fridge replacement projects - post here
Page: Previous  1, 2, 3 ... 32, 33, 34, 35, 36  Next
fishgo
fishgo is offline
PostPosted: Sat Nov 07, 2020 6:58 am    Post subject: Re: fridge replacement projects - post here Reply with quote
djkeev wrote:
fishgo wrote:
More details please! How was that fridge wired? It seems 12V only, is there an option for running the fridge off 110VAC?
Using a simple off the shelf AC to DC voltage convertor, it would be simple to run and 12 v DC item on AC shore power.
Dave
Very true, but it seems it could also be ordered dual voltage? I like the look of that fridge.
therastavan
therastavan is offline
PostPosted: Sat Nov 07, 2020 7:43 am    Post subject: Re: fridge replacement projects - post here Reply with quote
fishgo wrote:
therastavan wrote:
Researched the heck out of the best option for a new fridge. Most said the Truckfridge TF49, but it’s Chinese and sticks out a lot plus it only comes in black. There were new Dometics but they wouldn’t fill in that huge empty space. Then I came across a lone post by “owokie” on the Samba forum. He swore by the Vitrifrigo C50i. Said it was the best choice. Nobody listened to him. I did. Hunted a new one from CamperInteriors.co.uk in the UK because nobody sells this model Vitrifrigo in the USA. It’s Italian. It’s the perfect color. It’s the perfect size. Fits flush. It’s just PERFECT! This is THE BEST refrigerator for the Westfalia. Period. Installed in 20 minutes. Not too deep to require any cutting behind it.
Super easy to wire! I used Anderson Powerpole connectors I bought here https://www.acerracing.com/products/powerpole-connectors-10-pair
They are real silver plated copper and can handle 30amps continuous which is way more than is needed for this fridge which by the way uses 35% less energy than the TF49 (40amp/24 hours vs 25.8 amps/24hours) and that saves a lot of battery power. So I snipped off the original wires off the original connectors and just used these to make a very efficient connection. I used their special crimping tool so I didn’t have to solder https://www.acerracing.com/products/ratcheting-crimper-for-use-with-15-30-45-amp-power-pole-contacts
It’s a 12v fridge but you can easily use a power inverter to go from 120v to 12v and the wires are in the cabinet next to the fridge so simply disconnect these Powerpole connectors and connect the inverter wires.
The Powerpole connectors are widely used in the camping world for these types of connections.
djkeev
djkeev is offline
PostPosted: Sat Nov 07, 2020 10:16 am    Post subject: Re: fridge replacement projects - post here Reply with quote
That looks like a really clean and easy install.
I do see on their website the AC / DC option.
Dave
Ghia
Vanagon
Beetle
therastavan
PostPosted: Sat Nov 07, 2020 10:46 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Here is the link to Vitrifrigo's website for the C50i
https://www.vitrifrigo.com/ww/en/c50i_internal_cooling_unit
Since it is tall, it is not so deep that it will stick out like the other units. But the inner capacity is the same.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Nov 07, 2020 11:09 am    Post subject: Re: fridge replacement projects - post here Reply with quote
I like those dimensions, where can I buy one?
thanks,
Mark
therastavan
PostPosted: Sat Nov 07, 2020 11:22 am    Post subject: Re: fridge replacement projects - post here Reply with quote
thanks,
Mark
Link to buy the refrigerator:
https://us-camperinteriors.glopalstore.com/collect...ge-12v-24v
Also, I used the optional fitting frame:
https://us-camperinteriors.glopalstore.com/collect...ting-frame
Link for the connectors I used to easily connect the wires to the Westfalia wiring:
https://www.acerracing.com/collections/powerpole-connectors/products/powerpole-connectors-10-pair
And the crimping tool for the connectors:
https://www.acerracing.com/collections/powerpole-c...e-contacts
crazyvwvanman
PostPosted: Sat Nov 07, 2020 2:12 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
About $250 for shipping by air from that UK source.
I was hoping for a US source but didn't find one yet.
Mark
thanks,
Mark
https://us-camperinteriors.glopalstore.com/collect...rame......
owokie
owokie is offline
PostPosted: Sat Nov 07, 2020 2:36 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Mark
thanks,
Mark
Email them. Mine shipped for $75. Unless you're more resourceful than me, you won't find one in the states.
djkeev
djkeev is offline
PostPosted: Sat Nov 07, 2020 2:37 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
More details on their website......
Dave
Ghia
Vanagon
Beetle
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Nov 07, 2020 2:40 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Mark
https://www.vitrifrigo.com/us/us/
according to this they have a office in florida. may be worth investigating. if this works well, i think i'd be game for one
edit:
http://www.marinewarehouse.net/Vitrifrigo.html
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
owokie
owokie is offline
PostPosted: Sat Nov 07, 2020 2:44 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Mark
edit:
The challenge is not finding a place that sells VFs, there are plenty. None of them import this model, at lease a year ago when I called the place you listed, Sure Marine, and every other vendor I could find. Only one offered to order one in, for more than I could get it shipped from the UK.
It works well.
WestiT3_1986
WestiT3_1986 is offline
PostPosted: Tue Mar 09, 2021 2:44 am    Post subject: Re: fridge replacement projects - post here Reply with quote
therastavan wrote:
How does the CRX50 fit so flush? The depth seems more than the Truckfridge.
Sorry, wasn't on here for quite a while.
I didn't cut anything at the back, but I removed the front insulation and door and fitted the inside to the old wooden Westfalia door. That makes up for quite a bit of space.
Rorke
Rorke is offline
PostPosted: Wed May 26, 2021 5:37 am    Post subject: Re: fridge replacement projects - post here Reply with quote
Challenging project here (for me anyway). Thanks to the Samba pioneers for information and inspiration. The original door isn't beautiful or fancy, but just easy on the eyes.
New fridge is a bit bigger, colder, has a freezer, doesn't use propane. But noisier.
It was tricky to keep my City water port because the delicate fridge guts are in the way. I also added a new port forward of the original three for an air compressor. To make room for this, I had to modify the "guts" with a homemade aluminum bracket.
nice door
bigger fridge for my woman's white wine
Air - City Water - AC - Water Fill - Diesel Fill
Not enough clearance for air
with the bracket
best view of inside obstructions
Looking good. I would like to get a new port over the diesel so it all matches. Next year.
JenEye
JenEye is offline
PostPosted: Tue Nov 08, 2022 3:28 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Hi! We are interested in adding the Vitrifrigo fridge to our 1989 Westy. Can you tell me how much power it draws? Also, how much of a gap is there left over at the bottom of the fridge and how did you seal that off? Thanks!
Also, what is your AUX battery setup? Would this work with a standard, under the drivers seat AGM gel battery system?
R0Batt
R0Batt is offline
PostPosted: Tue Mar 07, 2023 11:42 am    Post subject: Re: fridge replacement projects - post here Reply with quote
I am also about to pull the trigger on a Vitrifrigo C50i.
Is it a bigger capacity than the factory westy fridge?
How useful is the freezer portion? I see there is an option to order one without it.
There is also a seller on ebay that is selling them. Looks like they are only selling black ones at the moment, but I messaged them to see about silver.
85 Westy
Charlotte, NC
jimf909
jimf909 is offline
PostPosted: Tue Mar 07, 2023 11:58 am    Post subject: Re: fridge replacement projects - post here Reply with quote
I have the VF51 so not exactly what you're looking for but I believe this is still relevant:
1 - Much bigger than the stock Dometic. I don't have the dimensions but it's noticeably bigger and we love the added capacity.
2 - I love the freezer. We keep ice cream bars and have two ice cube trays for stirring the essential Manhattan or Martini for cocktail hour. We also start trips with some meats frozen in the freezer.
- Jim
Butcher wrote:
Guilty as charged.
R0Batt
R0Batt is offline
PostPosted: Tue Mar 07, 2023 12:14 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Great information. Good to know about the freezer being functional.
Now time to shop around and find a good deal lol
Since I have the white/brown interior, hopefully I will be able to paint the silver parts around the door brown pretty easily.
Did you use any of the mounting flanges that are optional?
85 Westy
Charlotte, NC
Chilepines
Chilepines is offline
PostPosted: Sun Apr 09, 2023 9:43 am    Post subject: Re: fridge replacement projects - post here Reply with quote
I've been fretting for a while about which fridge to get. Seems the Dometic CRX 50 is a really good unit, and it now seems they are available in the US but only in black.
Does anyone know if the front panel on the black is changeable? I really like the factory look you get that way, and don't want an all black fridge in an otherwise original interior.
josepvan
josepvan is offline
PostPosted: Sat May 13, 2023 11:51 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
WestiT3_1986 wrote:
Dear Vanagon/Westfalia friends,
I thought my just finished fridge swap might be of interest for some of you...
Sven
Hi Sven!
I recently bought a CRX50 fridge and I'm planning to follow your steps. Thanks to share your experience!
But I would like to know how you rate the results so far. Is there any further advice to give about the process or to improve the results?
Many thanks!
Josep
therastavan
PostPosted: Thu Jun 08, 2023 7:36 pm    Post subject: Re: fridge replacement projects - post here Reply with quote
Yes the Vitrifrigo C50i is much larger than the factory fridge and it really is the best option out there hands down. Nothing else comes close to it. Forget about the TruckFridge or Dometic. The C50i is the right color, easy to install, sits flush, and fills the entire space. Someone like GoWesty or BusLab really needs to import these to the USA so people can have easier access to them instead of hunting one down from Europe although it's not that hard to find with a simple google search.
Page 33 of 36
