Klippin is a seat belt manufacturer. It is interesting that the convertible part number is a Ghia part number, perhaps because the shorter seat belt base was initially made for a Ghia?
1967 Sedan, manufactured in 1966:
1967 Sedan (black webbing, rather than grey - from a Ghia?), manufactured in 1966. Courtesy of John Henshaw.
1967 Convertible (same question as above), manufactured in 1966. This one is taped down, as it was barely holding on. Courtesy of John Henshaw.
1967 Convertible, manufactured in 1967. Courtesy of Jos Hall, with measurement information.
Using that information, I had a new reproduction label designed and printed on original looking material (as close as I could find, courtesy of customcouturelabelco on Etsy), thanks to an Adobe Illustrator design from Studio 28B. Note, my convertible is from early 1966, so I made my label based on that (so, manufactured in 1966).
I then had Safety Restore reweb my seat belts and put on the new labels, according to what I saw original (stitched under the fold over webbing, and then the bottom of the label itself folded over and stitched from underneath. Here is the final result:
I only needed two of these reproduction 1967 convertible Beetle front seat belt labels from 1966 (a fairly specific item), and, as I had to order a lot (50, in this case), I have a lot left. If anyone else is in need or would like so, please PM me with your address, and I'll see about sending a couple in the mail to you (no charge - I had to get them anyway!). If you would like the Adobe Illustrator file, I can send that as well (in case you want to change the part number and modification number to make your own for another 1967 Beetle - you may need a graphic designers help, though).
So, I just wanted to share my journey, and the results, in case anyone needs to do something similar in the future. Thanks for reading this far!
-Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia
harrymarlin
PostPosted: Fri Aug 14, 2020 4:01 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
BTW, for anyone who is interested, this font is similar to the font used on the engine tin stencils, DIN - a font developed by the Germans in 1931, and used in manufacturing/engineering applications: https://en.wikipedia.org/wiki/DIN_1451?wprov=sfla1
-Harry
old DKP driver
old DKP driver is offline
PostPosted: Fri Aug 14, 2020 6:49 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Harry, that’s a great write up especially to something rarely thought of on
Any website forums.
Thanks for this!
Chris
V.W.owner since 1967
Adriel Rowley
Adriel Rowley is offline
PostPosted: Sat Aug 15, 2020 11:39 am    Post subject: Re: 1967 front seat belt labels Reply with quote
I don't see it as too much, simply what is needed.
harrymarlin wrote:
Seat belt webbing
I looked on FDTS's webpage, not finding webbing at all, how did you acquire it?
I been wanting to replicate the original belts as part of what I remember about Dad's Beetle, soft unlike the slick and hard belts sold as replacements. I had yet to look into webbing, now thanks to you sharing this journey, I will not have to. I look forward to reading more.
Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation
harrymarlin
PostPosted: Sat Aug 15, 2020 12:14 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
I was directed to FDTS from a guy on a Porsche forum (thanks, Jos!) who was selling webbing for Porsches, but didn't have what I wanted. I didn't look too closely at their website, although I think they have significantly updated it since I started looking, but here is the set of samples they sent me for review:
They told me they don't normally sell just the webbing (they do restorations of seat belts) or do much business out of the UK, but they were willing to send webbing to me at a reasonable price when I asked. I don't think you are going to find the right looking webbing for sale in the US.
-Harry
Adriel Rowley
PostPosted: Sat Aug 15, 2020 2:20 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Harry, I am sorry I upset you, far from my intentions, was only trying to show appreciation; I would again however seems I shouldn't as only make it worse.
harrymarlin
PostPosted: Sat Aug 15, 2020 3:08 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
I am certainly not upset by anything you said - I think you asked a valid question, so I hope the additional information I gave was helpful. I think FDTS has a very good option, and I think anyone who is looking for webbing closely matching original will need to look outside of the US (at places such as the UK).
Do you have any pictures of 1964 webbing to start looking for matches?
-Harry
Adriel Rowley
PostPosted: Sat Aug 15, 2020 10:25 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Okay, good was just a misunderstanding. Yes, now know need to contact them for samples.
I have the original front belts, the driver's is so warn not sure I trust it. Might be ZFA or KA.
What I don't understand is why Dad's Sister walked off with the pair of belts Dad bought for putting in the rear (then bio "mother" left with us, not saying where she had gone). IIRC had close to the same weave despite being just over 20 years later. At least have the dealer plate frames, Dad took them off in '68 and so in great original condition (were in the same box).
67conv
67conv is offline
PostPosted: Sun Aug 16, 2020 2:58 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Harry, Thank you posting such an esoteric, yet informative narrative on the quest for webbing of original 1967 era Klippan seat belts and their labels! I applaud your willingness to "dive in, deep"...Also for the link to the German DIN standards for lettering and stenciling. Awesome! Great stuff for us originality geeks!! Much appreciated. John
1967 VW Convertible, owned 35 years.
1957 DKW 3=6, owned 21 years.
PREVIOUS: 1972 "Baja Champion SE" Spec. Edition Beetle bought NEW @ Pierce VW in Denver; 1979 Super Beetle Convertible bought NEW @ Downtown LA VW; 1967 type 1 savanna beige; 1967 Porsche 2.0 911S; 1973 Porsche 2.4 911T; 1963 356 T6 B Cabriolet; 1964 356 SC sunroof coupe; 1972 Type-3 Squareback; 1968 + 1969 Type-3 Fastbacks; 1987 Vanagon GL Weekender
Jos.Hall
Jos.Hall is offline
PostPosted: Sun Aug 16, 2020 7:00 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Guys, Harry may not realize this but his leg work not only on these seat belts/labels but on every aspect of his restoration, is going to save a LOT of headaches trying to get the details right.
My hope is that he will continue to share and document his research and processes regardless of view counts or comments.
Harry sent me a few of his labels and I want to share how incredibly accurate they are. My car was built in '66 as well so his adjusted date is appropriate for my car. This is a spare set of vert seat belts that I have because I can't have just one of anything.
PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin
Snotraveler
Snotraveler is offline
PostPosted: Fri Oct 16, 2020 7:01 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
This is the tag on my 1967 sedan. 111 857 705
Just thought I’d share.
Jos.Hall
Jos.Hall is offline
PostPosted: Sun Oct 18, 2020 5:56 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Yes sir. I'd assume that's from your drivers side on a sedan. The ending of an odd number is drivers side and the even number is passenger side. So the 706 would be a passenger side reel.
harrymarlin
PostPosted: Sun Oct 18, 2020 6:12 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Oh my goodness! How did I not know this up to this point? It looks like I only have labels for one side of the car!
<sigh> oh, well. Goid information, Jos! Thanks!
-Harry
Snotraveler
PostPosted: Sun Oct 18, 2020 6:16 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Yes, it is the drivers side. So many little “details” to these cars! Thanks for the info.
Jos.Hall
Jos.Hall is offline
PostPosted: Sun Oct 18, 2020 6:26 pm    Post subject: Re: 1967 front seat belt labels Reply with quote
Harry, my mind must not have been working all those times we were discussing it. The nomenclature only triggered in my mind when I saw the 705 and the 706 next to each other. I believe the only difference between left and right seat belts though is the adapter bracket.
